Question about Pool & Spa
When turn on pool pump there is a loud vibrating noise coming from the Heater flow valve
The loud humming noise gets louder at higher RPMs and it happens without the heater being on
  • 2,113 Answers
Is it possible that the flow valve was put on backwards?
Posted on Nov 28, 2013
  • 61 Answers
SOURCE: Pool heater will not turn on.
It means that there is no pressure in the pipes to indicate flow. Make sure that water is flowing, and if there is a bypass on the heater make sure valves are in the correct position to allow water to flow through the heater. If you are CERTAIN that water is flowing through the heater, and the LCD still says no flow, you probably have a faulty pressure switch inside the heater, which is the most common problem with pool heaters. To confirm you will need to remove the wires from the pressure switch and short them together with another piece of wire. If it still says no flow you may have a bad board, but 99.9999% of the time it is the pressure switch.
Posted on Apr 11, 2009
  • 4 Answers
SOURCE: hayward pool heater h series
the issue is a broken baffle in the system. there is a baffel that directs water into the heat exchanger and back out into the system. The welds that hold the baffel in place have broken off. It can be repaired if you take the unit to someone with a mig welder and have them re-weld it (muffler shop, mechanic?). there needs to be a weld on both sides. You can see the baffel if you remove the unit and look down the inlet and outlet tubes.
Posted on May 25, 2009
SOURCE: low pressure reading on Pool Heater
I had this problem with ours last year. I replaced the water pressure switch and it began working fine. We later had a symptom that the blower would start but it would not ignite. The ignitor rod was corroded so I took it out and sanded it with some sandpaper---worked fine...until I dropped it trying to reinstall and it broke. Bought a new one and it works fine now.
Today's problem is related to the blower now.... it is always something, isn't it?!?
Posted on May 30, 2009
  • 366 Answers
SOURCE: triton minimax 400 pool heater won't ignite
Make sure the gas valve is set to on and thermostats are set properly. Check the pressure switch and high limits for continuity.Check wires for signs of damage, etc..
Posted on Sep 16, 2009
  • 5 Answers
SOURCE: heater making loud noises
I had this problem with mine ( hayward h series abg100 ): exhaust fan turned on, waited approx 15sec, gas turned on, ignition, flame lit (can verify in flame window below knob), stayed lit for ~5-10 seconds (varied), I heard popping, cracking, knocking, banging noises, then gas turned off.
I believe the reason it does this is the bypass/diverter plate in the exchanger (right at the inlet side) is loose; the weld broke loose. They weld this very poorly and is obviously a known issue with the unit. I think storing it outside in the winter doesnt help. Another reason for the noise could be not enough water going through the exchanger because of a problem with the diverter plate, therefore the exchange gets to hot and boils.
I believe the ignition board senses this somehow (not sure how though, only way I can think of is via the ignition sensor), and cuts off the gas. I managed to fix this by putting on a small stainless steel hose clamp around the thermostat forcing the divertor plate tight up against the top so the water flows through the 3 exchange pipes. This was a very difficult maneuver due to working inside the tight pipe, but it worked!
You can check if you have the same problem as me by taking off your hose input to the heater, and removing the outer 2 PVC reducer connectors. Then you'll have access and sight to the exchanger input (3" pipe?) and should see what I'm talking about. If the plate moves (or isn't tight) then you most likely have the same issue. kevin71246@hotmail.com if you have questions.
Posted on May 24, 2010
MY 1998 FOR EXPLOYER ELT HAS A LOUD HUMMING NOISE THE FAST I GO THE LOUDER IT GETS CAN ANY ONE TELL WHAT A POSSIBLY CAN BE .MY HUSBAND SAYS THE SPINDLE????
Humming Noise Front End- Any Ideas? - Ford Explorer and Ranger ...
www.explorerforum.com > ... > Stock 1995 - 2001 Explorers
Dec 18, 2008 - 19 posts - ‎16 authors
Have a 98- Eddie 4.0 SOHC, 4WD with a 100,000 mi. When driving it has a humming noise, it almost sounds like a bad tire, or a ... I start to hear the humming noise at 20 mph, it is very loud at 40 to 50 mph ... 94 XLT-95 FX4. humming gets louder as speed increases
May 27, 2010
How to: IAC valve cleaning thread (w/pics)
Oct 29, 2007
humming from air intake
Jun 6, 2002
Loud humming noise coming from the air filter
Oct 6, 1999
More results from www.explorerforum.com
Jan 12, 2016 | Cars & Trucks
1996 ford contour loud humming noise and vibration from front wheels
You have a defective wheel bearing most likely, the noise sounds correct for that problem. have a shop drive it before you replace anything to confirm my guess.
