Question about Whirlpool Accubake SF362LXTS Kitchen Range
Oven does not maintain set temperature.
Oven will warm up to set temperature and shut off. It will not relight to maintain that termperature and must be relit by pressing cancel and then start after the temperature has dropped to below 200 degrees.
  • Bill Haldeman
    Bill Haldeman Nov 29, 2013
    Thermostat and both circuit cards have been replaced by repair service. Oven still will not maintain set temperature.
  • 2,113 Answers
It's time for a new thermostat
Posted on Nov 28, 2013
  • 213 Answers
SOURCE: When oven is baking, control resets
theres a loose conection on the oven control more than likely its internal and youll need to replace the control but check you wirs to the control first just incase the bad conection is there. if its not, replace the oven control
Posted on Nov 25, 2007
  • 2692 Answers
SOURCE: oven not maintaining temperature
Yes
Posted on Jan 08, 2009
brnspncr
  • 67 Answers
SOURCE: Oven door will not release after cleaning
Try waiting until the oven is COOL, then switch the power off to it , wait 20 seconds and switch the power back on?
Posted on Jul 29, 2009
jumptrout51
  • 3361 Answers
SOURCE: Oven not heating to correct temperature
Replace the oven glowbar ignitor. It is too weak to keep the gas valve open.
Posted on Aug 19, 2009
jumptrout51
  • 3361 Answers
SOURCE: head a popping sound and oven temperature doesn't work
Most likely a bad element. Turn off the power to the oven. Remove the racks. Use a phillips screwdriver or 1/4 inch nut driver to remove the mounting screws at the back of the oven cavity to remove the element. Carefully pull the element out and remove the wires. Do not let the wires fall back into the holes. Use a volt meter set for continuity. Touch one meter lead to one terminal on the element. Touch the other meter lead to the other terminal. If you get NO reading the element is bad. A new element will correct your problem. If the element reads as good you have a wiring problem or a bad control.
Posted on Jan 04, 2010
Testimonial: "Although I have not yet tried what you recommended (my boyfriend will), the answer was quick and comprehensive. Thanks"
The oven comes on an heats up to temperature , after a short while the oven no longer continues to heat. The contol panel shows on in bake mode , but the oven continues to cool.
Hello Brian;
You did not provide any information on the unit that you have. After you open the oven door there is a metal label on the face of the oven. Send that to me so I can see what you have.
1.) Some ovens have a single or dual broiler thermocouple.
2.) Some ovens have a separate control board for the oven.
3.) Some ovens have a Infinite switch.
Mar 21, 2015 | Kitchen Ranges
Head a popping sound and oven temperature doesn't work
Jan 04, 2010 | Whirlpool Accubake SF362LXTS Kitchen Range
What does F2 mean
F2 means that the oven temperature has exceeded 590 degrees with the door in the unlocked position. There is high resistance or interference in the oven termperature sensor. Replace the oven temperature sensor.
Nov 18, 2009 | GE 30" Self-Cleaning Freestanding Electric...
Kenmore SF367.....Contantly relighting during cooking?
This is a normal function of your gas range. I own a similar model and it operates the same way. The gas is not required to be on continuously to maintain the oven temperature and will relight periodically when the internal temperature drops below the prescribed set level.
Jul 04, 2009 | Whirlpool SF367 Gas Kitchen Range
GE JKP26GOP1BG Electric Oven won't maintain temperature
You will need to replace the temp probe Call704-891-6557 we'll tell you how to do it safely.
Mar 14, 2009 | Ovens
Whirlpool Accubake SF362LXTS Kitchen Range Logo
115 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
