Question about Behringer Djx900usb 5 Channel Dj Pro Mixer
Just got a DJX900usb.. without using any external soundcard i'm abconnect with traktor pro 2. but only channel 1 is working. if im on channel 2 it must be control from channel 1 yet same goes to other
Need all the channels to be working fine
Can I connect this mixer without having to buy an additional pice of equipment?
You will need speaker(s), amplifier and appropriate wire. I see no problem with the Traktor pro
You can get the manual at: http://www.behringer.com/assets/DJX900USB_P0A56_M_EN.pdf
May 20, 2013 | Behringer Djx900usb 5-channel Dj Mixer...
Memory dump blue screen
Sounds like you are having an audio driver problem try using a different driver for your sound card
Jul 01, 2017 | Computers & Internet
I just got the x1.. installed it earlier and it was connected with traktor working.. then after i installed the cd.. ( dont know why. bc it was already working ) for some reason after that.. it is now not...
I suggest :
1 - desinstall x1
2 - desinstall Traktor
3 - Reboot PC
4- Reinstall traktor , during the setup it ask if you have external controler , select the X1.
It Should work like this
Aug 01, 2011 | Native Instruments Traktor Kontrol X1
Cant hear anything out of my speakers connected to djio
Are you using a Mixer as a pre-amp for this set-up? For example, I have a Numark CM200 where I have all of the inputs and outputs I need to run. DJ IO is connected to Chanel 1 and Chanel 2 Lines in my mixer. The DJ IO is conected to my computer by USB cable. In Traktor souncard settings chanel 1 is set to (3&4) Chanel 2 (2&1) also, devise set up is Numark DJ IO and in External mode. Of course the mixer is conected to my amp and speakers conected to the amp as well.
Apr 26, 2010 | Numark DJ/iO Sound Card
Trying to setup Traktor PRO with the DJ IO and Stealth Control as the mixer... cant get the other deck to play on my headphones, and also having trouble figuring out the OUTPUTS in the properties menu of...
the outputs in Traktor should be set up like this; Chanel 1 (3&4) Chanel 2 (2&1) this set up will give you a stereo sound coming out of Traktor using Numark DJ IO. Make sure the output is set up External and the Audio Devise is Numark DJ IO.
Mar 06, 2010 | Numark DJ/iO Sound Card
Phones 1-2 has both channels coming out of it
Had the same problem and fixed it today. It is the mute button. Whem you change from 1-2 to 3-4 if the mute button for 1-2 does not activate you will get the sound from 1-2 thru 3-4. Just change the setting and you are away. worked for me.
bruce
Jun 03, 2008 | Echo Indigo DJ Sound Card
Details to obtain Headphones from laptop
you dont have to use 2 soundcards because the system will only use 1 soundcard, putting 2 soundcards will just cause chaos to your system. anyways, you could use a special kind of soundcard to have great results.
Mar 11, 2008 | Computers & Internet
Behringer Djx900usb 5 Channel Dj Pro Mixer Logo
57 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
