Question about Canon PowerShot G10 Digital Camera
Lens error in a Canon G10
When I turn on my canon G10 it always appears lens error message.
  • Leonor Hern?ndez
    Leonor Hern?ndez Dec 13, 2012
    thanks a lot for the information. My camera was on garanty, so I send it to the seller. Finally it needs a lens replacement. Now it works ok...
  • 5 Answers
Try restarting it a couple of times. If that doesn't make the error go away, the camera needs to be serviced. There is a really good site and all they service are Powershots. They are wonderful if you need to get service for one of these Canon Powershot cameras and they are really reasonable for the cost. Your problem is on their site. Try going to: www.camerasandparts.com Look at their service and repair and you should see it there. They are amazing for service on these models. I wish you a lot of luck with it, that's a really great camera.
Posted on Aug 10, 2011
  • 5 Answers
You can get it fixed here www.camerasandparts.com They just service the Canons and that's where a lot of people go for help with these cameras. It's $89 there for the parts / labor and servicing for the camera included, plus they cover the return shipping with their service packages. That's where a lot of people go for help with these Canons. Work quality is superior through them.
Posted on Jul 11, 2012
    Problem Solver:
  • 8 Answers
Camera anti-shake is broken, It can be fixed,Replacement Canon PowerShot G10 Battery ....
Posted on Jan 13, 2012
  • Canon Master
  • 4,738 Answers
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on May 10, 2009
The best telephoto lens for this camera?
Canon G10 - Ken Rockwell
www.kenrockwell.com/canon/g10.htm
Oct 20, 2008 - The Canon G10 is the best compact digital camera I've ever used, ...The G10 is a regular Canon Powershot point-and-shoot, in a tough ..... On the G10 theISO dial moves under the mode dial to make room for ... Neither the G10 or G9 have true zoom lenses; they only change focal length in discreet steps.
Canon PowerShot G10 Review ' Digital Camera Resource ...
www.dcresource.com/reviews/canon/powershot_g10-review/
Nov 24, 2008 - Is the PowerShot G10 the ultimate compact camera? ... Telephoto lens, TC-DC58D, From $109, Boosts focal range by a factor of 1.4X, ..... For bestresults, you'll want to attach one of the Canon Speedlites I mentioned back in ...
Jan 01, 2016 | Canon PowerShot G10 Digital Camera
Canon g10
No. The LA-DC58K only allows you to use the TC-DC58K teleconverter with your camera.
The Tamron 28-200mm lens is intended for use with SLR (single-lens reflex) cameras, not with point&shoot cameras. As far as I know, there aren't any adapters which will allow you to use an SLR lens with the G10.
A teleconverter is an add-on accessory that works with an existing lens. The 28-200 is a lens, which is intended to be used as-is. Using it on the G10 would basically require removing the built-in lens on the G10. As that lens can't be removed...
Jan 05, 2014 | Tamron Cameras
Cambron 500mm
I think you don't want to use it on the G10, because that would not be possible. You first have to know what the connection side of the Cambron lens is, than look on every site that has adopter rings for Canon EOS or Rebel cameras. Like the link down here.
link to ebay adopter rings
Nov 22, 2013 | Canon Conversion Lens Adapter LADC58K 22x...
Err 99 message on canon 450d
CANON ERROR 99 1. Turn off the camera. 2. Remove the lens, battery, and CF card. 3. Allow the camera to sit without power for approximately 20 minutes. 4. Insert a fully charged battery, and turn on the camera. 5. Depress the shutter button as you would to take a picture. Does the "ERR 99' message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps: 1. Turn off the camera. 2. Insert the CF card. 3. Turn on the camera. 4. Format the CF card in the camera. 5. Depress the shutter button as you would to take a picture. Does the "ERR 99' message appear? If so, then the CF card is the most likely source of the issue. Try using a different card. If the message does not appear, please complete the following steps: 1. Turn off the camera. 2. Clean the lens contacts by gently rubbing them with a pencil eraser or soft cloth. Be careful that you do not let any debris fall into the camera body. 3. Reattach your lens. 4. Turn on the camera. 5. Depress the shutter button as you would to take a picture. If the "ERR 99' message only appears when one particular lens is attached, then that lens should be examined by a service technician. If you see the "ERR 99' with a different Canon lens attached, then the camera should be serviced. http://www.youtube.com/watch?v=WkXyLieNUDI - - - - - VIDEO & VOICE INSTRUSTION. Error 99
Aug 12, 2012 | Canon Cameras
Shooting is not possible, turn the power switch to off and on or reinstall the battery
Hi there :the Error 99 is a comunication error between camera body and lens .are you using Canon lens?Try the camera body with a/another Canon lens in Camera body and try the lens on another Canon camera.With this troubleshoting you can know if the camera body is failing or lens is failing.I hope this information will help you.
Nov 29, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
How to restart canon g 10 when a error lens?
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101
Aug 14, 2011 | Canon PowerShot G10 Digital Camera
Canon g10 lens error.. lens fully extended then won't take a photo.. then the lens error appeared
Causes of a Lens Error: There are a number of ways with which a lens error can be caused. Particulates might have managed to get into the mechanical bits that allow the lens to retract, a purely physical interference with the lens mechanism. If the camera was dropped, especially while the lens was extended, there's a pretty good chance something might have been knocked loose, such as the guide pins upon which the lens withdraws and retracts.
How to Repair a Lens Error: As scary as a lens error might seem, there are some easy fixes. Before trying any of them out, however, first take a good long look at your camera warranty and maybe have a chat with the company. If the lens error will be covered under the terms of the warranty, go for it. Even some of the simple fixes mentioned below might void the camera warranty. Frankly, however, it's unlikely that a lens error will qualify for the warranty.
Try just some basic things first-just to make sure it's actually the lens that's broken. Replace the batteries with fresh ones. Failing that, replace the memory card.
Additional details could find in this article link: fixing-lens-error-on-digital-camera.html
Keep us updated.
May 26, 2011 | Canon PowerShot G10 Digital Camera
Caqnon G10 shuts off when zooming with an adaptor tube
Yes...the Canon brand is made to work properly with the camera.
Jul 23, 2010 | Canon PowerShot G10 Digital Camera
LENS ERROR, RESTART CAMERA...
CANON IXUS 561
Lens sometimes does not extend and error message 'lens error restart camera' appears when camera is turned on. This does not work without several tries and much button pressing. Problem is not caused by finger(s) in front of lens barrel.
May 20, 2010 | Canon PowerShot A560 Digital Camera
Canon PowerShot G10 Digital Camera Logo
2,935 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
