Question about Boating
Coleman canoe parts diagram - Boating
How do I wire a Coleman Evcon 3500A916 furnace Model
Wiring Diagram for a Coleman Furnace - RV-Coach Online
www.rv-coach.com > Discussion Forum > RV - Insurance
... Furnace, Mark, 9-12-07. Need wiring diagram for coleman furnace Model # 7700B856 .... Amanda, 11-10-11. I need a wiring diagram for a Coleman evconpresidential model 7956c856 ... Need wireing diagram for coleman 3500a916 ... More results from www.rv-coach.com
FURNACE Diagram & Parts List for Model eb15b Coleman ...
Dec 22, 2015 | Coleman Heating & Cooling
Coleman canoehow do i protect the canoe hull from from fading . iis there a waxing that would be effective?
You could use a product called 303 Protectant (I think that's the right name) every couple of months, and more if you use the canoe, but that would coast maybe $10 each time and I would ask if it is easier to just store it out of the sun, or under a tarp (not wrapped tightly).
You could try a car wax that claims to protect from UV.
Jun 23, 2014 | Boating
I have a really old coleman canoe & the front seat support bars are broken.Any ideas how to repair or where to find replacement parts? Coleman says its discontinued so no parts from them.
Compare with a Pelican canoe, and see if its parts will fit.
Alternatively, make something similar out of aluminum tubing or hardwood.
Do consider if the boat is actually worth fixing. A used Coleman can be found for $250-350, and if you do much canoeing a used (better canoe) can be found for $450-550 in most areas.
Jun 05, 2014 | Coleman Boating
Skid plate for coleman conoe
Try any canoe / kayak store and ask for skid plates. These are usually at least $20 to buy the plates alone, plus the stuff to install them. Adds 1.5 to 3 pounds. For a Coleman, which is very flexible, you might have to install carefully and with flexible adhesives rather than epoxy. Think about whether you really want to do it.
Cost for a shop to do it is probably $100 or so, and a worn Coleman is not worth that.
Apr 30, 2014 | Coleman Cable Boating
I have a coleman canoe about 1978ish model 5907-719 17 ft. I can't find a replacement center thwart. Any ideas?
Post a picture of what it looks like, if you can.
If it was wood, then just make one. Else make a wooden one to fit where the Aluminum would have been. That is the usual thing to do with older boats, and cost-effective.
If you really care about the canoe, seek out an old one for sale "well used" and buy it as a replacement or for parts. An elderly Colman is not worth a lot, so don;t spend a ton on fixing the first one.
May 24, 2013 | Coleman Boating
I can't find any id on my old scanoe, how can i get an id number for it.
I have one from the 1980's and found numbers stamped on the side stern quarter, hard to see
Mar 21, 2011 | Coleman Boating
How do I fix my badly faded canoe, colour is red and only faded down one side?
I would recommend painting it with a type of paint that would adhere to the material the canoe is made of whether that is aluminum, fiberglass, etc. My guess is that you have been leaving only half of the canoe in the sun, so when you store the canoe, either keep it in a shaded area or cover it with a tarp to keep the sun off.
Jun 06, 2010 | EA Sports Pelican Int'l. Colorado 15' 6"...
Colman Canoe Bracing Gone Loosing Shape
Your going to have to replace the bracing, the poly plastic your canoe is made of needs it to retain it's shape. If its an older one the bracing should be made of aluminum tubing, you can buy this then cut to size shape and fit to your canoe. If its a newer one say made by pelican {they took over for coleman} its made of plastic this will prove to be harder to do. Either way its a big job
Nov 08, 2009 | Boating
Canoe has damage on the front bow.
Bondo would probably work.
Also, you could laminate a few pieces of something like vinyl siding/facia board over the hole. If the canoe is ABS, the vinyl siding cold be "welded" / fused to the ABS with PVC primer & solvent/cement.
May 27, 2009 | Coleman Cable Coleman Inflatable Boat...
Actually a Scanoe with a square hole in it!!
Ha Ha! Very funny :)
Maybe, I've never tried it.
Is suppose with the gaping hole, it will allow the water in, so if Iput the clothes in the canoe, it will lilkely wash a little.
All kidding aside, since you know Coleman, I just wondered if you would have a referral to someone out this way
Cheers!
Craig
Mar 03, 2008 | Washing Machines
Boating Logo
198 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
