Question about Sherwood Audio Players & Recorders
The display does not light up sound does work
Unit turn on but no display. Functions seem to work and sound is good. Cannot see what I am doing on the display
  • 60 Answers
I personaly had a sherwood system once and had to replace the backlight. Seems to be a similar problem...
cheap repair, if you like your system it worth the repair.
Posted on Nov 29, 2013
  • 1 more comment
  • Doug Call
    Doug Call Nov 29, 2013
    Thanks for the hint
  • InstaRep
    InstaRep Nov 29, 2013
    no problem, you can gently tap on the screen to see if you can give the bulb a second life. Don't try this too long, just to see if it react. good luck!
  • Doug Call
    Thanks again
Samsung rs261mdpn
Replacing the main control doesn't fix anything on the display they have separate functions. You need the bom number to find the display board it should end in /xaa or something like that
Nov 06, 2013 | Refrigerators
I have a Jandy Aqualink RS OneTouch Wired Control Panel. The units light is on but there is no LED display. The unit continues to operate and turn the pool pump on and off at the scheduled times,...
It sounds like the unit itself may be out. The acid test would to be to get hold of a new one and switch them out. See if you can find a local pool company to work on that for you.
Dec 26, 2012 | Jandy AquaLink RS OneTouch Wired White...
I have a JVM1850 that was installed 4 years ago. The unit was working fine, then a day ago I received an error display requesting a charcoal filet replacement. No filter is needed since it is vented...
I have a JVM1850 White microwave-over the oven-installed 3 years ago. Last evening the unit would not turn off. The inside light and fan continued to run, however, the microwave was not working.
All the controls and functions seem to operate, but when completed, the unit remained working, as stated above, with the door opened or closed.
Sep 18, 2011 | GE JVM1850 1000 Watts Microwave Oven
L322 reg02 radio display not workin no sound on tv or sat nav. visual display working on sat nav and tv but no sound. seems as if there is no power to left hand side of unit. righthand buttons working but...
solved the problem after speaking to the main dealers, disconnected battery for fifteen minutes then reconnected which rebooted system. Range rover say just like your home computer its got glitches so rebooting works, common problem in cold weather.
Jan 13, 2010 | Car Audio & Video
Display has very light illumination and does not display temperature or other settings. All functions seem to work but functions are not shown on display including temperature, Bake/Broil cycle, etc. Time...
This is a failure in the electronic range (or oven control) ERC or EOC. You can replace it with a new one, or have it repaired.
- www.fixyourboard.com
Jul 26, 2009 | Ovens
Blur and green display on startup
It sounds as if your display is shot. To prove it, turn the machine off, and plug in an external monitor and then turn on the unit. Activate it through the fn keys and the appropriate button across the functions. If the monitor looks good and you still have the blur your laptop display sounds like it needs replaced/repaired. If it follows through to the monitor, then your video driver might be flaked out. If the latter is the case, start your unit in safe mode and see if it can be seen once you get the machine started. Good luck.
Apr 27, 2009 | HP Computers & Internet
03 chev silverado radio on but no sound
My van radio runs on 2 different fuses- both in the fuse box under the dash. One runs the lights the other the sound. Hope this helps.
Jan 11, 2009 | 2003 Chevrolet Silverado 1500
studying the radio schematics , i'm seeing a radio amp fuse under the hood ,in the main fuse box under hood , 30 amp , check that for starters , if the amp was out you would only lose sound , would like to get a fix ya vote , comment back because i have other thoughts on your schematics , and do you know if its the base model or premium sound , with or without cd ? , thanks .
Jan 11, 2009 | Car Audio & Video
DOUBLE OVEN,GAGGENAU
this oven could be in display mode this only allows non harmful functions to work eg lights etc but no heat this can be disabled through clock test prog reset but you will need an engineer to do it as complicated.
ring 08705 678910 for service and advise
good luck
Dec 16, 2007 | Gaggenau EB 270/271 Electric Single Oven
121 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Josh Whitehead
Josh Whitehead
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
