Question about Kingston DataTraveler R3.0 32 GB USB 3.0 Flash Drive - 1 Pack External
Kingston DT 3.0 32gb not recognized by computer
When i insert into usb it does not show up in my list of devices and i cannot access the files. drivers are loaded and prevviously it was accesible. data light on DT3.0 does not light up either
    Champion:
  • 245 Answers
If u use Windows -> right clik on my computer -> manage-> and then disk managment-> find the disk and activate it, probably offline, do not click on format if there is data on it !
Posted on Dec 06, 2013
USB Mass Storage Device(Kingston DT 101 G2)
Name: Kingston DT 101 G2 (USB2.0)
Logic Driver: L:\
VID&PID: Vid_0951&Pid_1642
Speed: high speed
VendorID: Kingston
ProductID: DT 101 G2
Product Revision: 1.00 what s the softwar for this flash??
Feb 10, 2014 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston dt101g2
if u can format your device format as fat32....before format keep your data...
Jan 02, 2014 | Audio Players & Recorders
What is the password for the new kingston USB DT109?
It is true that locking mobile storage devices, such as USB drives, with Imation Lock is an excellent way to protect your data.
However, using Imation Lock with a Kingston USB drive can create problems.
Learn how to unlock your Kingston USB drive so you can use it once again.
Ensure that your Kingston USB drive has been removed from your computer's USB port.
Start the Imation Lock software by double clicking the Imation Lock.
Plug in the Kingston USB into a USB port immediately after the "Please Insert the Device or Run This Utility as Privileged User" message appears.
Access your Kingston USB drive by clicking Start > Computer.
Double click on the device.
Start the Imation Lock software again by double clicking the Imation Lock.
Disable the password protection by clicking the open lock icon.
or
If you have password protected a USB drive or partition on your computer and have since forgotten the password, you will need to completely erase the drive.
Erasing and reformatting the drive will remove any password protection, software and data on the drive preventing you from accessing the drive.
The process is simple using Window's Disk Management utility.
Log into the computer as the administrator.
Open the Windows Start menu, select "Run," type "Compmgmt.msc" and click "OK." In Windows Vista and Windows 7, simply type the command into the "Search" field.
Select "Disk Management."
Locate the password-protected drive.
Right-click it and select "Delete." Confirm the action.
The drive will be erased and become unallocated free space.
Hope this helps.
Nov 28, 2012 | Kingston Ultra Thin DataTraveler DT 109...
Kingston Datatraveler Windows 7.
1]Go to control pannel
2]Go to System and Security
3]Go to Device Manager
4]Click Universal Serial Bus Controllers
5]Right click the USB
6]Click Uninstall
then Reboot computer while pendrive is inserted in USB
Then connect to the internet.
When you connect to the internet if the said USB is empty
(i.e. no device is inserted in it) they install the device
eventhough the device is not present, causing the said error.
Aug 15, 2012 | Kingston Computers & Internet
When connect my pen drive ( kingstone 8GB G2) it can connect.....it showed on my task bar........and when i open drive of it in my computer it say "please insert a disk into drive H: "...
the computer may have recognized the device as a card reader instead of a thumb drive, try inserting it into a different usb port. And if that doesn't work ,back up the files on the drive and try reformatting the drive.
Jun 17, 2011 | Computers & Internet
Window did not recognized my kingston usb (DT slim)
Usually all flash drive are plug and play devices if your computer is not recognizing it you should try plugging it into another USB port and even try plug in another computer to see if it would work.If your flash drive does not work this mean it is dead and the flash drives are not design to get the information off when it is dead.
Aug 17, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
DT mini Slim 4GB not working
run this command:
c:\format xx:\ /FS:FAT32 /A:4096
Substitute "xx" for the drive letter that windows gives to the Kingston DT Mini 4GB.
It worked for me after using it as a Jolicloud Live Bootable USB.
Sep 28, 2009 | Sony Computers & Internet
Kingston DT1000 pendrive was not detected in computer
hi there.
this is what i have just found on the internet it might help you out but not sure.
After plugging in the device. Go to device manager (In run type "devmgmt.msc") In Device manager go to "Universal serial bus controllers" It should list the storage devices that you have connected to your PC. Right click and then click "Uninstall. Remove the USB drive and restart your system.
Try connecting the device again, I think this should solve the problem.
for windows xp
first you need to go to Device Manager by double-clicking on the System icon in Control Panel, choosing the Hardware tab, and clicking Device Manager.
go to divice manager
usb hub controler it will be at last of the list then
right click on usb hub controler open it go to usb root hub right click & go to properties
then go to device and click ok
do it 4 to 5 time it will work 100%
i have tried it and it worked
Best of luck :)
hi do one thing go to my computer right device manager ther u to o universal serial bus right click on tht option go to update driver select yes this time only give automatic k . before doing this step plz insert mother board driver cd after tht u do all this procedure thn c ur pendriv vl be dedected k
if none of the above works try this link out.
Kingston DT 1000 pendrive was not detected in computer Google Search
Nov 20, 2017 | Transcend (589307) Media
My noteoook got the problem with port usb
Since you have these many problems with your laptop, Firstly try to reformat the system and reinstall all the neccessary drivers. Many times reformatting works well as your OS might malfunction when you have virus or malwares in your laptop.
OTHER SOLUTIONS
a. for USB:
  1. Click Start, click Run, type Devmgmt.msc, and then click OK. The Device Manager window opens.
  2. Expand Universal Serial Bus controllers.
  3. Right-click a USB Root Hub in the list, and then click Properties. The USB Root Hub Properties dialog box is displayed.
  4. Click the Power Management tab.
  5. Click to clear the Allow the computer to turn off this device to save power check box, and then click OK.
  6. Repeat steps 3 through 6 for each USB Root Hub in the list.
  7. On the Action menu, click Scan for hardware changes.
    Windows XP recognizes the new device.
  8. Close the Device Manager window.
b. SD CARD
Your 1GB kingston card might have virus. use a card reader and reformat the card for future use.
c. Uninstall and reinstall the driver of your finger scanner.
Hope this helps,
~regards,
Jegan
Jun 01, 2009 | Lenovo 3000 N100 Notebook
Kingston DataTraveler R3.0 32 GB USB 3.0 Flash Drive - 1 Pack External Logo
335 people viewed this question
Top Kingston Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
