Question about Husqvarna Chain Saw 20" Bar
Can I make my own cylinder gasket for a husky 61 ?
For a after market cllinder
Yes you can make your own cylinger gasket for your chain saw just as you can make a gasket for a carberator or other items. Just go to the local automobile parts store and ask for gasket material. Take the old gasket out and trace the pattern on the gasket material and cut it out. The holes will have to be cut cut out also to the correct diameter. The screw holes can be drillied out or punced out for the installation. Be sure you obtain the correct gasket material so take the old material in with you for them to look at.
Posted on May 09, 2009
A 359 husky. What is the size engine in mm.? Do they make a cylinder, piston kit that Inc gaskets. YEARS IN PRODUCTION?
2001 thru 2011
aprox 47mm
Piston and Cylinder kits from Husky do not include gaskets, but can be purchased individually.
Dec 04, 2016 | Husqvarna Garden
I have an older Husky 61 that is leaking bar oil down the shaft of the oil pump. It is a new aftermarket oil pump, and after taking it a part there appears to be no means of sealing the pump shaft to avoid...
There was never an o ring fitted to the pump shaft, just a shim and a copper washer, the rest was down to good tolrences, your after market pump may have poor tolerence between the pump body and the shaft, pirate parts are not always a cheap solution.
Jan 21, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husky 61 lots of spark fuel is getting to carb cylinder is dry wont start would comprison be bad?
Two stroke engine have a reed valves, or something like it, that prevents exhaust pressure from causing the gas to back up.
Because of long idle times in the winter, if you don't use a fuel stabilizer, the gas dries up an leaves a sticky varnish residue.
This not only plugs up orifices, but glues the reed valve either shut or open. Either is bad. So you probably have to take the carb off and clean it to remove the varnish.
Aug 26, 2010 | Husqvarna Chainsaw Piston Kit for 61...
I need a drawing of a carburettor on a 61 Huaqarrna chain saw\r\nwhere do I get it? It is a husqvarna Chain saw
You didn't specify of its a 61 or a 61 Rancher. Here's the info you need to take to your Husky dealer. The diagram will be with the major repair kit.
Model 61, then the 61 Rancher:
CARBURETOR Model 61: ecblank.gif Tillotson HS-163A, B , HS-254A series or
Walbro WS series
MAJOR REPAIR KIT: ecblank.gif RK-23HS for HS-163A MINOR REPAIR KIT: ecblank.gif DG-5HS/T for HS-163A
CARBURETOR Model 61 Rancher: ecblank.gif Tillotson HS-163A series or
Walbro WS-17A, B series
K10-WS
D10-WS
May 18, 2010 | Husqvarna Garden
Carb assembling question
Thanks Jerry.
The only that came to my mind is to try here:
ArboristSite Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
I did a quick search and saw nothing for a 61 carb but it does not mean it is not there. Someone at Arborists has rebuilt your carb. The hard part will be digging them out then dredging up the right memories. Good Luck. HTH Lou
Mar 05, 2010 | Husqvarna Chainsaw Piston Kit for 61...
Hi how to put front spring in to clutch brake
No model 61 listed @ Husqvarna.
How about a 261 here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter 261 (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
See the Chain Brake Assembly detail. HTH
Lou
Oct 22, 2009 | Husqvarna Chain Saw 20" Bar
Husky 61 leaks chain oil? Gasket on tank???
HI. TO FIX WHAT YOU ARE TALKING ABOUT, YOU HAVE TO STRIP THE SAW AND SPLIT IT IN HALF. NOW I HAD THAT PROBLEM ONE TIME AND I FOUND WHERE THE LEAK WAS CLEANED IT VERY GOOD AND PUT SOME JB WELD ON IT AND AS FAR AS I KNOW THE SAW IS STILL GOING. GOOD LUCK. JIMBO
Feb 27, 2009 | Garden
Husqvarna Chain Saw 20" Bar Logo
90 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
