Question about Cameras
When trying to power up hear 3 beeps and camera turns off.
When pushing the power buttom camera trys to turn on and then hear 3 beeps and camera turns off. New batteries have been installed.
    Problem Solver:
  • 9 Answers
Make sure the batteries are good and in right. If it keeps doing it you might be having a problem with your lens opening up and staying open, I had a camera that did that to me, and the lens had been knock and wouldnt open properly, check that out. The lens was out of range from normal and would automatically shut down
Posted on May 09, 2009
Will not turn on.battery tested and was fine.
Bad push buttom, or something inside the buttom, like any cola or kool aid between the push buttom.
Try to check if the push power buttom it´s working.
Dec 07, 2015 | Cameras
Need to fix problems with 5104 viper remote
It is possible that you need to reprogram the remote.
1st you need to enter the remote into programming... Hold the Function button until the remote gives a long beep and LED light comes on the remote a (it takes about 8 sec.) Then press and hold the remote start buttom until the remote beeps 3 times and LED lights up. Now your ready to program the remote
One of the door has to be open . Insert the key - turn the key to the On position then press the button on the antenna once and then press it again and hold it
You hear a chirp and then you press the lock button on the remote and then you hear a second chirp to receive confirmation and then release the button and the turn off the key .
Remote should be program
Jan 21, 2013 | Viper Televison & Video
I turn on my ps3 and the green light comes on for a short time and the it beeps three times shuts off and the green light turns red and starts to flash. If I push the power button again the red Light
you need to change your power box there is a bad connection with the wires. its over heating you might whant to buy another at game stop or take it in to get fixed. the more you messed with it it might mess up your whole system.
Aug 18, 2012 | Sony Playstation 3 (PS3) Console
Reset photoconductor units aficio 410dn
www.ricohpr.com/.../Ricoh%20Aficio%20SP%20C410DN%20LTR%20%5B34245%5D... -
in order to reach the Ricoh restore factory menu, you need following steps.
1. push the yellow small "C" buttom. you can hear beep.
2. push the 3 numeric buttoms, in following order: 1,0, 7 .
3. push the big red "C" buttom, don't release for 5 minutes until you saw a copy windows popup on the screen.
choose the "copy sp", then trun off the power, and turn it on again.
now done, you have reseted the factory settings for the Ricoh Aficio munti-functional copier;printer.
If you really need the actual "Chip" then you will have to get a Service manual, inside there are circuit diagrams and circuit details.
May 06, 2010 | Ricoh Aficio SP C410DN Laser Printer
I turn on my ps3 and the green light comes on for a short time and the it beeps three times shuts off and the green light turns red and starts to flash. If I push the power button again the red light stops...
this happens when the ps3 has overheated-try removing the hard drive and replacing then give the console a hoover out.....if this doesnt work try holding the power button on for 5 sec....if this doesnt work its back to sony im affraid
Mar 16, 2010 | Sony Playstation 3 (PS3) Console
I cannot turn my camera on.
If The Lens Is All The Way Out And Wont Go Bak In Thats Why The Camera Wont Turn On Not The Other Way Around. Try Very Gently Turning The Lens And Turning The Camera On At The Same Time Till U Hear A Click That Should Do The Trick.
Feb 09, 2010 | Samsung SL420 Digital Camera
My samsung l830 camera lens is stuck open and when i press the power button it beeps 3 times and remains blue then does nothing
If the lens on the camera is stuck out, look to see if it's a little crooked. If it is, try to gently straighten it. If it still won't retract, try to gently push it in as you turn the power on.
If it won't turn on (the green light blinks and it beeps 3 times) push and hold the 'power' button and the 'play' button at the same time for a few seconds - it worked for my S730. Good luck!
Jun 28, 2009 | Samsung Digimax L830 Digital Camera
Hi when i turn on my ps3 corrupt data comes up on screen and when my ps3 trys to fix the problem it just goes back to the start again i cant even get into the main menu its 2 years old was kept like new i...
1. Plug in controller
2. Have system in standby mode (red light)
3. Hold down power button for a full cycle (will turn on and back off again)
4. Hold power button again will hear 2 single beeps then a double beep.
5. As soon as you hear the double beep immediately remove your finger from the power button.
6. Hit the PS button on controller when it tells you to
7. Go to ONLY option 3 (restore)
8. WARNING: select any other option and you can wipe out everything ONLY USE OPTION 3
9. Follow on screen prompts
Try this and get back with me, I will look into it for you.
Mar 15, 2009 | Sony Playstation 3 (PS3) Console
Will not turn on
My guess is that your camera has been dropped recently and that the beeping is a result of the lens not extended when powered on. My Mother-in-Law has the same camera exhibiting the same symptoms. I've been able to get it to turn on by slightly pulling on the lens prior to turning it on. One of the plastic gears inside is probably damaged.
Aug 19, 2007 | Samsung Digimax S500 Digital Camera
Cameras Logo
252 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
