Question about Sewing Machines
How to thread a bernina top thread 830 - Sewing Machines
  • 38 Answers
  • 27 Answers
SOURCE: Bernina 830 stopped running
Motor brushes are usually the problem
Posted on Jan 14, 2009
  • 52 Answers
SOURCE: bernina 830, worked fine until today... think it
there is a board inside the foot pedal that goes out sometimes you can check this by flipping the foot pedal upside down and at the top right there is a small hole where you can adjust the speed with a flat head screwdriver but be gentle it breaks easy, if its out you can take it to a bernina dealer and they might have a reapired one or they can send yours off for repair since that part is repair only
Posted on Jun 26, 2009
  • 5 Answers
SOURCE: Bernina 830 stuck
You probably have a crack in the cam gear.
Posted on Jul 25, 2009
  • 13 Answers
SOURCE: old bernina 830 stitching problem: tight
Sounds like you need to adjust the tension. Probably a good idea to oil this older machine before you adjust. Also look for and clean out any lint or debris in bobbin case and around foot area.
Posted on Aug 29, 2009
  • 1116 Answers
SOURCE: bernina artista 180 keeps warning to check top thread
Refer to your manual for maintenance and clean the machine as indicated. A sensor may be blocked by lint.
If this continues, the machine will need to be serviced by an authorized Bernina repair tech.
Posted on Mar 25, 2010
Needle threaded is stuck in up position will not return 830 bernina
Bernina 830 Record??? Or newer Bernina 830 computerized?
If it's a Record, could very well need a good cleaning and oiling. Older mechanical machines need periodic lube to keep them running smoothly and quietly.
Wheel on right side that controls the needle up and down is very tight...
Feb 11, 2017 | Bernina Sewing Machines
I have a Bernina 830. Using #03 foot....bobbin thread through the hole in the arm of the bobbin. Why does it not go in reverse to finish the buttonhole?
If it is the older Bernina 830 Record, could be some of the parts have seized due to lack of oil. Frequently, seldom used functions (levers, dials, feed dog control) are the first signs.
Be sure to move the dials/levers and apply oil there as well.
Dec 07, 2016 | Bernina Sewing Machines
I have an 820. The needle threader is clean of lint but still does not work
Threading the BERNINA 880e 830e 820 Bernina Sewing Center Tampa
http://www.manualslib.com/manual/726261/Bernina-820.html?page=30
Bernina 830 880 Needle Threader Cleaning
Install a brand new needle. Verify that it is installed correctly and is facing straight forward. If it is still not threading properly, then something may be bent or out of place in the threader.
May 15, 2016 | Bernina Sewing Machines
Bernina 830 Bobbin case does not swing out
Bernina 830 / 880 Bobbin Error and Bobbin Sensor ...
? 2:53
https://www.youtube.com/watch?v=RzpprWzYEJY
Dec 17, 2014 - Uploaded by Bernina Boys
What to do when your Bernina 830 or 880 bobbin shows a question mark. It also shows you how to ...
[PDF]Dear BERNINA 830 customer, Congratulation
Jan 01, 2016 | Bernina Sewing Machines
Why is the top thread on my 830 bernina bunching on the bottom?
The top thread has no tension or not enough. Check to make sure the top tension is going through the tension disc by giving a light pull when the foot is down. When the foot is up there shouldn't be resistance. Start at a setting of four and adjust as you need to.
Feb 20, 2015 | Bernina Sewing Machines
I have Bernina 830 embroidery machine. I'm still a novice with this machine. An upper thread broke and could only be removed from the right side. I know that this is a NO NO but I had no choice. I r
Do you have a manual?
http://www.ebay.com/sch/i.html?_from=R40&_sacat=0&_nkw=Bernina+830+manual&_sop=15
You may need some cleaning, oiling or maintenance?
Tips for cleaning and maintenance:
Oil the hook after having used the content of 3 to 4 bobbins. The machine
screen will display a reminder
Increasing noise of the motor and/or irregular
stitch formation can also be an indication that oiling is necessary
Remove any lint from the hook and the bobbin area, then remove the stitch plate
See instruction manual chapter Maintenance/Cleaning
YouTube videos:
https://www.youtube.com/watch?v=mlBNy33bd3U
https://www.youtube.com/watch?v=mV4z3EAyMz4 Bernina 830 or 880 Thread Nesting Troubleshooting
Feb 08, 2015 | Bernina Sewing Machines
How do i adjust thread tension
Depends on your Bernina model. Some of the older mechanical models (830 Record, etc), the thread will wrap around a tension knob which you can turn right to tighten or left to loosen. The newer mechanicals, the thread passes through a slot at the top of the machine which is the tension disk, but somewhere nearby there is a dial to increase or decrease the tension. The computerized models, the tension is adjustable on the screen.
Jul 06, 2014 | Bernina Sewing Machines
Top cover on my Bernina 830 is crooked
there are two screws on the top one by the bobbin winder and the other by the take up lever, you should be able to adjust it from there
Jul 07, 2009 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
