Question about Sony DSR-25 Mini DV VCR
When pressing the eject button the front door doesn't open (it ejects the tape, but have to manually lift up the door to let the tape out). How can I fix this problem?
  • Sony Master
  • 5,047 Answers
It's probably a small spring that has detached itself from the door. There might be some plastic damage, which could be repaired. The only way to see what is happening is to remove the top cover and eject the tape.
Posted on Dec 07, 2013
  • 275 Answers
SOURCE: vcr jams on eject
What do you mean 'Tape crunches" Do you mean that there is tape slack, which then crunches when Tape is lifted during Eject? If that is the case, then the Supply Reel Roller Brake is bad. it is a Felt Pad, which needs replacing. If the entire eject operation is wonky, or if it's timing is bad, then I suspect that One of the eject Gears (On either side of the Mechanism) is damaged and needs to be replaced. One question, i assume that you are able to eject the Tape eventually, and so - Does the Tape Load into the VCR properly, when you insert it into the machine? This will help me in giving you a better diagnosis.
Posted on Mar 14, 2007
  • 1153 Answers
SOURCE: Tape keeps ejecting
You can check tape player for any type of object lodged in it. Maybe unplug and turn upside down to here anything inside. Or even any broken tape that come off inside. The only other thing is that the belts inside are worn and will not put device back in play mode.
Posted on Dec 22, 2007
  • 139 Answers
SOURCE: VCR tape won't eject
The flap on the door stays open until the tape is ejected. There are two possible ways to remove the tape. First, with the power off, try to locate the drive pulley or gear on the side of the tape housing. It may be possible to turn it with your finger and cause the tape to eject. The eject mechanism will move VERY slowly when you use this technique.
The second way to do it should normally be done by an experienced technician, because it involves taking it even farther apart...and it may be difficult to reassemble. There are typically four screws that hold the tape mechanism in place...two near the top front and two near the back. It should be possible to remove those screws and pull the entire mechanism out of the VCR. Then you can more easily rotate the eject pulley (or gear) and remove the tape. If this sounds a little scary, I would definitely recommend placing the top back on and acting like nothing happened!
Posted on Mar 17, 2008
dcxdan
  • 5 Answers
SOURCE: Code 3L117C ???
None that I could find. Trash time for this Sony
Posted on Aug 01, 2008
radar001
  • 1051 Answers
SOURCE: VCR tape is stuck - will not rewind or eject.
There schould be a release buuton on the rear of the machine. It's usually recessed and may be difficult to see. Press this with the yip if a ballpoint pen and extract the tape. If the tape is wrapped around the record/playback heads your only option is to remove the top cover and manually remove the tape. Sounds difficult but if you take your time it's not too bad a job.
Posted on Mar 08, 2010
Testimonial: "Thank you! - no button - took the top off. I depressed a lever next to the tape switched the VCR back on and pressed the eject button - it worked!"
Vcr tape will not eject
Try unplugging the unit and re starting it.You can also lift the front cover and try pressing in, down while pressing the eject button.
May 26, 2011 | Sony RDR-VX420 DVD Recorder/VCR
Can't open door - can't eject tape
How old is your camera?
Seems it has weak capacitors in circuit.
Oct 27, 2008 | Sony Handycam CCD-F555 Camcorder
I have a Gateway 300x Micro-Tower case circa 2002 and I can not open the case, without breaking it. I'm trying to install a new audio card and can't get at the 300x innards. Help!
Most of these towers are vertical style, therefore the big button is just to the left of the Gateway symbol. Push it in and pull the left panel away from the case.
Jan 11, 2009 | Computers & Internet
Tape won't eject,tv keeps shutting off
sounds like your tape is jammed try turning the tv on and ejecting the tape while using something to try to lift the tape up and out good luck.....
Dec 19, 2008 | Emerson EWC1301 Combo
Tape eject
I have the same camcorder SONY DCR-TRV130 and have had this same problem.
The first time this happened, I was able to eject the tape by turning the unit to VCR, removing the battery then putting battery back in and pressing the blue eject button. Now 2 years later, same problem only the same solution did not work. I read many other solutions, and found one I had not yet heard of. They mentioned using a straight edge..... I was confused, but learned that the point is to try to press the blue eject button without having to completely open (lift) the door. I was able to use a strong paperclip (opened up or unfolded) I reached in with the paperclip and applied pressure to the blue button and as soon as I heard the "gears" turning, I lifted the door and the tape ejected.
