Question about Craftsman Garden
Gt 5000 stuck in gear
I have a GT 5000 that I just got stuck in gear. it was creeping a bit, but not much. I also disengaged the transmission and still wouldn't start. Fuse is good, and it is not engaged with the mower deck, brake is on and seat switch is on as well.
  • 35 Answers
Check brake switch, unplug it and make a short jumper wire in the plug ..,in switch ,if it still wont start ,jump across the starter silinoid .
Posted on Nov 29, 2013
panilling9
  • 284 Answers
SOURCE: surging
Doesnt sound like governor issues
Sounds fuel related
You need to remove your carb. and tank assembly as one
Take the carb off the tank and replace the daiphram& gasket between the two
note how the old one came off.
Sometimes the common fuel we have now with 10%ethanol effects rubber parts and causes them to fail prematurely.
you may notice the old gasket is wrinkled and maybe not pliable like it should be.
while you have the carb apart give it a fairly good cleaning with a air hose
be sure not to overtighten the bolts that mount the carb,back to the tank.
Be sure your fuel you are using is fresh
hope this helps some for you
Posted on Jun 13, 2009
SOURCE: I have a cub cadet 1550, Blew fuse and wont disengage from gear
You have a bad wire which rubbed on the plastic housing to the engine block near the starter mower which causes a short and blows the fuse. I have the same tractor and this happened to mine also. The wire is red.
Posted on Jul 29, 2009
  • 430 Answers
SOURCE: I have a 1994 G4000 craftsman riding lawn mower i
If electrical ( the motor shuts down like you turned the key off) its likely the rider presence switch ( seat switch).
If the motor is pulled down and dies as if its uncapable of handling the load check the drive system. Remove deck and check drive belt and pulleys. Pull the belt off of a pulley for slack and with the tranny in first and the brake released you should be able to turn the large pulley on top of the tranny easily which should cause the tractor to start to move. If you cant turn the pully there is something wrong in the tranny.
Posted on Nov 30, 2009
  • 599 Answers
SOURCE: swisher 44" mower starts and runs but engine bogs
The engine in this machine seems to be powerful. If you can remove the belt from the pulley that drives the blade. Try turning the pulley buy hand. If it turns tight or not at all this is your problem. The unit that is the pulley to blade assembly is seized or ready to seize. Sometimes they are designed to be taken apart and repaired, and sometimes they are not. Did you check for a grease fitting within the pulley to blade unit?
I would like to hear how this works out for you. Best of luck.
Posted on Jun 14, 2011
  • 4044 Answers
SOURCE: My PTO will not engage
Check the operator presence switch located under the drivers seat. If that isn't mounted properly it will not activate like it should and will cause the mower to die when you try to engage the PTO or release the brake with it in gear.
Posted on Jul 06, 2011
My 2004 18 cc totota wish is hard to pull gear lever out of park even with park brake on worst on cold start
Do you usually park on a hill? If so the park brake is not holding the vehicle, it is creeping away and putting pressure on the transmission parking pawl, which makes it hard to disengage.
Nov 23, 2016 | Toyota Cars & Trucks
200 Nissan sentra linkage cluck no 5th grar
Transmission case + 5th gear fix - SR20 Community Forum - The Dash
www.sr20-forum.com > ... > HowTo's > General Maintenance
Dec 28, 2010 - 25 posts - ‎6 authors
How to recognise and repair 5th gear pop-out in a B13 or B14 ... Dont worry about the shift rod linkage and other parts in the old ... bad 5th gear and the notch gets larger and lager then you have no 5th gear . ..... BenFenner's 2000 Black M-Coupe ... NISSANB13 (Sunny/Sentra Genesis) Kumpul2 di sini yuk!
ugh stuck in 3rd gear (5spd LD) P10 g20
Jun 13, 2012
No 5th gear
Jan 1, 2011
How to: Fix your P11/B15 tranny with QG18 gear ...
Sep 11, 2009
Thread: How to recognise and repair 5th gear pop-out in ...
May 15, 2009
More results from www.sr20-forum.com
Oct 21, 2015 | Nissan Cars & Trucks
Crunching when changing gears on a pajero
check the oil level of the gearbox, if level is low or oil is too thin will cause it to crunch. put an 80w90 gear oil into it if needs fill or change/ also check the clutch is fully disengaged. maybe clutch hydraulics have air in the system, this will reduce the travel of the clutch fork and not fully disengage the clutch. to see if its the clutch hydraulics select 1st gear push in the clutch and start the engine, if it starts to creep forward check out the hydraulics. if all this ok, prob be the synchro rings internal in the gearbox
Nov 05, 2013 | 1992 Mitsubishi Pajero
Mitsubishi Eclipse GT clutch slipping
sounds like you need a new clutch and throwout bearing
Apr 14, 2017 | Mitsubishi Eclipse Spyder Cars & Trucks
I have a 1979 yamaha gt 80.i was riding and shifted into 3rd and now its stuck there and i cant shift up or down.why is that
Hi, Anonymous and the usual suspects are:
