Question about Canon PIXMA iP6700D InkJet Photo Printer
NOt printing text
I own a 6700D and my friend also has one. Hers suddenly stopped printing any test in Black. It prints photos okay, it goes through the motion of printing text out of various programs including the text print page but the page remains blank. I have tried it in colour and that seems to work. But nothing in black. So I thought, New cartridge even though the one in there was full. That didn't work. I have used it on 2 other computers and does the same thing, leading me to believe it is something in the printer. Have set the printer settings to factory defaults in case, but no change. I have used a new cartridge out of my printer that I know works fine but it didn't help.I am slowly coming to the conclusion that it is an internal programming problem with the printer unless you are able to shed some other light on it.
Thanks in advance
Regards Ralph
  • Aussieroo Oct 11, 2007
    I have swapped out the print head with my printer which works perfectly. There was no black text at all, put the print head back into my printer and it works fine. I feel this is looking more like an electrical problem. Contacts are all clean and look fine as well. So it appears whatever controls the "Pump" for the black ink isn't working. Any further ideas?
    Thanks for your prompt reply and attempt at finding a solution
    Ralph
  • Aussieroo Oct 17, 2007
    Thank You Thank you,
    I had a second look at the electrical contacts and found the ones where the ink tanks couple up and cleaned those, recleaned the main back plate on the print head and the spring contacts and Bingo. Seems my hunch was right it was electrical but I had missed the new contacts on the ink tanks.
    Thanks again, I have one happy friend who doesn't have to fork out for a new printer.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
The problem is the Printhead. The ink has dried up and therefore does not print. If you want to save the printer for  about  $15-20 there is solution that I bought that supposedly unclogges dried up printheads, I have NOT tried it yet, but being in the field it's just a matter of time. E-mail me back in case you have not thrown out the printer yet.
Posted on Oct 11, 2007
  • CheckitRight
    CheckitRight Oct 16, 2007
    The Line or feeding tube for the black ink is clogged up, like I previously stated sometimes depending on the models the printhead gets clogged up, with your since you can remove the printhead the feeding tube stays in the printer.
    check out this page.
    http://www.fixyourownprinter.com/search/...
SOURCE:
My Epson Workforce 1100 suddenly stopped printing black when printing in color. This happens when printing from Microsoft Word, Wordpad, Lightbox (photo manipulation) and Adobe Reader. It prints black...
normally most printers even like mine an epson NX110 will use color then black when using text but with grayscale only your forcing it to use black ink more and no color ink set in normal mode some color ink does get used ironically but it is normal for it to use color some as it reserves the black ink being used
Apr 22, 2017 | Epson WorkForce 1100 Wide-Format Color...
Not printing full text on page
It sounds like you are trying to print from frames. If in doubt the simple test is try printing the windows self test page. If that prints OK then your cartridges are OK. If you sre trying to print from an internet browser - download the page first and then print it or see if there is a "printer friendly bar"
Feb 12, 2018 | HP C4280 AllInOne InkJet Printer
I70 Canon photo printer will not print after changing print cartridge.
Check the black cartridge and make sure the orange or yellow tape at the rear end is not still attached. If it covers the small hole on the top of the cartridge, the printer won't print black text.
Mar 09, 2012 | Canon BubbleJet i70 InkJet Photo Printer
Black text or photo print in green
check test page... and ink levels... Try to print on other type of paper
Mar 19, 2010 | HP DeskJet F380 All-In-One Printer
Lexmark x6170 stopped printing text will only pint images
First, print a test page from the printer's menu and see if the black lines and text look okay on that. If there is no or poor black printing, you need to replace the black cartridges or try cleaning the cartridge's nozzle with rubbing alcohol. If that looks fine you need to check the printer's settings in its properties on the system lift of printers.
Oct 01, 2009 | Lexmark X6170 All-In-One InkJet Printer
HP z2100 horizontal lines where the text or object are
Check for updated firmware and drivers. Also, if all your object and text or black try changing them to color and see if that helps, maybe there is something wrong with your black printhead, the black may not be used when printing photos, the printer may be using process black for photoes and real black for black text and objects.
Oct 08, 2008 | HP DesignJet Z2100 InkJet Photo Printer
Print quality suddenly degraded
Sounds like your print head went bad. You will have to buy another one.
Jun 04, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Text Not Printing
You are out of black and white ink.
Graphics are printed with the color cartrage
text is printed with the black and white.
Apr 30, 2008 | Brother MFC-8440 All-In-One Laser Printer
Canon IP3000, problem printing black
Try to change the default printer and check ...
Also try printing from other documents see if you facing the same problem
What version of Works you using ?
Do you have the Dic for Works ?
Apr 14, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA  iP6700D InkJet Photo Printer Logo
94 people viewed this question
Clive
Clive
old marine
old marine
Ekse
