Question about Sony KDE-50XS955 50 in. Plasma HDTV
Pink Screen While watching TV, the screen goes pink. Turning TV off and on corrects problem but turning off and on the receiver or Direct TV doesn't correct problem.
    Master:
  • Sony Master
  • 687 Answers
Check all your cables & connections & connections at I/O ports; possibly I/O PCB
Posted on Nov 30, 2013
5 Suggested Answers
lebones337
  • 152 Answers
SOURCE: We were watching tv on
sounds like the lcd control board malfuntioned. call sony and im sure they will have you bring it to a repair shop at no charge
Posted on Jan 01, 2009
SOURCE: Sony TV KDL-32L4000 Turns Pink
My Sony tech says it's most likely a bad cable box. Try a DVD and if the DVD is fine then it's for sure your cable box. Needs to be replaced by the cable company.
Posted on Aug 10, 2009
  • 458 Answers
SOURCE: Why is my TV screen PINK?
Have heard of this issue,in most cases while using HDMI cable.Try switching to component cable hookup.(Red/Blue/Green RCA type plugs).This will still give you Hi-Def.(don't forget to get a Red/White cord set for the audio also,unless you get a 5-way cord that does both).
Posted on Jun 03, 2012
SD Tech
  • 14553 Answers
SOURCE: THE SCREEN IS BRIGHT PINK
Could be in the set but if using a cable or sat box unplug them and wait a while and plug back---I have seen a reboot of a box cure this issue.
SCREEN IS PINK AND NO SOUND..MENU SCREEN COMES UP IN CORRECT COLORS
How to Fix TV Pink Screen, Tech Tips 16 - YouTube
? 0:51
https://www.youtube.com/watch?v=84tyJ6A1frg
Apr 13, 2013 - Uploaded by Tampatec
Turning on and off the TV (not cable box) does recharge thescreen and the colors will properly disperse ...
Why is everything that was white now colored pink on my ...
www.makeuseof.com/.../why-is-everything-that-was-white-now-colored-...
Dec 15, 2015 | Televison & Video
All other input works fine e.g. dvd, TV went pink screen.
If other inputs show no problems and you are not using a cable box or satellite receiver, etc. just off air antenna, something on the main board is failing. please double check other inputs again.
Feb 17, 2014 | LG 32LC7D Television
Pn60e530 Samsung plasma tv when turning on screen flashes pink then goes black Sound is on no picture
screen drive on back of the screen has gone. they do over heat. the pink is the plasma lighting. replace the screen driver board and should be fine, when replacing put a bit of heat sinc on the top of the 2 or so chips big square ones on the board should help it last longer.
Sep 14, 2013 | Televison & Video
Pink screen on sumsung LCD
Likely to be a bad main board that processes all signal and controls the display panel for tuner and all inputs---other possible boards not likely as they do not know when a DVD etc is being played or not.
Not out of the realm of being possible is a bad connection or loose plug to or from the main board---especially look for any that are secured or held down with tape where they plug into that board.
May 30, 2012 | Televison & Video
Have a jensen linear phase car receiver , there is a light pink wire coming out of it what is it for ?
The pink wire is the safety wire so that you can not watch the screen (during a video) unless your car is in park. You can either connect it to a ground or completely bypass it by typing the code 543210 in the menu screen and turning the safety feature off.
Dec 12, 2009 | Jensen's VM9312 Car DVD Player
Sony kf50we610 hd pink stripes
That's a good one!
If you're using component video cables, make sure they are good and tight. If it's composite video or S-video inputs, you will likely need service.
Sep 12, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Pink screen
Anything is fixable just a matter of cost or availability of parts.
Jul 24, 2008 | Panasonic CT-27SL15 27" TV
Pink screen or scambled picture when turning on tv to watch dvd
I have seen several LG plasma that have a pink picture and everytime it has been a failed control pwb. This bd is located under the assembly that houses the main digital bd. The main dig. bd is the one with all of the inputs.
Feb 08, 2008 | LG 42PC3DV 42 in. Plasma EDTV
Screen turning pink
If the pink overlay goes away gradually, you could have weak picture tubes (CRT's) If the color jumps in after warming up, it could be a bad solder connection. If you haven't had a good picture to watch for a long time, I would be tempted to put the money towards a new HDTV set as those older Mitsubishi Rear Projection TV's had a Lot of bad solder connections in the past, and by fixing one problem another could crop up in the near future.
Apr 12, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Sony KDE-50XS955 50 in. Plasma HDTV Logo
155 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