1. Clutch not disengaging.
2. Bent shift shaft.
3. Shift fork bent or seized.
4. Gear seized on the shaft.
5. Gear positioning lever binding.
6. Shift return springs weak or broken.
7. Shift return spring pin loose
8. Shift mechanism arm spring is broken.
9. Shift mechanism arm is broken.
10. Shift drum is broken.
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1982 GT 80 Enduro Wont shift
Fixing the 2nd Gear on Yamaha Triple Engine
YAMAHA DT80 DT100 GT80 FULL SERVICE REPAIR MANUAL 1977 1982 Download... $18
OEM parts for Yamaha
1979 1980 YAMAHA GT80 GT 80 FACTORY OWNERS Manual OEM BOOK 80 eBay
Apr 16, 2012 | Yamaha Motorcycles
When you engage the mower the tractor looses power and just creeps along. We have replaced the battery, fuel filter, air filter, and blades. Nothing seems to work. Any ideas?
Fuel mixture is wrong - your carb needs cleaning - specifically the jet.
At idle - it works fine - but under load it bogs down because the demand for fuel is increased... but not delivered.
Thanks!
Jun 15, 2011 | Craftsman GT 5000 26 HP54" Garden Tractor...
I got engine code PO700 and PO733 on my 06 charger
P0733-GEAR RATIO ERROR IN 3RD
Theory of Operation
The Transmission Control Module (TCM) constantly calculates the transmission ratio based on the input speed sensor 1 and 2 (N2-N3) signals and the calculated output shaft speed. The intent of this diagnostic is to detect if the transmission is slipping or an invalid gear ratio is present.
  • When Monitored: Engine RPM greater than 450 RPM , output speed greater than 180 RPM , no N2 - N3 input speed sensor errors present, no gear selector lever errors present, no ABS system errors, and all wheel speeds above 450 RPM .
  • Set Condition: No shifting operation and detected gear is not the actual gear. No shifting operation - detected (calculated) gear is less than actual (expected) gear, no plausible gear is calculated, actual turbine speed - calculated turbine speed is greater than 300 RPM or calculated transmission ratio is above threshold. During an Upshift detected (calculated) gear is less than actual (expected) gear. During Downshift - detected (calculated) gear is less than actual (expected) gear.
Possible Causes
  • LOW TRANSMISSION FLUID
  • OTHER TRANSMISSION DTC's PRESENT
  • INTERNAL TRANSMISSION FAILURE
Always perform the NAG1 Pre-Diagnostic Troubleshooting procedure before proceeding. See: Transmission Control Systems\Testing and Inspection\Procedures\NAG1 Automatic Transmission
Diagnostic Test
1. CHECK FOR OTHER TRANSMISSION DTC's
With the scan tool, check transmission DTC's
Are there any solenoid and/or solenoid supply voltage DTC's present?
YES >> Refer to the Transmission category and perform the appropriate symptom(s).
NO >> Go To 2 2. CHECK TRANSMISSION FLUID LEVEL
Check the transmission fluid level.
Is the fluid level correct?
YES >> Go To 3
NO >> Properly adjust the fluid level.
Perform NAG1 TRANSMISSION VERIFICATION TEST - VER 1. See: Verification Tests\Transmission Verification Test 3. CHECK IF DTC IS CURRENT
With the scan tool, record the Environmental Data and erase Transmission DTC's. NOTE: If the TCM detects and stores a DTC, the TCM also stores the vehicles operating conditions under which the DTC originally set and is located in scan tool under Environmental Data. Before erasing any stored DTC's, record any available data to assist in duplicating the conditions in which the DTC originally set.
Using the Environmental Data recorded earlier, test drive the vehicle while trying to duplicate the conditions in which the DTC originally set.
Did the DTC P0733-GEAR RATIO ERROR IN 3RD reset?
YES >> Repair internal transmission as necessary.
NO >> Go To 4
4. INTERMITTENT WIRING AND CONNECTORS
The conditions necessary to set this DTC are not present at this time.
Using the schematics as a guide, inspect the wiring and connectors specific to this circuit.
Wiggle the wiring and connectors while checking for any possible open or shorted circuits.
Check for any Service Information Tune-ups or Technical Service Bulletins that may apply.
Were there any problems found?
YES >> Repair as necessary.Perform NAG1 TRANSMISSION VERIFICATION TEST - VER 1. See: Verification Tests\Transmission Verification Test
NO >> Test Complete.
Jun 04, 2009 | 2000 Dodge Durango
Garden Logo
48 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
