Question about Samsung SCX5639FR Printer
Initializing all the time - Samsung SCX5639FR Printer
After initial set up and download, TV is displaying a hand on power plug picture with a red circle and line through it and a refresh symbol in light blue next to it, what does this mean?
Hi! and Welcome to Fixya!
What you have on the tv screen is a warning sign that your tv is currently updating its software. A hand holding a power plug with red circle on it says do not unplug the tv while its running the software update. The usual time for the update to finish is 60 minutes. It may took more than 60 minutes if you have a slow internet speed. This is normal especially if you are running the software update for the first time during the initial setup. The next time tv performs software updates it will take shorter time.
However, if the updates took more than two hours, the tv may be frozen. You can unplug and plug it back in and start from the initial setup again.
On some rare occasion, the tv may not proceed with the initial setup. You may have to turn off your modem to complete the initial setup. when initial setup is done, connect your tv to network and run software update again.
Let me know if you still have other questions.
Sep 07, 2015 | Sony BRAVIA KDL-55W802A 55" 3D 1080p...
How long do you charge the cxt195 radios for the first time for the initial charge and after the first charge what about the next charge time is at same time frame
The initial charge time varies but overnight is generally recommended. Afterwards, the charge time is considerably less.
Dec 25, 2014 | Radio Communications
Each time I attempt to initialize a zip disk in my Roland BR8...
Probably the drive has gone bad as a first thought... this happens. Possibly the heads got dirty...
Make sure nobody has smoked tobacco around the unit as that is a killer for Zip drives.
Sometimes they have a second level of initializing/formatting. If the BR* has that, try it.
Jan 25, 2010 | Boss Music
Why does my GPS system have a difficult time locating satellites?It says ''acquiring satellites'' for about 5 minutes. Then it says it can't locate satellites. Should it continue trying? Why does it do...
this is what my navigon says about gettting the gps to connect.
Initializing the GPS receiver
In the upper right-hand corner of the display, the GPS symbol appears. As soon as
data from at least 3 satellites is received, the symbol changes to (GPS Ready). Note: If possible, position the device with a clear line of sight to the sky to successfully
receive messages from the GPS satellites.
Note: GPS initialization requires data from at least three satellites. If GPS data is not
available, the receiver will not initialize.
Note: It can take up to 20 minutes to initialize the integrated GPS receiver for the first
time.
Note: Each time you turn on the device, GPS receiver initialization begins. When GPS
data is available, reception starts within one minute.
If the navigation device has been switched to standby for more than a week, the next initialization
can take up to 10 minutes.
Jun 19, 2009 | Garmin GPS
Changing the time on my Motorola Razr V3 phone
you must first disable Autoupdate (turn it off) - go to settings>scroll to Initial Setup, (select this)>Time & Date (select this)>Autoupdate (set to OFF)>after you do this option will appear to change time to 12/24 hour....
May 11, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Go to settings
--> Initial Setup
--> Time and date
--> Auto update off
Then you will find the time and date.
go to date use right soft key and change the date and similarly for the time.
Jul 28, 2008 | Motorola Mobility RAZR V3
How to initialize
Push Menu switch, go to Set-up and select Set-up1 and downwards there is option Initialize. select it and press Yes. Camera will go to power Off and On itself. Date n time adjust option will come and adjust current date n time and have fun. :D
May 30, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
I do not know how to set my clock on my razr after the time change last nite
Settings
Initial Setup
Time and date
  • Turn AutoUpdate Off
select and make the change
Nov 04, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Samsung SCX5639FR Printer Logo
18 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
