Question about Element Skateboards Element EDHFT12 DVD Player Plays DVD/CD-RW/MPEG4
I have an Element EDHFT12 hdmi player and can not get it to play in hdmi. It shows no signal in hdmi
Will not connect in HDMI, it shows no signal on tv
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Element Skat... Master
  • 924 Answers
Make sure the audio output in your system setup, is set to HDMI output. For more information, please visit my website at audioserviceclinic.com. Thank you.
Posted on Nov 30, 2013
I do have a lg BH6430P home theatre,when I connect the HDMI to the TV it gives me no signal
check that the hdmi lead is good, if it is check that its outputting a signal that is not too high for the tv. i.e. if the lg is outputting 1080p can your tv show 1080p just because the tv is HD ready, doesnt automatically mean it can show 1080p try setting the lg to 720p or lower to see if anything shows on the tv
Aug 02, 2017 | LG Audio Players & Recorders
Lg 42lt75 used to work with a bp630 blue ray player but now shows "No Signal".
have you tried connecting ur laptop via hdmi to tv? if it works you should probably check tv settings for hdmi, if not then it is possible that the hdmi controller from tv to have some problems, i had a similar problem with a philips tv and took it to service ending up in a total replacement of motherboard and led display
Mar 09, 2014 | Televison & Video
Hi, I have a Lenovo Z470 laptop and I want to connect it to my Philips Smart TV (40PFL5507H/12), I thought it will be straight forward connection, but the TV is showing no video signal receive, please
HDMI is the best method as VGA is low density video. You may have to set up the laptop to send data output to the HDMI/VGA port (Out to the TV). Your manual should spell out the procedures to change from Computer Internal Video to Video OUT.
Feb 08, 2018 | Lenovo IdeaPad Y510 Notebook
I am have my DVD player connected to the receiver via component cables (blue, green, red). Sound is playing perfectly via its own set of cables. I have an HDMI leaving the receiver as an input to the...
Sounds like your receiver only supports HDMI "pass-through"
HDMI passthrough will only forward the video signals from the source HDMI port, it will not actively convert the Component Signal to HDMI.
May 30, 2011 | Yamaha RX-V663 Receiver
Player turns on ok,display shows menu that disc is playing but tv says there is no signal, not seeing home screen with net flixs or the other apps.player has been working great we used it 2 day earlier...
The "handshake" between the television and the blu ray player has been lost. This happens a lot when connecting with hdmi. Sometimes a hot swap will work to remedy this. That is turning off and unplugging both your television and bluray player while removing the hdmi cable from both for 30 seconds to one minute. Reconnect the bluray player to the hdmi cable and then to the television. Plug them both back in and turn the television on first then the bluray player. Your television may need a factory reset going into the service menu or the board the hdmi ports are located on might need to be replaced if all of the hdmi ports are not responding. You can connect with component if possible in the meantime.
Apr 14, 2011 | LG BD390 Blu-Ray Player
PS3 hdmi connection works but not std rca AV
You must set it OFF HDMI while connected to the TV...
Feb 28, 2010 | Sony Playstation 3 (PS3) Console
Toshiba sd-5000 just not playing. all HDMI cables are properly plugged in. Accidentally push a "strange button on the remote and the DVD player just topped working. The LCD shows that it is working, but my...
I got the same problem today. I thought it was a connection on HDMI cable problem. I tried many different options to solve it but nothing was working. After I read your post I realized that my 2 y old boy was playing with the remote before it happened. So I found on menu in DVD player option - default setting- and I pressed it - and bingo - it's working. I used cinch cables instead HDMI while I was fixing - just in case you cannot get the menu screen on tv - good luck
Jan 20, 2010 | Toshiba SD-5000
My gateway t-6330u hdmi cannot connect. It shows the the external monitor is connected but my TV set shows no signal. and it worked perfect couple month ago
Here is something you may or may not have tried:
With the HDMI cable hooked up to your TV set, reboot your computer. in many cases (even though it may be shown as hooked up) the video card will not send a signal on a specific output unless there is something plugged into it on bootup. Once that has been done, verify that you are on the proper HDMI setting on your TV. Many TVs have multiple HDMI inputs, so it is possible that there is a signal and it's not switched to it.
Sometimes its about going to the basics.
Nov 03, 2009 | Computers & Internet
Element Skateboards Element EDHFT12 DVD Player Plays DVD/CD-RW/MPEG4 Logo
379 people viewed this question
Top Element Skateboards Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Element Skateboards Audio Player and Recorder Expert? Answer questions, earn points and help others
