Question about Amana AFD2535DES French Door Refrigerator
Amana French Door Refrigerator, model AFD2535DES - doors not sealing tightly - door pops open when other door closes.
Can the door seals be replaced? Our Sears maintenance repair man told us there was nothing that could be done.
  • 21 Answers
Unfortunately he may be right. however, There are a couple things you can check. Is it built-in, meaning... do you have cabinets, directly above? Impeding, being able to raise the front of the unit, so that it can "tilt" towards the rear? Do you follow me? Make sure the doors have jars, bottles, whatever... the weight helps.. Down on the floor, the fronts usually have adjustments, allowing this feature for the purpose in mind..
check too, there are no obstructions.. meaning the drawers aren't in any way coming in contact (where even slightly could intrude.) check foods or containers do pass beyond the edges of the shelves. If I recall, 5-7 lbs of outward pressure, is required by law, to enable the doors of any unit to open.
Check the gaskets on the hinge sides, they should be resting Flat, (the same way the top rests, against the metel surface when t he door is closed. )
Posted on Nov 29, 2013
4 Suggested Answers
  • 116 Answers
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Posted on Mar 11, 2007
  • 6 Answers
SOURCE: Amana 22 side-by-side refrigerator, freezer door opens slightly
There are three possibilities to this problem:
1. Door seal which should be magnetic is faulty.
2. Ice maker caddy (container) has not socketed properly into ice maker rear drive tang.
3. Door stay closed plastic hing pieces are damaged. These are tapered pieces that fit in hinge area that allow door weight to help close and hold door. Some are black in color and some are white. As far as I know they are interchangeable.
Posted on Jan 01, 2009
SOURCE: Amana ARB2117BW - Bottom Freezer Door Won't Stay Sealed
This problem was posted in the wrong section. My model didn't have it's own, so its in ABB1927DE Bottom Freezer Refrigerator - perhaps you could create a section for it.
As it turns out, I looked more closely at the baskets inside. We had noticed that if the top basket was slid all the way forward when we closed the door that it would close better. So I looked to see if they or the slides were out of alignment. They seemed ok, but then I saw that the way the bottom basket was hanging didn't seem right - it was not quite nestled into it's retainer slot. I took the baskets out and turned the bottom one around. It fit perfectly into it's retainer slot. I then replaced the top one (it was already in correctly) and closed the door. It sealed correctly the first time. I tested it several times after that and it sealed tightly. Closing the top door did not make it unseal as it had done before.
Posted on Jan 23, 2009
LG french door refrigerator does not keep food cold. Left door pops doesn't stay tightly closed.
What do you mean by "pops"? If your problem is the door, then it is possibly leaking out your cold air. It could be the seal or the hinge.
Aug 11, 2014 | LG LRFD22850 Bottom Freezer Refrigerator...
Left door of the refer isn't closing properly, must manually feed it thru the little channel at the top for it to fold in and close
check the door hinges a in place:
The door latch and lower hinge pin should hold your refrigerator door in place..
Uncover the door by removing the screws.Take the door off and pack bottom hinge with washers and make sure hinge brackets on cabinet are tight.
Check the seal is clean and pliable:
If seal is gapping, one solution is to warm with a hairdryer and pull outwards gently.
Check the refrigerator is properly leveled:
Adjust the middle hinge to straighten the lower portion of the door. Use a level to ensure the door is flush.
After fitting the door back again,check to see if the seal is touching on all sides when the door is closed. If not, you will need a new seal.Refrigerator is properly leveled.and hinges should be properly placed.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Sep 06, 2010 | Amana AFD2535DES French Door Refrigerator
Freezer freezes but refridegator is warm on amana french door refrigerator.
it could be a defective damper vent door,( frozen shut from condensation) between the freezer and refrigerator,the motor that opens and closes this door,or a thermistor in the refrigerator that signals the control board in the rear of the unit to operate the damper vent door motor to open and close this door
Jul 28, 2010 | Amana AFD2535DES French Door Refrigerator
Just starting not keeping things cold
If there is frost on the wall of freezer, you have a defrost problem, and not enough air is circulated due to frost build-up. If no frost and all fans and compressor is running, you have a sealed system failure. Time to replace refrig.
Jul 02, 2010 | Amana AFD2535DES French Door Refrigerator
Freezer door pops open when fridge door is closed.
well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
May 26, 2009 | Amana ARSE66MB Side by Side Refrigerator
Amana side-by-side refrigerator/freezer
raise the front legs/rollers so unit is tipped back slightly.its ok if it opens as long as it closes.
Aug 07, 2008 | Amana SCRATCH&DENT 25 Cu. Ft. French Doors...
Door Pops Open
check the alignment of the doors. their is an adjustment on the top hinge. also the hinges have washers on them that you can adjust the door up and down by moving washers to the hinge under or over the door.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 12, 2008 | Amana AFD2535DES French Door Refrigerator
Refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
Nov 16, 2007 | Amana AFD2535DES French Door Refrigerator
Amana AFD2535DES French Door Refrigerator Logo
73 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
