Question about Dell Dimension 3000 PC Desktop
I have upgraded my hard drive from pata to sata using the ide to sata converter I don't no what went wrong but my diagnostic lights are reading A B C are solid green D is solid yellow and i am getting nothing at all but power to pc no power to my monitor Please Help
  • 2,113 Answers
You may have to reboot a few times to update the bios with the new card. But there is probably an IRQ problem between the 2 cards. To fix this move the sata card over one slot and try booting again maybe 2 or three times.
Posted on Nov 28, 2013
4 Suggested Answers
  • 77 Answers
SOURCE: Can i Install PATA hdd on Dimension 4700
I'm sorry, but I couldn't wade through this bunch responses, so I'm going to give you my own.
You have 2 sata drives installed, already, so you cannot add an additional one w/o a bunch of wonky adapters, so use the IDE channel. You say you have an IDE rom drive. Well, there's a reason there are 3 connections on an IDE cable. One side goes into the motherboard, the other 2 into your drives. The motherboard side is the one furthest away from the center connector. I assume you have the primary connector connected to your rom drive. the 2ndary one would be on your hdd. Why people asked you why you're doing this is beyond me. It works, you'll have an extra drive, your preference. Whatever.
Let me know if you have any more inquiries.
To answer your questions from your original post directly, the other 'ide' channel is specifically for a floppy disk You CANNOT connect an IDE cable to it. And yes, you can connect an  hdd to the slave port on the ide cable.
Posted on May 01, 2008
MDoe
  • 156 Answers
SOURCE: Dell dimension 3000 hard dirve what type do i need to install a sata pata or ide
Hi
Dell Dimension 3000 accepts IDE hard drive. Any modern IDE drive should be fine
Check out Dell Dimension 3000 Service Manual for spec and how to remove and install parts.
Mike
Posted on Aug 21, 2008
  • 166 Answers
SOURCE: I am having trouble installing a second hard drive
Have you enabled the drive in the BIOS yet?
To do this hit F2 when it starts up and then go down to drives. Hit enter and then locate the SATA port that you have it in and turn the drive on.
Let me know if this works or not. If it doesn't, give me additional details and we will try to fix it.
Posted on Apr 30, 2009
Is a ide a hard drive
You should check what kind of hard drive is using your computer. If it has less then 5 years probably hard drives are sata.
watch this tutorial
Instructions on USB To SATA IDE Adapters Cables
How to connect SATA devices in PATA IDE only PC system
Modding Guide Inline SATA Connectors
How to connect an IDE drive to SATA motherboard
Jul 22, 2015 | Hard Computers & Internet
Tip
How to connect your hard drive to your motherboard The first thing you have to...
The first thing you have to figure out is what type of hard drive you have, a PATA or a SATA drive.
PATA = Parallel ATA
This type of drive uses the older IDE connections. Most of your current motherboards still have aleast one IDE connection to support the ROM drives on the market that have not moved over to SATA connections but you can still connect a hard drive to this connection if needed. The thing to keep in mind is that you can only connect 2 IDE devices to one IDE connection on the motherboard.
Here is an example of an IDE cable. If you can see there are tabs on the cable to make sure you line up the pins properly.
SATA = Serial Advanced Technology Attachment
This type is now the standard that most hard drives are. Also note that alot of your ROM drives are switching over to this format as well.
Here is an example of a SATA cable.
In regards to power connectors If you are using a PATA drive then you will use the Molex power connector. Note some of the early SATA drives use this power connector as well.
For the SATA drives you would use the SATA power connector. Note if your power supply does not have this connection you can get an adapter that goes from a Molex connection to the SATA connector.
Next you will need to find the connectors for the hard drive on your motherboard. Below if pictures of the 2 connection types.
