Question about Electrolux EWMGD65HTS Gas Front Load Dryer w WaveTouch Controls Featuring
Electrolux gas dryer error code e66
Is there a way to reset the dryer and clear this error code?
protek480
  • 1714 Answers
SOURCE: Electrolux dryer error code e61
There is a 'tech sheet' in the back pf the dryer. Unplug machine, Remove the access panel on the back to get to it. Reach in and it should be there. It will tell you how to do a button check. You have to enter a test mode through the buttons.
The E 61 is a stuck button.
Enter function test mode and perform key
stuck closed (active). (button) test to determine which button is at
fault. Carefully free the and perform the test
again. If button is free but the key struck code
still exists, replace electronic control.
Posted on Sep 25, 2009
SOURCE: Electrolux ewf1087 washing machine error code?
what is a (e40)
Posted on Jan 02, 2010
tattootech2
  • 72 Answers
SOURCE: ewdw6505gso electrolux. error 1. have turned off
the water will have leaked into the drip pan underneath, which is installed to protect your floors. Unfortunately, only way to get at it is to pull out dishwasher and remove 3 phillips screws that hold it on. In order to repair leaks, Electrolux came out with a "leak kit", which is part number 154769101. Comes with all parts that they had leak issues with
Posted on Apr 07, 2010
  • 5125 Answers
SOURCE: I have an electrolux gas range, model ew30gs65gs1. I get error code f14 when I plug it. Clear error code, try to set anything except the clock on the glass panel and o very f14 again.
The F14 error indicates a problem between the touch pad and the display control board. This could be a wiring problem so check the wiring harness between the two parts. Make sure that the wires are properly seated and check for corrosion at the connectors. It could also indicate that either the touch pad or the display control board (or both) are faulty. If your wiring is good, you need to replace the touch pad. If the error persists after replacing the touch pad, you have to replace the display control board as well.
The parts are available here: http://www.searspartsdirect.com/model-number/ew30gs65gs1/1412/0124250.html . See parts 19 and 20 on the control panel diagram.
I hope this helps.
Posted on Dec 28, 2016
Testimonial: "Thanks Cindy. The problem with ordering parts is that it is too expensive to 'guess' which part it might be. Is there a diagnostics port on the board whereby I can check to see if it is really a bad board?"
I have a code e62 on my dryer
did some research might be a faulty heater or some kind faulty wiring or some kind of circuit board failer. i checked on youtube where i guy talks about errors and he explains them too. Tumble Dryer Error Codes E61 E62 E63 E64 E65 E66 E67 Electrolux AEG Zanussi so try watching this video this help you on what you can do more for your dryer..
Jun 23, 2017 | Computers & Internet
E75 default code on Electrolux gallery series dryer
I appreciate your inquiry, Ape!
From what you have described your Electrolux dryer is displaying an error code of "E75". An"E75" error code is not showing as a valid error code it could be a possible miscommunication with the control panel and I would recommend performing a reset on your dryer. You can do that by disconnecting the power from it for ten minutes. Could you please provide me with your model number? You can normally locate the model number on the serial tag which is located on the door frame. Also, once you reset it can you provide feedback if you continue to receive that error code. Good luck. -Matt
May 19, 2015 | Electrolux Dryers
EDV
Check Outlet Thermal Limiter for continuity. For Gas Model, also
check Inlet Thermal Limiter for continuity. If Thermal Limiter is open,
check for evidence of high temperature event and any resulting damage...
If no further damage is evident, replace Thermal Limiter
Mar 24, 2014 | Electrolux Dryers
I HAVE A ELECTROLUX T3650 TUMBLE DRYER SHOWING E 08 FAULT
Hi - Typically error code E08 on Electrolux models indicates that it is recommended for a professional to check the mist value on the motor. Try resetting the unit by unplugging it or flipping the breaker to the household circuit breaker. Wait approximately ten minutes and turn on the dryer. If the error code does not clear and it is ineffective, contact a professional to move forward accurately.
Oct 12, 2012 | Electrolux Dryers
Error code e66
Hello wez1330 - Error code E66 indicates that the thermal limiter circuit is open. Base on the intensity of the issue, I suggest contacting a professional technician to accurately repair the unit. Technician will need to check the inlet or outlet thermal limiter for continuity. If the thermal limiter is open, tech will need to check for evidence of high temperature event and any resulting damage. If no futher damage is evident, the thermal limited and retest will need to be replaced.
Sep 29, 2012 | Electrolux Frigidaire Affinity 5.8 cu. ft....
Electrolux Gas Dryer: E66 error
Should the heater wire have electrical continuity to the housing
Mar 08, 2012 | Electrolux EIED55H Dryer
Electrolux EWF 1087 error code E60
My Electrolux washer always come up with an error code of E60, Why? can any one help
Mar 07, 2008 | Electrolux EW1200i Front Load Washer /...
Electrolux EWMGD65HTS Gas Front Load Dryer w WaveTouch Controls Featuring Logo
326 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
