Drum won't spin, drains ok and agitator works fine
Washer works fine until it gets to the spin cycle. Agitator works, drum won't spin. Whirlpool LA5243, 2 speed, belt drive.
    Genius:
  • 1,198 Answers
Http://www.pcappliancerepair.com/model-display.php This site shows your lid switch. Just enter your model number. The lid switch is the usual suspect for your symptom.
Posted on May 09, 2009
Whirlpool washer does not spin
Try taking some of the wet clothes out maybe to heavy
Jan 15, 2016 | Whirlpool Washing Machines
Know when clutch going bad
Needs agitator dogs in agitator.
Mar 13, 2014 | Whirlpool Washing Machines
The agitator works well during the wash cycle. When the drum spins, the agitator will not if the clothes touch the agitator. The water empties, but the agitator prevents the drum from spinning.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the following Whirlpool Service manuals for top load, direct drive washers. They describe what happens in the transmission when the washer goes into spin mode:
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
Also see the Whirlpool Parts list for their Commercial washers, although the consumer models use the same transmission.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Basically whats happening is this.
When the washer goes into spin mode two plastic cams are forced together and raise a gear on the main agitator shaft that is supposed to keep the agitators from spinning. If the cams are worn (not necessarily broken) the gear doesn't lift high enough to completely disengage the agitators. We had the same problem. Ours was a major gear noise but a clicking could also be a symptom as well as the agitator keeping the drum from spinning. A set of Whirlpool Agitate Cams (part number 62580/01) cost about $15.00.
It's a bit messy to fix (15 oz. of 80-90 weight gear oil in the transmission available at auto parts stores) but very inexpensive.
See the following for how to remove the transmission.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators.
The top agitator uses a plastic 1/2" drive bolt. A 1/2" socket extension works well.
You don't have to remove the drum.
You can also see this site for removing the transmission.
ILLUSTRATED DESCRIPTION OF REMOVING CABINET THRU TRANSMISSION.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 15 Oz of 80-90 weight gear oil. (Available at auto parts stores)
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
I'd also check the Motor Coupler (a $15.00 item that tends to wear) while you have the transmission out.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
Jan 20, 2011 | Kenmore 22422 Top Load Washer
Agitator does not turn ..... you can hold on to & it doesn't turn in wash cycle
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
If you move the timer to the spin cycle and the washer drains and spins, the motor coupler (A common replacement part) is OK.
This points to one of two possible solutions.
First, I'd remove the agitator(s) and look inside at the splines inside the agitators and at the splines on the main agitator shaft.
Here is a description of how to remove the agitators. Your washer may be a bit different but the Sears site should help to determine how to do it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=7a980a8b05b84ff3b7ee1c8ba46e2ae8
If yoy have a two piece agitator and only the top section doesn't agitate, the problem is likely the agitator "dogs" as described in the illustrations.
If the Agitator splines are worn or damaged, You'll have to replace the agitator.
If the splines on the transmission agitator shaft are worn, you'll probably need a new or rebuilt transmission.
In addition, see the following Whirlpool / Kenmore service manual and parts list for their commercial washers (consumer models are basically the same).
Oct 28, 2009 | Kenmore 24032\24036 Top Load Washer
Noise when stopping after spin cycle or open lid (after moving)
check hub nut, it is likely loose, its under the agitator. top pops off agitator and bolt hold agitator down.
Jan 04, 2009 | Whirlpool Inglis IP4400 Washer
Washer will fill with water but the agitator won't spin.
No agitation or spin in any cycle? If so and the machine will drain check the coupler.
Oct 08, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool washer LSQ9549LN0 problem
you have a problem in the transmission of the washer
May 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
155 people viewed this question
Top Washing Machines Experts
