Blackened monitor screen
A year or two ago i spilled hair product on my laptop and my laptop completely stopped working and the screen turned black, it wouldn't even respond to anything. i recently found it on my shelf again and i turned it on to find this, are there any solutions? thank you.
    Top Expert:
  • Computers & ... Master
  • 34,836 Answers
Repair or replace. It may not be worth repairing.
Posted on Nov 28, 2013
4 Suggested Answers
  • 4 Answers
SOURCE: Black Screen-No picture
Normally when an LCD monitor goes black, it is because the inverter goes out (which essentially is the backlighting).  To verify this problem, hold a flashlight up to the monitor while it is turned on and see if you can "see" the picture.  If this is the case, it could be repaired, but realistically, the cost to replace it might be cheaper (and you would probably end up with a larger monitor to boot).
Posted on Jan 01, 2008
SOURCE: monitor goes black 1 second after coming to full screen
Same problem here. Does anybody have an answer?
Posted on Jul 17, 2008
  • 33 Answers
SOURCE: Screen goes black but power light stays on
Hello. I had the same problem with my X2gen 19" (model MW19R)monitor. In my case, the monitor would turn off after 20 seconds or so but the blue power light would stay on as well. I had to replace a high voltage capacitor located in the backlight power supply board. There are 4 blue capacitors on the board which are identical and they are marked as 27J 3KV. Fortunately, I only had to replace one of these capacitors ( it was turning a yellowish brownish color ). Hope this helps.
Posted on Aug 09, 2009
How do u fix a black screen of ***** on laptop
hi does it work if you plug in another monitor through vga port. if it doe work with other monitor then check display setting in control panel and see if it set to your main screen. i hope it works. i tried this a couple of years ago and that my screen was actually dead.
May 17, 2016 | Acer Aspire Computers & Internet
Latitude B130 screen works great then cuts out to complete black, works with external monitor
Are you sure that the display is not set for external monitor only? Also take bright flashlight and shine on the display. If you can see the images then the problem is with the back light and usually caused by a bad inverter. Some times you can get the back light or inverter bu most times it is easier and cheaper to replace the entire display.
Aug 20, 2012 | Dell LATITUDE Computers & Internet
Toshiba Satellite L455-S5000 monitor blackout but works w an external monitor
This is a tricky situation, any fluid that ends up inside can cause a cascade effect, hours, days, weeks and even months before the full efects are known. You could end up changing the screen and down the road face major failure in the motherboard. Under the circumstances I would consider a laptop replacement.
Mar 13, 2012 | Toshiba Computers & Internet
Laptop monitor blacks out but works fine with an external monitor
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Mar 12, 2012 | Dell Computers & Internet
My acer KAV 60 screen is not working. the hard drive boots and it charges but nothing happens on the screen. It just remains black. I did't drop it or spill liquid on and it's only a year old.
In order to check what is really not functioning. Your laptop have a video port for external monitor which is color blue often at the lower back of your lcd screen or at the side. Plug the CRT or LCD monitor to your vga(video graphics adapter) port to check if your laptop is still functioning. If there is a display on your external monitor that means you have to replace your lcd monitor. If there is no display with external monitor check your memory or ram by unplugging your memory then clean it with a hard eraser the memory pin and then put it back again and turn on your computer to test if already functioning. If the above procedure didn't work you have to bring it in a computer repair shop. Have a good day!
Dec 20, 2010 | Acer Aspire One PC Notebook
Laptop Monitor shows balck and white stripes
From what i can barely see it your photo it looks like your video chip  (which is part of the motherboard's chipset) has died. It will be expensive to replace the motherboard.
To recover all your data is easy - just remove the hard disk from the laptop, put it in a case like one of these
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010010092%201053807124%201054107131&name=SATA
then connect the case to another pc.
Mar 26, 2010 | Toshiba Satellite A105-S4084 Notebook
My LCD screen stopped working. Playing a game when the monitor was blackened. This time the screen is black. If I start the monitor, the led is orange, if I connect to my PC led color turns green but does...
victorash02, Is screen black n blank, or just black? Do flashlight test! Yes it could be both! Most likely problem with unit's internal "switch-mode-power-supply"/"CCFL inverter supply". You or technician will need to investigate for probable cause of black screen of death. Need a little history of unit! Did it work just fine 2 weeks ago? How many "ON" hours of use on the unit? When was it made? Did you PROVE that PC not cause and works ok? Get back here with more info so we can help.
12fixlouie on fixya. Read my fixya profile for a little while.
Mar 09, 2010 | BenQ FP71G 17" LCD Monitor
Laptop monitor out afte spill
Could be a few things destroyed something on the motherboard or on one of the wires leading to the screen. if you heard a sizzle take the keyboard off and the wires for the screen are usually right there see if any are burnt and look for puffed up fuses.
Tip for next time if you get an electronic device wet remove battery dry completely before putting battery back in
Sep 19, 2009 | Computers & Internet
Got spilled by water
Uh, oh, sounds bad, probably didn't get all the water. Also, you really have to open things up and let dry for several days(I leave things dry for a week, before attempting to power up). Open it again, do it quickly, I've never used a hair drier before, hum, I'd just leave it opened up(as long as it was just water that is). You need to get it opened up as completely as you can. Just try not to get impatient with it.
Mar 16, 2009 | Toshiba Satellite A100-S8111TD Notebook
Can't get my laptop to display on a monitor.
Most laptops require you to press the Fn (Function) key and another key on the keyboard to activate the external video port, not too sure which button on your model it is, but it should look like a monitor.
Other than that it could be your board is fried. Which will need replacement/ repair.
Dec 10, 2008 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
166 people viewed this question
David Payne
David Payne
