Question about Uniden TCX905 Cordless Accessory Handset and Charger Phone
Line 2 not working
Line 2 on phone does not work - no sound... switched line 1 and 2 and it does work - so it is the line 2 on the phone - any suggestions?
    Genius:
  • 1,198 Answers
Do you actually have two lines to the room? Check to make sure all phone cords have four contacts.
Posted on Nov 29, 2013
SOURCE: base unit line 1 is flashing no dial tone
We followed your instructions and are not sure what worked, however, this AM phone line is working.
Posted on Sep 30, 2008
SOURCE: Single Line Cordless Phone with two mailboxes
There are a number of VTech 1-line phones with 3 mailboxes.
Posted on Dec 28, 2008
divatif
  • 39 Answers
SOURCE: No dial tone, just buzzing noise - should be 2 line phone, 1 jack
What you need is a dsl filter since you are working off a splitter. You can usually get these for free from your phone company.
Posted on Mar 20, 2009
cshannon1077
  • 14 Answers
SOURCE: DCT 646
If you have a phone that works off a broadband modem, that is a VoIP phone. That will not work with a home phone line. I'm assuming Verizon is your local Telephone carrier that provides your local dial tone.
The broadband modem would have the phone number of whatever VoIP phone service you have.
Posted on Apr 10, 2009
  • 205 Answers
SOURCE: phone cannot find base
complite opening phone re connection remove safty try it
Posted on Jul 09, 2009
I got msg "check operator
Go to your phone settings and locate (line 1/ Line 2) function...switch the Line 2 to Line 1 then ok....now turn phone of and on an try it...
(if this doesn't work the first time ...change line 1 to Line 2.)
this will stop the problem..
www.joestechreview.ning.com
May 12, 2011 | Apple iPhone 3G Black Smartphone
Line connection
try this;
press sp-phone enter *71029, then enter the outside number, then #, you will hear a tone that means call forwarding is activated.
to cancel press sp-phone *7100# or simply dial 790 for extension data clear
Aug 07, 2008 | Panasonic KX-T7630 Corded Phone
Good Morning! I work for a small business that has 5 of the GE 2-9451 4 line phones with intercom. We were actually running two businesses out of the same office originally. Line 1 would ring in to...
Since you said line 3 was working for #2 company, i will suggest you put the line 3 back from where you removed it from. From the look of things the line might be the only line connected to be functioning. When ever you want to switch line since it is with intercom you will need to switch both side from where it is connected to where it is connected to, so that network connection can be achieved.
And on the other hand, the other line might not be working properly, that is why it was not connected or used.
Take care.
Apr 08, 2010 | GE RCA 4-Line Speakerphone
Problems with line 2 not connecting properly
I have encountered similar problems connecting equipment to two lines. Open the terminal block so you can see the wire connections. Line 1 should be red and green wires; line two should be yellow and black wire. If your installation is new, you may see WHT/ORG and ORG/WHT and WHT/BLU and BLU/WHT wires or some other combination selected by the telco technician on a whim. The color combination could even be reversed or one side of line one could be connected to one side of line two - a typical "Monday morning" installation. If you make sure the line wiring is correct everything should be working correctly.
Mar 29, 2017 | RCA ViSYS 2-Line Speakerphone
Meridian M7208 Phone-Only 2 lines are working
Sounds like it might be a telco problem. Do lines 3 ,4 work on the other phones?
Switch lines 1 and 3 to see if the problem changes.
Apr 22, 2009 | Nortel Meridian M7208 Corded Phone
Line 4 doesn't ring in coming call
The way 4 line phones work is that you need 4 lines on every jack that is connected to your phone.
You see the light probably because one of the phones has line conected and you see line appearance.
Mar 20, 2009 | Nortel Lands Phones
Philips voip 841: no sound on skype calls, but fixed line works f
We have had this issue recently as well with both our parents and now our own.phone.
Simple solve I found here:
1. Remove batterys
2. unplug base
3. replug in base
4. Put batteries back in
Worked for us - must be a virus or something
Feb 16, 2009 | Philips VOIP8411B/37 IP Phone
Suddenly line 2 only works on wired phones
Here are a couple of things to try. First is to disconnect the base and install a regular two line phone to verify that line 2 is ok at that jack. Also on Panasonics website, when you unboxed and installed that unit, there was a cord that had green plugs on it. That was a 4 conductor cord. If somebody changed that out to a 2 conductor, it could cause this. Also it could be a defective cord. If you have another 4 conducter cord from the wired phones, swap it out. Make sure on the base, on the back, that it is plugged in to the correct plug, marked line 1/2. Basically if a regular 2 line phone works, it is possible that the unit is defective. Also maybe unplugging the base from power and resetting that may fix it also.
If that does not help here is Panasonics number.
1-800-211-PANA(7262)
Jan 05, 2009 | Panasonic KX-TG2740 Cordless Phone
Wires from the wall are 2(orange/white), 2(blue/white) 2(white/orange and 2(white/blue) my phone outlet which is wired has 1(black), 1(blue), 1(yellow) and 1(black. How are my wall wires to be attached...
Take a look at this image:
0d5b58e.jpg Notice that the Line 1 will typically present on pins 3&4 and Line 2 on 2&5. I would think in your case Black/Blue is Line 1 (3&4) and Yellow/Black is Line 2 (2&5).
If you have a 1 line phone and only have 1 line active, then typically blue and blue/white can be connected to the Blue and Black of your Jack. If this doesn't work, switch with the Yellow and Black.
Please let me know if you have further questions. Good Luck!
Aug 11, 2008 | Lands Phones
Phone connection for Lucent 854
You can get a splitter for it which will then divide that one phone jack into 3 out or 4 out which ever you need. the only problem that you might run into is how close the phones might be to each other. Otherwise there isn't much other ways around it with only one phone jack.
Mar 31, 2008 | Lands Phones
Uniden TCX905 Cordless Accessory Handset and Charger Phone Logo
49 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