IDE/PATA motherboard connectors
SATA motherboard connectors
on Sep 01, 2010 | Computers & Internet
Diagnostic lights
I know this is old, but I think maybe I can help someone who is having a similar issue. I assume they were using some kind of IDE to SATA convertor from the motherboard header (the place where it plugs in on the motherboard) or an SATA to IDE convertor on the drive itself. It is probably not working or the mainboard can't support it. Here is the answer from the manual referring to the diagnostic LEDs:
  1. Ensure that the cables are properly connected to the system board from the hard drive, CD drive, and DVD drive.
  2. If there is an error message on your screen identifying a problem with a device (such as the floppy drive or hard drive), check the device to make sure it is functioning properly.
  3. The operating system is attempting to boot from a device (such as the floppy drive or hard drive); check system setup to make sure that the boot sequence is correct for the devices installed on your computer.
  4. If the problem persists, see "Contacting Dell" in your Owner's Manual for instructions on obtaining technical assistance.
These convertors are pretty straight forward. It's probably better to get an internal PCI SATA card and hook to that. There are a couple of advantages to a SATA card--
  1. They can support the rated speed of the drive. If you have a SATA 3.0 drive (6Mb/sec) and you have a card that supports it, it should run nearly that fast.
  2. They usually support hardware RAID for more drives.
  3. They usually have eSATA ports and maybe USB as well.
As long you have the drivers to support it, it should be better.
Nov 28, 2013 | Dell Dimension 3000 PC Desktop
Sata pata ide hard
A sata drive doesn't need jumpers. The jumpers were only required when 2 drives used the same cable.
How do I choose a hard drive?
It depends upon where the hard disk is to be installed, ie. in a desktop computer, in a laptop or in an USB hard drive case.
A 3 1/2 inch hard drives can be a IDE/PATA or a SATA type. Older computers use IDE/PATA hard drives and the maximum size you can install in a desktop depends upon the computer's BIOS.
SATA hard drives are generally used in later model computers and the size of the hard drive is not limited by the BIOS.
A 2 1/2 inch hard drives are used in laptops and are available in IDE/PATA and SATA types. The size and limitations of IDE/PATA hard drives also apply to laptops. The same applies to SATA hard drives.
The choice and size of hard drive depends upon your requirements and how much you want pay.
Don't forget to check BIOS for the maximum IDE/PATA hard drive size you can install in your computer.
Aug 22, 2011 | HP Computers & Internet
Hard drive problem
New hard drive $40 to $60.. www.Tigerdirect.com www.frys.com www.bestbuy.com etc..
Main thing you need to know is SATA or IDE (aka .. PATA) Sata or serial uses small half inch wide cables . IDE / PATA uses 3inch wide ribbon cables. Pop the PC open andlook at the hard drive to see the cables attached. Most new drives come with basic instructions.
Feb 23, 2011 | eMachines T3604 PC Desktop
I HAVE IBM 8305-49U. Can this machine support IDE to SATA
IBM Netvista 8305-49U supports ATA-100 Enhanced Local Bus IDE controller. Sata is not supported. However, IDE to Sata converter can be used.
CreativeTECH
Jan 18, 2011 | IBM Computers & Internet
Can i use PATA hdd for this motherboard?
You could connect a PATA HDD to this using the IDE connector, which then means that you would need to either slave your optical drive on the same channel, or obtain a sata optical drive.
The other ( not recommended) solution is to buy an IDE / SATA converter and run the hard drive from a SATA port. I've never had any sucess with these adaptors
Dec 25, 2010 | ASUS P5GC-MX/1333 Motherboard
How do i convert my hard drive for my lap top they have different plug ins
Was your old hard drive a 44 pin IDE drive (PATA)? Then you need a 7 pin SATA to 44 pin IDE converter module. Unfortunately, I can't suggest any - most take up enough space that they can't be fit into a laptop case behind the hard drive. Some connect to the IDE cable; others connect to the IDE port on the motherboard. They are more useful for the small format desktop cases (home theater PC).
I wish that I could be of more help. 2.5" IDE drive are still available; this might be a more effective solution than finding an adapter that will fit inside the laptop.
Sep 23, 2010 | Seagate Momentus 54006 (ST9250315AS) 250...
Jan 23, 2008 | Dell Dimension 4700 PC Desktop
Dell Dimension 3000 PC Desktop Logo
81 people viewed this question
Alun Cox
