I have a T2642 desktop (Win XP) with wireless Broadband. I added a home network with a Linksys router. Two laptops are connected wirelessly. Suddenly the Linksys files disappeared and the T2642 no longer recognized it had an Ethernet port (not listed in Device Manager but driver still found in LAN folder). The port still lights up when the cable is plugged in. I downloaded the driver and overwrote in the LAN folder but no change. I tried the repair function in the driver software but it instructs to restart computer and install PCI card. I tried to install another port in an open PCI slot but it froze the computer (nothing on the monitor). I think there may be a compatibility problem there. Any suggestions?
I'm not sure what clarification you are asking for. I understand that the card that came with the computer might be faulty. I suppose even with the light coming on with the cable inserted that that means it has power, not that it is working properly. I tried to insert a new port (10/100 network card--the brand was Network Everywhere)in an empty PCI slot without success. With this new card in nothing worked. As soon as I removed it the computer was again able to boot up.
It's a wireless router, so you may not need to use a port at all.
You can connect to any of the ports numbered 1 through 4. The yellow Internet port should connect to your outside network. (Cable modem or router or Ethernet port from your Internet service provider.)
The Linksys G router gives you both wired and wireless connections over a broadband Internet connect to create a local area network. The Linksys router is compatible with wireless G and B devices, through the 2.4-GHz wireless band. The wireless speed is at 54 megabytes per second and you can get 100 megabytes per second with a wired connection. You have to set up the wireless configuration on the Linksys before using it on your network.
Plug the router's power cable into an electrical outlet. Attach an Ethernet cable into the Internet port on the back of the router. Connect the other end into your broadband modem. Connect your computer to the Linksys G using another Ethernet cable. This Ethernet cable can go into any of the wired router ports. Open your Internet browser. Type "192.168.1.1" in the address bar and hit "Enter." This is your router's IP address and the home of its Web configuration page. Click "Wireless." Click "Manual." Alter your SSID, also known as your network name. You can change this name to any value that you want. You can also change the wireless channel if you are in an area with many wireless connections that may interfere. Click "Save Changes." Click "Wireless Security." Choose an encryption method to encrypt your wireless transmissions. WPA or WPA2 are common security protocols you can use in wireless networks. Input a network key, also known as the network password. Click "Save Changes."
That's all you need to get your wireless internet up and running. However, in order to connect computers to the wireless network, they must be wireless capable, for example, most laptops have built in wifi, however desktops will need a wireless adapter to take advantage of your wireless router.
Use an Ethernet cable to connect a computer (desktop/laptop) to one of the "wired' ports on the router.
Connect to the built-in web-server "inside" the router.
Run the "Wireless Networking Setup Wizard", to configure the wireless capabilities of the router; assign an SSID, and assign a password for the wireless network.
> Try changing and creating a new wireless network name.
> Try changing your security mode like WEP to WPA or vice versa..
> Try to update you drivers on your laptop then restart your computer before connecting to your network..
> Try assinging DNS ( Domain Name Server.) ask your router manufacture for the DNS that you could use.
> Make sure you typing the correct password for your wireless network..
> Make sure you disable WI-FI protected setup and on the router.
> Try to disable Anti-virus and Firewalls on you laptop.
run the telephone line from your modem into the wall jack. From the modem connect a network cable (cat5) into the back ( via the uplink port) of your linksys router . Your router can now route the IP from the modem.
You say "your Ethernet Port" (= LAN port) If unavailable try using any USB to rj45 adapter and you can use any USP port. Check this device:Linksys - USB200M - Compact USB 2.0 10/100 Network Adapter (20 $?) or similar
You can still use your existing Linksys router with your cable modem. In fact the router your have is designed to work with DSL/Cable Broadband connections.
1. Make sure to properly connec the devices in your network. Modem will be connected to the Internet port of the router. Then, laptop will be connected to one of the 4 Ethernet ports of the router. For initial setup of your router with modem, you need to hardwire laptop to the router.
2. Press and hold reset at the back of the router for about 15 seconds.
3. After 15 seconds turn off the router and then turn off the modem. Wait for a minute.
4. Power on modem and wait for the lights to be ready.
5. When modem lights are on, turn on router.
6. There should be 4 lights on. Power should be steady green. Internet, WLAN and Ethernet port.
7. Checked if you have Internet connectivity on your laptop while it is wired to the router.
8. If Internet is working, disconnect laptop from wired connection to the router and check available wireless network that laptop can detect.
9. The default wireless network name that the Linksys router broadcasts is "linksys". Connect to it which is an unsecured wireless network.
10. Once you are successfully connected, check Internet.
the blue and jellow ethernet cord is the same thing.
Make sure you have wireless switch on (enabled) on the laptop
If you have wireless enabled, it should say one or more wireless networks detected in windows xp. Also, if you have a certain router, you might need a code to unlock it so you can use it.
I may be able to help with this...but I need a detailed description of how you have things connected between the XP desktop, the cable, modem, the Linksys router, and the laptop. Also, is the Linksys router new?
Typically, the wan port on the wireless router connects directly to the cable modem with a cat5 network cable....then the desktop pc connects to the router...on port 1 for example...with a similar cable. Once the wireless router is set up properly, the laptop should then be able to connect using wireless.
The LAN card is possibly faulty.