Try it, I was very surprised that it worked. This has been a problem for me for about a month. I am pleasantly surprised to have a solution. Hopefully it will work for you too!
Sep 15, 2008 | Video Cameras
Hi I cannot get my d.v.d drive to open and close. What do I do?
  1. If the keyboard has a CD/DVD Eject key, press it. The Eject key is usually placed by the volume knob and is marked by a triangle pointing up with a line underneath.
  2. Double-click My Computer .
  3. Right-click the icon for the CD, CDRW, or DVD drive that is stuck, and then click Eject.
  4. If the CD or DVD drive door button is a long clear plastic bar on the front of the PC, press firmly on the right side of bar. Some models have a button on the front panel of the PC to the right of the hinged door. Press the button to eject the drive.
  5. If the drive door button is part of the PC case and is covering the actual drive door, open the door that is part of the PC case and press the Eject button on the faceplate of the drive.
  6. Restart the PC and press the Eject button on the front of the drive when the first screen appears (before Windows launches). If the drive door opens this way but does not open in Windows, another software program is taking control of the CD driver. Try shutting down or configuring any software programs that create discs or monitor the CD or DVD drive.
  7. If the door still does not open, do the following:
    1. Close all programs and shut down the PC.
    2. Unplug the power cord from the power outlet.
    3. Look for the small hole on the faceplate of the CD or DVD drive. This is the manual release. The location of the manual release hole will vary
  1. Straighten the paperclip and insert it into the manual release hole until resistance is felt.
  2. Once the resistance is felt, keep pushing the paper clip until the drawer opens a little.
  3. Remove the paper clip and gently pull out the drawer until the disc is accessible.
  4. Remove the CD and turn on the PC.
If the tray still does not open, do the following steps to check the power cable for the drive. Work on a hard flat surface over a non-carpeted floor:
  1. Turn off the PC.
  2. Unplug all power cords from the back of the PC.
  3. Press and release the Power button on the front of the computer.
  4. Remove the side panel.
  1. Unplug the power cable and wait five seconds.
  2. Find a different power cable that is not being used, plug the different power cable into the back of the drive, making sure that it fits firmly into the socket. If a different power cable is not available, replug the original power cable into the back of the drive, making sure that it fits firmly into the socket.
  3. Replace the side panel and plug in the power cord.
  1. Turn on the PC and press the eject button on the front of the drive.
If the optical drive does not have the manual eject feature and the CD tray will not open by using the steps in this document or if a disc has shattered inside the drive, the CD, CDRW, DVD drive may need to be replaced.
Thanks
Aug 18, 2008 | Computers & Internet
Philips VR1010 VCR
Because of the complexity of the equipment involved I would suggest that you take it to a local authorized repair shop.
Mar 27, 2008 | Televison & Video
Cannot eject VHS tape from Sony SLV-X811
I had a similar problem with a Panasonic VCR. It would not eject the tape and gave an error code. I found that the door does not quite fully open, so that the top of the tape hits the door and cannot eject. If I turn off and then turn on the VCR the error code disappears. Then I press the eject button and simultaneously hold the door fully open with one finger until the tape starts to eject and clears the door.
Feb 29, 2008 | Televison & Video
My Drive will not eject the tape
Turn off the tape drive. (Switch in the back of the unit. Wait 2 minutes and then turn unit back on. Tape drive should issue a write data command and then rewind the tape. After rewind completes the tape should eject. If it does not eject after rrewind completes than try holding the eject button for 5 seconds to attempt a "force eject"
Note: Do not repeatedly press the eject button as this can cause damage to the tape and the tape drive.
Dec 07, 2007 | Quantum SDLT 320 External LVD...
Gs36 tape door doesnt open
In case anybody read this....     I have a GS-36 that would not eject the tape. I removed all the screws from the bottom and pulled the bottom plate off. Then I fidgeted with the mechanism near the eject button towards the front of the camera.  In my case it had just become stuck and needed to be gently pried open.    Tested it a bunch of times with tape - seems to be o.k.!
Oct 13, 2007 | Panasonic PV-GS36 MiniDV Digital Camcorder
Sony DSR-25 Mini DV VCR Logo
96 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
