Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
I cannot get my wireless router to work on my laptop
Its always worked until lately and now my laptop signal shows and tells me that my WLAN:Disabled and I don't know what to do to fix it. please help me
  • jkpf May 11, 2010
    First thing you should do is unplug the router for 2 minute or so and try to reconnect first. Some routers needs to clear the buffer that way for it to work again.
    Sergeant:
  • 322 Answers
Try replacing or upgrading the router's firmware.
Posted on May 09, 2009
Escribe your Linksys E2000 Advanced WirelessN Broadband Router Network Routers Problem Router has been working fine since initial setup almost a year ago. Turned on computer yesterday, and it would not...
Please check whether your computer's wireless connection enabled or disabled. If you are using windows 7 this information you can find in network sharing center. By accident if WLAN is disabled it can be enabled. Also power cycling the router may do the trick.
More drastic approach is resetting the router which I recommend to reserve as last resort. With information you provided the router seems to be fine and your computer wireless need to be enabled!
good luck!
Sep 12, 2011 | Cisco Linksys E2000 Advanced WirelessN...
Everything was finewith wireless until we pluggd ethernet cord into back of siemens for xbox 360 now computer (wireess) doesnt work upstairs help
check what cable you plugged into the xbox...and be sure is not the main internet cord that it supposed to be in the wlan port of the router ...and get a cable from one of the router's LAN port into the xbox..and leave the main one into the wlan ..this way you will have wireless ...if the configuration on cables is ok ...get into the settings of the router from the admin computer the settings were made in the first place ....and see whats wrong with the wireless settings ..they may be disabled by mistake ..or another odd reason ...and enable the wireless transmitting again ..
Mar 21, 2011 | Computers & Internet
Belkin g wireless modem router f5d7634 always disconnect
try to reduce the MTU settings on your router.
If possible upgrade the firmware of the router.
Click here for more info about the networking
Oct 07, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Laptop not connecting to wireless network
Don't wait tell you laptop is defective, at least buy a new wireless lan before its too late.
Sep 30, 2009 | Dell Inspiron 5100 Wireless Mini-pci...
I m havin BSNL ADSL2+ DNA-A211-1 modem..i don know how to connect my laptop wit modem in wifi mode..pls tell how to configure n connect it..modem has ethernet port oly not having usb port..pls suggest some...
Secured Wireless is better than a unsecured one. Configuring a secured wireless network easy.
· First Check it the Wireless is turned on in the modem.
You must see the wireless light glow on.
Wireless LAN (WLAN) should be Enabled before configuring the wireless network
· To make sure, if the WLAN is enabled you can check the WLAN light glow.
· If it is off, then you can be sure that WLAN is disabled.
May 27, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Can't connect to internet
there is a switch on the front or side that needs to be put to the on position, if it's anything like mine it is very small and hared to see. If you normally have a LED that tells you that the adapter is on, it's normally near that.
May 07, 2009 | Dell Vostro 1500 Notebook
Can't turn on wireless on computer
which toshiba satellite pro ?
is wireless on at the laptop?
sometimes a combination: Button FN & F1-F12
try to connect router via ethernetcable:
inside routerconfiguration enable wlan
sometimes routers have a switch outside to enable/disable Wlan
is there a WLAN-LED at the router?
May 05, 2009 | Computers & Internet
Inspiron 6000 has trouble picking up wireless signal
Some wireless cards are better than others at picking up weaker signals.
The problem with any wireless transmissions is that radio signals cannot pass through metallic surfaces.
You should position your wireless router away from metallic surfaces/walls and position your laptop so it can receive the radio signals without it passing through any metallic walls. If possible place the wireless router higher than at desk level.
Dec 26, 2008 | Dell Inspiron 6000 Notebook
Wlan disabled
If you have vista click the start button and in the start search type "hp wireless assistant". It should show up in your list while you type it. Click on it. Once the assistant box shows up, click on "properties". A "settings" box should show up. The main one you need here is "independant controls for installed wireless device". Check that box. The other ones are icons and indicators that you can check at your discretion. If in doubt, check them all. Hit the "apply" button. Then in the upper right hand side of the box hit the button that says "turn on". This should activate the device and if you have a light up indicator on your computer, it should change color or light up. That should do it. Kind of weird how it gets to that point.
Feb 26, 2008 | HP Compaq Presario V2000 Notebook
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
108 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
