Question about OCE Office Equipment & Supplies
OCE Varioprint 110 shows error code 6132
Can anyone give advice what does that code represent and how can it be get rid off? (For example which counter in service mode needs to be reset since sometimes technician forgots to do it)
  • JMJr Jun 24, 2014
    Hi Maros Klamar, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? Was the machine printing when the code came up?
  • Maros Klamar
    Maros Klamar Jun 25, 2014
    thanks for your concern, but luckily problem was already solved, the code pop out to the screen always during initalization, so no, printer wasnt printing
Copiertech
  • 16 Answers
SOURCE: error code
Hi Sorry cant send manual U have to buy like every one else.But here are the codes you require It is service code 24 sub code 04 to reset PM counter and sub code 07 to rest drum sub code 09 to reset print count and sub code 11 to reset developer. Hope this helps
Posted on Aug 22, 2007
SOURCE: OCE TDS600 Error Codes
It might need a new fuse which is located where the hot wires are when the paper feeds through or it might need a circuit an Ormon G3NE-220 TL-US load 20A 240VAC 50/60hz input 24 VDC.
Posted on Aug 31, 2009
Soulvisitor
  • 1113 Answers
SOURCE: Minolta Error code C0500
1. Test Mode Operations
• The Test Mode is performed from the copier’s Tech. Rep. Mode.
1-1. Entering the Tech. Rep. Mode
1. Press the Utility key.
2. Touch [Total Check].
3. Press the following keys in order: Stop → 0 → 0
→ Stop → 0 → 1.
NOTE
Be sure to keep the display procedure for the Tech.
Rep. Mode from any unauthorized persons not
involved with service operations.
4344S504CA
link to a service manual that explains tech mode
Posted on Dec 02, 2007
SOURCE: oce tds 800 how do you reset the counter for maintenance and part
hi
you have to go into service first
you have to log on in SDS
WITH user :oceservice
pASSWORD:675756
And there on consumbeles you have to reset by
pressing 0 / enter and than egnoladge with the green V on top
good luck
Yaacov
Posted on Mar 08, 2010
wheatlandsvc
  • 1110 Answers
SOURCE: My Oce im2520f is giving me an error code: C0500
The C0500 error code is a fuser unit error code. The fusing unit is the part that gets hot and "fuses" the toner onto the paper just before it exits the machine. There is a special reset procedure for this code so as to prevent overheat of the fuser. You will need a service technician to diagnose the problem in the fuser and then reset the code. Most common causes are blown thermal fuse, bad thermister or rarely, a bad heater lamp.
Good Luck and Thank You for using Fixya.
Posted on Mar 19, 2010
Oce Plotwave 345 with error codes 22514,22553,8532 can't find a service manual for this
There is nothing you can do, even if you had the service manual. The first two error codes deal with power supply issues and the last one deals with the fuser section, which may be related to the initial problem of power issues. I would recommend you call an authorized Oce/Canon service representative to determine what exactly the fault is. This printer is a new model, and there is not likely parts available outside of official Oce/Canon logistics.
May 22, 2017 | OCE Office Equipment & Supplies
What is the error code 1571 on a Varioprint 110
The scanner fails to reach the target speed of rotation 10 sec after the laser scanner motor reaches constant speed state. Causes - The laser scanner motor is faulty. The DC controller PCB is faulty. Remedy 1. Laser scanner unit, DC controller PCB Try replacing the laser scanner unit. Is the problem corrected? YES: End. NO: Replace the DC controller PCB.
Dec 08, 2014 | Canon Office Equipment & Supplies
Oce tds error code 12502
Error 12501, Error 12502, Error 12503, Error 12504, Error 12505, Error 12506, Error 12507, Error 12508, Error, 12509, Error 12510, Error 12511, Error 12512, Error 12513, Error 12514, Error 12515
Error codes related to External Paper Input Module
Oce VarioPrint 110
Oce VarioPrint 120
Oce VarioPrint 135
Apr 28, 2014 | Office Equipment & Supplies
Error code on oce colorwave 650
It is a printhead or "imaging device" issue. Call your authorized Oce/Canon service representative. These printheads are proprietary and not available outside of official channels. If you find one outside of official channels be wary of the quality. If there is a a color in in the tube of where the toner pearl goes in, it is a used head and can not be used in any other color except the one that it was originally intended.
Apr 12, 2014 | OCE Office Equipment & Supplies
TDS600 Error Code 08005
This has to do with one of the thermistors in the fuser section. I would recommend you call an authorized Oce/Canon service representative. The part is delicate and difficult to replace.
Apr 02, 2014 | OCE Office Equipment & Supplies
Oce Varioprint 6250 is telling me I have paper in the Preheat Unit and TTF. Everything is cleared but it won't reset.
To reset turn OFF tghe copier press and hold the Utility key and turn ON the copier and wait then the display scree trouble reset.Touch the screen and turn OFF the copier,wait 1 minute and turn ON.
Feb 20, 2013 | OCE Office Equipment & Supplies
Hi, our oce variolink 2822c suddenly began to show; "malfunction detected. inform the service representative of the error code", trouble code: c- 3721. Unfortunately service representatives...
Your machine is made by Konica Minolta. The C3721 code means that your fuser unit has detected an overheat condition. The fuser unit is the assembly that uses heat and pressure to "fuse" the loose toner onto the paper. It is located right where the copies exit the machine. Your are going to need to have your local service company come out and make repairs. You may get advice as to how to reset the code but beware. Since this is an overheat code, if you reset it more than once you can do severe damage to your fuser unit. You may turn a simple and relatively in-expensive repair into a major one.
I would waot if at all possible for the service technician, but I have only worked on Konica Minolta copiers for nearly 28 years now.
WheatlandServices
Jan 22, 2011 | Office Equipment & Supplies
I need a manual for an Oce VarioPrint 1550 copier
go to www.oceusa.com, press support & drivers, find model in drop down
Nov 06, 2009 | Office Equipment & Supplies
Jul 13, 2009 | OCE Office Equipment & Supplies
464 people viewed this question
Top OCE Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
fares
Level 1 Expert
Are you an OCE Office Equipment and Supply Expert? Answer questions, earn points and help others
