Question about Arietta 30 in. Wall Mount Decorative Range Hood Dekor Glass 30
Fan switch turns on by self - Arietta 30 in. Wall Mount Decorative Range Hood Dekor Glass 30
Ok i have a 2004 chevy monte carlo i have a weird problem i know its a pain to get it on how about off i have keys out fuse out and my ac/heater is still goin i cant turn it off tell i disconnect the fan...
I DONT THERE IS ANYTHING WRONG WITH YO FAN NOR FUSE BUT THE SWITCH, AC FAN SPEED CONTROL UNIT AND MAY B THE HARNESS TOWARDS THE AC BLOWER FAN.
NGOSA L. K.
Mar 02, 2014 | Cars & Trucks
Fault finding
HEATING AND AIR CONDITIONING
HONDA CIVIC 2001 - 2005
How to retrieve DTC:
The heater control panel has self-diagnosis function. To run the self-diagnosis function, do the following:
    1.Turn the blower fan OFF.
    2.Press and hold the recirculation control switch and the rear window defogger switch down.
    3.Turn the ignition switch ON (ll).
    4.Release both switches. The recirculation indicator and the rear window defogger indicators come on. The recirculation indicator goes off 3 seconds later and the A/C indicator comes on, then the self-diagnosis will begin. About 10 seconds later, the self-diagnosis will finish and the A/C indicator goes off.
    If any trouble is found, the recirculation indicator blinks the diagnostic trouble code (DTC) to indicate a faulty circuit or component.
    If the system is ok, the recirculation indicator stays off.
Aug 19, 2013 | Honda Civic Cars & Trucks
99 Tahoe blower works sometimes when it quits there is no power to switches at the controls it may turn on going down the road bt it's self is this a switch problem?
take a look at the connector that feeds the resister that mounts next to the fan under the dash below the glove box the connectors over heat and become loose making the connection fail
Jun 24, 2012 | 1996 Chevrolet Tahoe
1989 cougar heater or ac wont blow air what could be the problem
Its either the fan switch is bad,,or a fuse,,or the fan motor its self is bad,I would check fuse 1st,,2nd unplug fan motor run a hotwire to it and see if it turns,,if it does than you know its the switch for the fan. If it dont turn with separate hot wire ,,than its the fan go bad.
Mar 07, 2011 | 1989 Mercury Cougar
I have a 75000 btu garage heater ,20 years old, The Fan stoped turning on and I replaced both the switches that turns the fan on by the heat exchanger and the shut off switch.It still will not turn the...
The high limit switch is shutting down too soon (too low of a temperature) or the fan on switch is not turning on at a high enough temperature...are they in backwards??? Even though the switches work they are not turning on and off at the right temps... so they may be out of calibration....
heatman101
Feb 10, 2011 | Heating & Cooling
1993 eldorado coolling fan not comming on, it is a 8 cyl, is there a fuse or relay switch?
yes there are fuses a relay and a censor all must work to turn the fan on also check that the fan its self is free to turn it could be sezed up or burnt out
Jun 27, 2010 | Cadillac Eldorado Cars & Trucks
Sony lcd projection tv in self diagnosis mode. 4 red flashes
This is a fan error take the back off the set and see if the fan is turning.
Sep 13, 2009 | Televison & Video
Power supply pull switch is broken
Just about any hardware store will have a replacement switch for your fan.They are a standard piece of equipment.You don't mention if it is the switch that controls the light,or the one that controls the fan.The light switch is a simple on off switch.The fan switch could be a simple on off switch or could have variable speeds.It may have an off position,and may not.You can tell if it is variable speed or not by looking at it.It will have more than two leads.You can decide for your self if you want an off position or not.For instance if you want to turn the fan off,and on from a wall switch you may not want an off position on the fans pull chain.
Jun 05, 2009 | Heritage (5BUW52WZ4HN) 52'' Ceiling Fan
A/C won't work 03 Acura RSX
General Troubleshooting Information
How to Retrieve a DTC
The Climate Control Unit has a self-diagnosis function. To run the self-diagnosis function, do the following:
1. Turn the ignition switch OFF.
2. Tu rn the fan switch OFF, the temperature control dial to MaxCool (60.F or 18.C), and the mode control dial to Vent.
3, Turn the ignition switch ON (ll),then press and hold the recirculation control switch. Within lO seconds while holding the switch down, press the rear window defogger switch five times. The recirculation indicator blinks two times and the A/C indicator comes on, then the self-diagnosis will begin. About 15 seconds later, the self diagnosis will finish and the Ay'C indicator goes off. lf there is any problem in the system after finished self diagnosis, the recirculation indicator will blink the Diagnostic Trouble Code (DTC) 1 through 13. When problems in the evaporator temperature sensor circuit are detected (codes 14 and t5), the A/C indicator will blink the DTC. lf no DTCs are found. the indicator will not blink.
d35f123.jpg 695f305.jpg5d11822.jpg Resetting the Self-diagnosis Function
Turn the ignition switch OFF to cancel the self-diagnosis function. After completing repair work, run the self-diagnosis function again to make sure that there are no other malfunctions.
Jan 13, 2009 | 2006 Acura RSX
Arietta 30 in. Wall Mount Decorative Range Hood Dekor Glass 30 Logo
64 people viewed this question
Top Arietta Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you an Arietta Kitchen Range Expert? Answer questions, earn points and help others
