Question about Sony Playstation 3 (PS3) Console
Ps3 turns on then off
Turns on then turns off with the red light flashes with two beeps
    Master:
  • Sony Master
  • 665 Answers
It could be a corrupt file partition in your HDD. Have you upgraded to the newest firmware from PSN recently? If so, it could be the problem. You will have to download the latest firmware from PSN website onto a thumb drive, then start your system in safe mode. There are several videos on youtube that explain how to do this in detail. Good luck. ^^
Posted on Dec 06, 2013
  • 4 Answers
SOURCE: PS3 TURNS ON THEN CUTS OFF FLASHES RED
Usually that means your fan or anthor device inside your ps3 has stopped working it has done it to me unfortnaully the only way to get rid of this is to send it to sony 150$ or buy a new ps3 :(
Posted on Apr 12, 2009
  • 85 Answers
SOURCE: Flashing red light and cannot eject game
PS3 has overheated and the thermal compound between the cpu/gpu and heat sync need to be replaced. the gpu and cpu may need to be reflowed as well. Had the same problem and fixed mine. The thermal compound was pretty much gone when i opened up the system. Also dont keep your ps3 on its side leave it flat this will help keep the compound from moving as much.
Posted on May 18, 2009
SOURCE: From standby PS3 wont turn on.
that sounds like your main power supply unit
Posted on May 29, 2009
ryanamontos
  • 60 Answers
SOURCE: My PS3 wont turn on it just flashes a yellow light
I found a way to eject the disk:
  1. Power off the PS3 on the main switch on the back of the console
  2. Press and hold the Eject button
  3. Turn on the main power switch
  4. The PS3 LED will go green and the fan will spin at max speed
  5. Wait a few seconds and press the eject button a couple of times, the disk should now eject
  6. watch the PS3 die after 30s or so…
This procedure did not fix my PS3 but at least I got my disk back before sending it to Sony for repair.
Posted on Jun 10, 2009
Killen4fun
  • 46 Answers
SOURCE: ps3 wont turn on, jus beeps 4 times an red light blinks
This could be any of a number of problems try these solutions one of which may work. If they all fail to work you can contact sony directly at
http://www.uk.playstation.com/Support/PS3
or
http://www.us.playstation.com/support/PS3
  • Remove any obstructions from the vents.
  • Allow at least 4 inches of clearance on all sides for the PLAYSTATION 3.
  • Remove the PLAYSTATION 3 from any cabinets so it is out in the open.
  • Shut the PLAYSTATION 3 down completely and let it cool down to room temperature, then try running it again.
  • If the fan cannot be heard before the system shut down, the PLAYSTATION 3 may need to be sent in for service.
  • If there is no airflow from any of the vents, the system may need to be sent in for service
Hope this helps.
Posted on Jun 24, 2009
I turn on my ps3 and the green light comes on for a short time and the it beeps three times shuts off and the green light turns red and starts to flash. If I push the power button again the red Light
you need to change your power box there is a bad connection with the wires. its over heating you might whant to buy another at game stop or take it in to get fixed. the more you messed with it it might mess up your whole system.
Aug 18, 2012 | Sony Playstation 3 (PS3) Console
Ps3 80g light turns green flashes yellow, then
Unfortunatly your ps3 is dead, I am sorry for your loss.
Jul 12, 2010 | Sony Playstation 3 (PS3) Console
Ps3 wont stay on
charge it red light turning of and beeping is meaning its dead
Mar 02, 2010 | Sony Playstation 3 (PS3) Console
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
My ps3 it goes green beeps twice then goes red and flashes on/off
you might be holding the power on button to long. you hold the power on button until it beeps to reset the video output. try turning it on by using your controller. just press the ps3 button and if the red light is on then it should come on.
Oct 14, 2009 | Sony Playstation 3 (PS3) Console
May 28, 2009 | Sony Playstation 3 (PS3) Console
Ps3 problem
if it wont load your icons and freezes before your xmb, put it into safemode and try restoring the filing system. to get it into safemode...
hold down the power button while the console is in standby. the light will go from red to green.it will beep once flash green beep again, and then beep a third time. after the third beep the light will turn red.
once the light is red, take your finger off the power button and place it back on the power button. the light will go from red to green, beep once flash and then beep twice quickly. after it does the double beep, take your finge roff. the light will stay green and you'll get a screen asking you to connect the controller.
after connecting the controller, try option 3, or whichever option is restore filing system. this can possibly correct media loading and will 95% of the time fix the console when it freezes before loading up your icons(the xmb)
May 03, 2009 | Sony Playstation 3 (PS3) Console
Ps3
insetad of restoring the filing system, restore the default settings ore restart the system
Mar 31, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
