Question about Ovens
Noisy fan The fan in the bottom oven has started making a noise. WD40 eases it temporarily, bu the noise returns after a short while.
    Genius:
  • Ovens Master
  • 1,198 Answers
Only graphite lubricants are heat resistant. The fan could be worn out, bearings just well done. (oven humor).
Posted on Nov 29, 2013
noffie
  • 10 Answers
SOURCE: noisy fan
it has to be replaced the bearings are shot on it I'm afraid well knowen problem in are trade.
Posted on Apr 12, 2008
barkencoa
  • 3463 Answers
SOURCE: NOISY OVEN
Yes, it can be fixed quite simply.
First check that the fan is not catching the cover or grill, if it is not remove panel covering fan and see if the fan blade is loose,on the shaft, they are usually held on by a left handed nut., so to tighten go the oppisite way to what you normally do, if that does not cure it, then your only solution is to replace the fan motor complete.
Plz rate my solution.
Thanks, and a merry xmas.
Posted on Dec 21, 2008
barkencoa
  • 3463 Answers
SOURCE: zanuisi top oven making noise
Yes , there is a cooling fan located at the top of the oven
It could be the fan blades catching, or a noisy fan bearing.
You would have to access it by removing the top oven cover to check., and yes it could be as a result of having it cleaned.
Thanks.
Posted on Jan 02, 2009
barkencoa
  • 3463 Answers
SOURCE: Oven makes a noise when I turn it on.
If it is a fan assisted oven , then it sounds like a noisy oven fan.
It could be a worn or dry bearing in the fan motor. if you open the oven door , you should be able to tell if it is the fan by listening to it carefully.
The other possibility is if it has a cooling fan in the back or on the top of the oven, it could also be that causing the prob, these are about the only things that could be making a noise, as there are no other moving parts that could make a noise.
PLz rate my solution.
Thanks.
Posted on Jan 08, 2009
  • 44 Answers
SOURCE: very noisy fan
Hi
you need to replace the fan as this will be the cooling fan which cools the oven down. and can not be disconneted .
regards
Posted on Mar 21, 2009
Cooling fan makes a rattle noisy when the oven gets hot & after turning the oven off. Very very annoying.
I would suggest taking a look at the fan and seeing if any hardware has come loose. A loose holding screw will cause the fan to wobble in its cage and make noise like the one you're describing. If all the hardware is tight, try a dab of WD40 to get everything moving properly.
May 23, 2015 | Ovens
Noisy fan and no heat
Kitchen aid is made by Whirlpool. There is a very good chance the then thermal fuse on the back of the oven has tripped. Whirlpools are very prone to this fuse tripping after a clean cycle. The noisy fan is just that a noisy fan it will probably need replacing. I have replace a couple of them over the years. When you pull the oven out to replace the thermal fuse replace the fan motor at the same tiome.
May 06, 2014 | KitchenAid KEBC207 Electric Double Oven
How to fix noisy fan in chef fan forced oven
Possible fault in the bearing bushes , in the first place you can spray a WD40 or even some light oil into the fan's rotor ends where the bearings are located. If the sound reduces clean and wipe off excess oil from the shaft side. Also make sure that the fan leaf is not making the noise due to any dirt accumulation or obstruction.
Jan 09, 2012 | Ovens
My whirlpool oven (model rbs305) makes a loud noise whenever it is on. I can't figure out if it's the fan, or just extremely loud.
I would suspect that the blower is noisy its what i would expect to potentially make noise ...if fits in the back of the control panel and it comes on to cool the control board each time the oven is on.
In case it turns out to be the blower thats noisy the part number for it is W10176670
GENE
Sep 10, 2011 | Whirlpool RBS305PD Electric Single Oven
Cooling fan is very noisy
It is probably a worn fan bearing, or loose or broken fan blade.
You could try spraying the bearings with WD40,
which may quiten it down, but normally the only solution is to replace the fan motor complete.
[Please rate my solution.
Thankyou.
Jan 30, 2010 | Zanussi ZDQ495 Electric Double Oven
Indesit FIE 56 K.B GB oven The circulation fan is squeeking
The symptons you describe are typical of the fan motor bearings failing. you could try spraying the bearings with WD40, but this would only be a temporary solution, in the end you will probably have to replace the fan motor complete.
Hope this helps.
Jan 07, 2010 | KitchenAid KEBC101 Electric Single Oven
Candy oven noisy fan
Noisy fan means bushes are worn. cant be repaired. needs replacement. Quote model of oven to spare parts supplier and replace. Make sure power is unplugged and not just switched off before repairs are done.
Sep 14, 2009 | Candy FP855 Electric Single Oven
Loud droning noise from fan.
You are correct in assuming that is a noisy fan bearing, only solution is to replace the motor complete unfotunately.
Please rate my advice.
Thanks.
May 27, 2009 | Ariston Technologies Ovens
Thanks.
Jan 08, 2009 | GE JKP30WMWW 27" Built-in Single Electric...
Zanuisi top oven making noise
Thanks.
Dec 31, 2008 | Zanussi ZDF490 Electric Double Oven
Ovens Logo
148 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