Sep 26, 2012 | 1995 Ford Contour
New jandy LxI 400 natural gas pool heater makes a howlering sound which starts after it runs for about five minutes. The noise starts soft and continues to get louder. The noise is loud. Once I shut the...
Your bypass valve is bad. Probably because you did not pay attention to your water chemistry. It is located where the pipes enter the heater. You remove it from the side of the manifold that is outside the heater. It is not a difficult job. Just make sure your pump does not come on while the heater manifold is open!
Apr 16, 2011 | Jandy LXI 400 NATURAL GAS POOL HEATER -
Have loud noise from engine,gets louder w/more rpms.it is an automatic,60k miles.no exhaust or muffler problem.
Serpentine belt tightener pulley bearing was bad, made a loud noise. I replaced the pulley (jobber part) and the noise level was reduced enough to notice the waterpump was also making a noise ... more revs = louder noise. I am now replacing the water pump. (approx 60k Miles too).
Nov 22, 2010 | 2004 Toyota Corolla
Hayward heater making a loud banging, knocking noise.
If you have an external by-pass it needs to be closed. This will be a valve between the pipes in and out of the heater. When you close it, it forces water through the heater. When it is open no water goes through the heater. So the water in the heater boils and turns to steam. With no where to go it starts banging and jumping.
If you close this valve or it is closed and you still have trouble the internal by-pass has gone bad. The overheating from the first problem will often cause this.
You remove the water header from the side of the heater and pull the pipes from it. In reality you will probably have to pull the gas pipe so you can move the heater from the pipes. You will find the assembly inside the manifold. It will probably come out in pieces but the new one goes back in as a unit.
This will regulate your water flow and keep it heating at a constant temp.
Nov 20, 2010 | Hayward H-series Electronic Gas Pool...
Hi I have a magnum 1000 Jacuzzi pump for my
alot of companies use to have a damper ring on pump shaft which would knock down some of the noise a pump motor made pumps make noise and the bigger the pump the louder the noise if its not vibrating or clunking then its running as it should
Apr 21, 2010 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
I have a TYPE JV Gas Fired Mini-Thermal Hydronic Boiler supporting 2 zones in my home. It has run perfect for the first 13 yrs. For the past 3 yrs there is a loud HUMMING which occurs only when the upper...
Lower pump connector going bad? Air in the system? Do you have valves that may be partly open and stuck? When the noise is occuring, go through the system as much as you can get to. See if you can find the source by hearing it get louder or by you touching here or there. It sounds as though it is mechanical but may be as simple as a valve in need of attention. Food luck and please let me know if you find it...Lee
Oct 27, 2009 | Jandy TELEDYNE LAARS GAS VALVE, PROPANE...
High pressure, and heater noise
I am not sure if you have solved this issue, or not, but if the PSI on the gauge is high then the problem may not be the heater. When you have the system turned on, and the PSI is reading higher than normal, just the flow of water coming out your return lines. If the flow is normal, like when you clean your filter, then see if you have a way to re-route the water so it bypasses the heater. If the PSI on gauge drops, then the issue is in the heater.
If the flow of water is slower than normal, with the PSI reading high, then you have a blockage somewhere in the system. It could be something simple like removing debris from skimmer and pump backets, to time to backwash, or clean, the filter.
If the flow of water is really hard and fast, with the PSI high as well, then you have too much water going through the system and need to slow it down.
Jun 27, 2009 | Pentair MiniMax 100 Aboveground 100,000...
Loud Humming noise every time we run the dishwasher
Hi, I had this exact same problem. In my situation it turned out to be the pump that pumps out all of the used water. It was rubbing up against the floor so that every time it turned on it made a loud vibrating sound. I just reached under the washer and put a piece of rubber between it and the floor and it solved the problem.
good luck!
I saw this post because I am considering buying the same model you have. Other than the noise problem you have, what do you think of it?
Mar 29, 2009 | Jenn-Air Dishwashers
Loud humming
If this is an electric resistance heater then there is no power supply or transformer. I had a baseboard heater that would hum loudly and I found there's a wire that runs along the bottom to connect the far end of the heat element to the electrical wiring at the supply end. This wire becomes magnetized from the current flowing through it and vibrates in the channel it runs through. I was able to open this channel and squirt a bit of silicone caulk in to keep the wire from vibrating and the hum is gone.
Dec 19, 2006 | Honeywell HZ514 Baseboard Heater
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
