Question about Samsung LN32C350 32 in. TV
LN32C350 external speaker
How do I connect external speakers to my LN32C350 samsung TV
  • 304 Answers
SOURCE: 46" Samsung LCD, no sound output whatsoever
First try hooking up a different source such as a DVD player or Cable box and see if you have audio. If you do then check the audio output from the computer. If you do not have audio then make sure the tv audio is up half way and turn off the set. When you do this you should hear the down chime provided you have the chime turned "on". If you do not hear the down or up chime then the sudio circuits on the Main bd are bad and the Main bd will have to be replaced. A quick way to check to see if the audio circuits are working is to listen for the up or down chime when turning on of off the set coming from the tv speakers speakers.
Posted on Jul 16, 2009
  • 610 Answers
SOURCE: I have a Samsung LN-T1953H TV and the sound
It sounds like the main board has gone out. The only audio components are the main board, wiring and speakers. Since audio is missing from external speakers as well, that tells you that the main board is at fault. The cost of the board could be from $150.00 to almost $300.00 depending on the version # of your unit and dealer mark up. You can call 1-800-samsung for nearest service center.
Posted on Mar 18, 2010
  • 304 Answers
SOURCE: Samsung UN55B8000 Audio out - 3.5mm connection not working
Try a firmware update from Samsung. If that does not work, replaced the Main bd.
Posted on Apr 16, 2010
  • 1779 Answers
SOURCE: My samsung ln32c350 lcd tv
Yes, I would exchange it for another ASAP.
Posted on Dec 01, 2010
  • 2509 Answers
SOURCE: how do i connect external
You will need to use powered speakers (like the ones used for a computer) and plug them into the headphone socket.
Most flat screen tvs dont have connections for extra passive speakers.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply and remember, even if you don't vote for me a please and thank you goes a long way
Posted on Mar 05, 2011
No sound coming from internal speakers Toshiba Projection television Model 50h82.
Some TVs have a set up option to disconnect internal speakers when an external audio amplifier will be used.
Dec 29, 2016 | Samsung Audio Players & Recorders
What do I need to connect external speakers to tv
You will need an amplifier and depending on your tv you can run either red and black RCA leads or a toss link fibre optic cable to it.Then connect speakers to the amplifier(stereo)
Aug 30, 2014 | Televison & Video
Why does my JBL sound bar connected with the optical cable not get any sound from my samsung ue46f6400
You may need to select 'external speakers' in the audio setup.
Here are the steps:
http://www.samsung.com/us/support/howtoguide/N0000058/12807/153493/UN40F6400AFXZA
Menu / Sound / Speaker Settings / Speaker Select / select External Speakers
May 18, 2014 | Samsung 6400 Series UE46F6400 46" LED TV...
Connecting tv external speakers
If you connected R/W RCA cables to the AUDIO OUT RCA jacks on the rear of the TV and connected the other ends to the TV AUDIO IN jacks on the receiver, you should be able to select an input on the receiver that will deliver sound to the Bose speakers. If you went to TV setup and selected external speakers, you directed output from the TV amplifier to external speakers which is not what you want.
Jan 27, 2014 | Televison & Video
Volume working
Code for NEO 1451 TV?(universal remote control)
Aug 14, 2013 | Samsung TV Remote Control
Connecting external speakers
If the speakers are wireless, wouln't the receiver connect to the speakers and some kind of transmitter connect to the TV?
Jan 20, 2013 | Samsung Hl-s5686w 56-inch Dlp Hdtv
I have lost my owners manual for this set and I want to attach external speakers to improve the sound quality. What impedance should I use and how do I set the t.v. for this operation.
I have 2 Samsung's. One is a series 3 one is a series 5. Both are very similar in the setup so I hope this is helpful. I have both tv's hooked up to external speakers.
First step is to figure out what kind of connect you will use. There is a 3.5mm Jack on the back of the Samsung models the is labeled as EXT. There is also the Optical cable port which will give you better sound. So you need to see which of the ports your speaker system has.
Second go into your menu - speaker settings - and at the bottom it will give you the option to use external speakers. Choose that.
Now that should be all you need to set your tv up for external speakers.
Mar 01, 2011 | Samsung Televison & Video
Sound at 50-70 is not that loud. we have another model same size and samsung that is extremely loud at 25.. i dont understand
Speakers sometimes become damaged when going at high levels from low levels and just switching like that..... This may be the cause for it to be kind of low.... Best not to turn it all the way up or it might just blow the speaker fully..... You may have a a volume limit set on it.... Check that, it might be not allowing your speakers to play any louder.... Otherwise, it is best not to have your speakers blaring, just have them kind of low, and your ears will adjust.... People lose hearing when they have their TV's turned all the way up and all loud... Plus it just kind of disrupts the peace of a home :) Good Luck :D
Jan 08, 2011 | Samsung LN32C350 32 in. TV
How to attch speakers to series 8 tv
From the spec sheet I was able to find it APPEARS that the only way to connect speakers to this unit is via the headphone jack. There seems to be ONLY input audio, no output other than the headphone jack.
Using this jack will likely turn off the internal speakers and you will have to use AMPLIIFIED or "ACTIVE" speakers if you want external ones.
If you connect external devices to this, make sure they are all fed from the same receptacle to avoid ground loops and possiblle damage.
Nov 10, 2009 | Televison & Video
Samsung LN32C350 32 in. TV Logo
80 people viewed this question
Jerry Greenberg
Jerry Greenberg
