Question about Gateway Computers & Internet
Gateway zx6971 wifi does connect to a network
  • Anonymous Nov 30, 2013
    Dont worry just call Here to get your router fixed
    1-855-219-3333
4 Suggested Answers
  • 95 Answers
SOURCE: Quick question regarding the Gateway Solo 9550
Try clearing your winsock///Click start...Go to run..type cmd....Then type netsh winsock reset. Computer will say need to reboot but not nessasary
Posted on Apr 04, 2010
SOURCE: Gateway ZX6971 touch screen not working in window 8
i have same computer.they do not have application for touch on thia version yet.they are working on it and when available you can download from gateway download tab.
Posted on Oct 31, 2012
  • 25 Answers
SOURCE: gateway ZX6971
either way hdmi will be the easiest otherwise u have to buy a new cable for vga and go hdmi on tv
Posted on May 17, 2013
How to connect lexmark all in one x3550 printer to a gateway zx6971 desktop
Hi, you need to have the cable that goes from the back of the printer into a usb socket on your pc. You should have got two cables with the printer the power cable to supply the printer and another cable that also goes into the printer and the other end usb goes into a slot in your pc that's how it transfers info printer to pc. You should have got an installation printer disk that you have to install into your pc so that you can pull the printer up on your pc and they both recognize each other.
Mar 06, 2016 | Gateway " 23"" Touch-Screen All-In-One...
Gateway zx6971 no signal
Let's see if anyone else has a suggestion, but it sounds a bit like the DDC info is not being transferred correctly by the monitor OR you have a bad graphics driver. You should try and boot up in Windows Safe-More by pressing f8 before the windows logo shows on the screen during the boot process. if this does not help, I would suspect hardware malfunction, which means you should connect another known working screen to the computer for testing.
Mar 27, 2014 | Gateway ZX6971-UB30P 23 Touch-Screen...
Name and passsword belkin f7d1301
  1. Choose a laptop or WiFi device that is currently connected to your network. If none of your devices are connected, use an Ethernet cable and connect a computer or laptop directly to your wireless gateway.
  2. Open a web browser and go to the Admin Tool (http://10.0.0.1) - this is the wireless gateway's administration site. The default settings are:
    • Username: admin
    • Password: password (case-sensitive)
    • Note: If you changed your Admin Tool password previously, you will need to use your new login information. If you don't remember your Admin Tool password, you will need to factory reset your wireless gateway. Instructions on how to do this can be found by reviewing the wireless gateway user guides at Wireless Gateway Guides.
  3. On the left navigation menu, select Gateway, then Connection and then Wi-Fi.
  4. Under Private Wi-Fi Network, you'll see the Name (SSID) of your WiFi network. (You may want to write down this information.)
    • Wireless Gateway 1 customers, click EDIT at the right.
    • Wireless Gateway 2 customers, click EDIT for both 2.4 GHz and 5 GHz bands to view the settings for each. ?
  5. Check the box next to Show Network Password. The Network Password (Network Key) will be displayed above. (You may want to write down this information.)
    • On this page, you can also edit your wireless network information, including changing your Network Name (SSID) or Password (Network Key). If you make any changes, remember to click SAVE SETTINGS.
  6. Now that you have your Network Name (SSID) and Password (Network Key), you can connect your WiFi devices to your network.
  7. If you have changed any information, use the new information to reconnect all your WiFi devices to your network.
Learn how an XFINITY Internet subscriber visiting your home can connect to WiFi without sharing your Network Name (SSID) or Password (Network Key)
Jan 04, 2014 | Linksys Wireless-G Broadband Router
How do I remove the back of my Gateway ZX6971-UR30P. I have a cd stuck in the disc drive and the door won't open.
Have you tried to use a straightened out paper clip to eject the disc. You should see a small hole next to the eject button on the disc drive, just push the paper clip in that and the drive door should open.
Sep 11, 2013 | Gateway ZX6971-UR30P 23-Inch All-in-One...
Gateway zx6971 has a in HDMI port BRAVIA HDTV has a VGA and HDMI ports How do I CONNECT my P.C to the T.V
May 04, 2013 | Gateway Zx6971-Ub30p 23 Touch-Screen...
Oct 25, 2012 | Gateway Zx6971-Ub30p 23 Touch-Screen...
Can you upgrage the motherboard in a Gateway ZX6971-UB10P
you can do it , Only need to buy it. But your must sure that you can the skill for to do that. Or go to the repair shop.
God bless you
Sep 27, 2012 | Gateway ZX6971-UB10P Intel PENTIUM G630...
When I try to connect via my home wifi network, the error message "No gateway found" appears. I have put in the WEP key.
You would receive this message when you are trying to connect to a wifi network if any of this is the problem;
1. The wifi network you are trying to connect to has a connectivity problem and hence you are having that error message.
2. The wifi is available but has not connectivity to the internet.
Sorry this possibly means that your home wifi network has some problems.
Regards
Aug 16, 2009 | Nokia E71 Smartphone
My wireless laptop gateway won't connect to my router again after going out of town using it at hotel and now it wont connect at home. it will connect on my job with no problem
Hi!
It is possible that the wifi networking where you connect in the Hotel use the same name of you home wifi network!
Try deleting your wifi profiles and reconnect again.
If you don't know how to delete the wifi profiles let me know and I tell you.
Thanks!
Feb 18, 2009 | Gateway MT3705 Notebook
Computers & Internet Logo
52 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
