Static in speakers when treb in turned up and volume above 50%
Static from jenson marine stereo when treb is turned up and volume above 1/2 way. swapped speaker same problem
    President:
  • 1,348 Answers
The output ic is cooked. it is upc1130h2 or similar.
these chips are floating ground.do not ground one speaker lead.
outputs are typically 7 dollars.
it is mounted to the aluminum heatsink inside.you need to desolder and resolder the pins,and then solder in the new one.
special heat sink compound has to be applied,or it will go very quick
Posted on May 09, 2009
My dual marine radio will only allow the volume to go up to 27 then cuts off. why?
Hi Charlene
This sounds very much to me like a speaker impedance issue.
The first thing I would check is the impedance (ohms) of your speakers. These are usually 8 ohms, but may be 4. If 4 ohms is the case, then your receiver is cutting out to prevent letting the smoke out of it. Eight ohm speaker replacement will fix the problem.
Hope this is helpful
-Steve
Apr 03, 2016 | Boating
How do I adjust the fade on the stereo of my 1996 Toyota Camry DX V6? it says "PULL FADE" underneath the BASS and TREB, but those nobs only effect the Bass and Treble.
Jim Norton Toyota of Tulsa, Oklahoma: 2012 Camry Adjust ...
? 0:54
https://www.youtube.com/watch?v=ghwosvmNxkk
Feb 8, 2012 - Uploaded by Jim Norton Toyota
Jim Norton Toyota of Tulsa, Oklahoma: 2012 Camry AdjustSound Qualities ... Toyota Tacoma Stereo Install with Bluetooth - 2005 to 2011 ...Missing: 1996
Stereo not balanced in 2015 Camry XSE - Toyota Nation Forum ...
www.toyotanation.com > ... > 7th Generation (2012+)
Apr 14, 2015 - 15 posts - ‎11 authors
I noticed that I can hardly hear my rear speakers in my 2015 Camry XSE. I have adjusted the fade control from the center position to the rear position. ... dash speaker on the driver's side, regardless of how I adjust the sound. DIY - How to fix a flakey volume control in a 2001 ...
Sep 25, 2012
DIY: 1996 Camry Power Antenna Replacement Procedure
Jan 18, 2009
AUDIO: What does ASL stands for while we adjust the ...
Jan 20, 2008
no sound from rear speakers
Mar 18, 2007
More results from www.toyotanation.com
Jan 15, 2016 | Car Audio & Video
Car stereo problems
Do you have an amp? Remote wire might have come loose and the amp is telling the speakers to stop playing. Or, you might just have a setting problem, like it\'s turned on to just the rear and the rear is set to sub. Try dinking with the settings and running flat eq....(+/- 0 on bass treb and mid). If not, then there is a master plug in the back of the system: unplug and plug back in. If none of this works, trace the speaker wires back and make sure they are connected and not melting somewhere hot.
Jun 17, 2013 | Car Audio & Video
Why would my car stereo sound staticky when i give it volume'',it was not like that earlier
first adjust the fade and balance, checking each speaker for this issue. if they all continue to cause static when turning up the volume, then it is either the connections are crimped poorly, speaker connections are not secure at speaker or just a faulty volume control knob
Feb 23, 2010 | JVC Car Audio & Video
Stereo cutting off when volume is over 29
Twenty nine sounds pretty loud to me. A shorted voice coil in any one of your speakers will drop its resistance value so if the amplifier thinks its feeding a short circuit, will "protect" itself by shutting off. Check wiring carefully and each speaker at a little lower volume for sounds of distortion ie: shorted voice coils...
Jun 27, 2009 | Kenwood Marine Receivr/Speaker CD/MP3/WMA...
Roland keyboard. Extremely static-y speakers. Cuts out.
It sounds like your volume slider is dirty. Try carefully and judiciously spraying a good quality contact cleaner into the slider and working it. do not use a lot. It only takes a little. Also do not use WD40.
Mar 01, 2009 | Roland Juno-D
When volume is turned up the radio shuts off
Have you checked all of the connections on the speakers, stereo, etc. Being a marine CD player, the wires and connectors are exposed to more elements than a car CD unit. Check for corrosion and make sure that all the speakers are hooked up to the correct "+" and "-" terminals. Not sure if this will help, but thought I'd try. It does sound like a speaker connection problem.
Aug 30, 2008 | Clarion M255 AM/FM Marine CD Player
Stereo static
shut down all electrical sets around and check if the static goen the problem will be in electrical sets and you have to check it one by one.if it is not solved check your cables for any bad connector -open circuit- short circuit(try with a couple of new cables).-apply a contact cleaner in all sockets and move jack in and out in all sockets(with no power on)
Jun 12, 2008 | Audio Players & Recorders
Car stereo static
Sounds like you may have an output transistor/module about to go out.
May 10, 2007 | iLO XM-MP3-CD Car Stereo
64 people viewed this question
 Grubhead
Grubhead
