Behringer EUROPOWER PMH3000 has a loud white noise hiss on all channels when pushing in the effects button.
Behringer EUROPOWER PMH3000 has a loud white noise hiss when pushing in the effects button and is present on all audio channels.
3 Suggested Answers
SOURCE: Europower Beringer PMH3000 power turns on then turn off?
when you turn on the AMP and the red light comes on give the amp 2 seconds and turn it back on the red light should turn off. That is what I do with the amps at my church and it works for me, I hope that this works for you too.
Posted on May 12, 2009
caroldon
  • 17130 Answers
SOURCE: my behringer europower EP2500 poweramp has a bad
There is a possible noise build up on your CH2 due to failure or weakness of the LCR network of the preamp circuit. It could also be a noise within any semiconducctor or the preamp IC. Unless you can do a signal test with the elimination of the input to the output amplifier, the fault will not be say to isolate. Hence if youarre familiar do the test by approching from the output amplifier's input, proceeding to the main input where the faulty section can be identified. Hope this helps. Good day
Posted on Jul 18, 2010
How can I reduce white noise / hissing I'm getting over the mic on a Behringer Xenyx 1204 USB setup?
Hi, you didn't say if the mic actually passes sound? The C-1 is a condenser Mic & needs phantom power - switch on the rear of your mixer. If that's no help, what happens if you disconnect the mic, then turn the levels back up? Still hissing or gone? If it's gone then it's the Mic - must use a 3 wire cable, preferably XLR so it gets the phantom power. If the hiss is still there without the Mic then sounds like the mixer is faulty - try some of the other channels..... How loau is the hiss - just in the background or as load as a vocal "one, two" test? A few things to check anyway...... Good Luck!
Dec 01, 2016 | Behringer Music
Effects not working on Behringer PMP4000 monitor
Normally, on mixers, Effects do NOT go to Monitors.
What you have to do is
(check if there is a control for "EFF to MON" before)....
*Make a cable bridge from EFF OUT to any channel of your inputs.
*Now you can send the EFX to monitors as you would any signal.
Be mostly happy....
May 16, 2015 | Behringer Pmp4000 Europower 1600-watt...
All light blinking
Fix the short. It appears the 15 neg supply supplies the LEDs. If you need the service manual try: http://www.eserviceinfo.com/index.php?what=search2&searchstring=behringer+pmh+3000
Jan 27, 2014 | Behringer PMH3000 - EuroPower 2 x 400W...
Hook up external amp to the behringer pmh3000
You can do it if the desk has unpowered outputs (maybe the TLR outs on top?)
Jun 29, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
Need part # for the Program Push Button Control for the effects on a PMX2000 power mixer
You will have to call Behringer in Woodinville WA to get the Behringer part number. Their phone is:
(425) 939-3200
With the number plus an incident number that Behringer will give you, you then call FullCompass who is the parts distributor... Then, unless they have it in stock, plan to wait a long time to get the part. FullCompass phone:
800-356-5844
Lots of luck... I have waited for three months for parts.
Apr 07, 2011 | Behringer Europower Pmp5000 Powered Mixer...
My behringer europower EP2500 poweramp has a bad hiss on channel 2 What could this be?
Jul 18, 2010 | Behringer EUROPOWER EP2500 Amplifier
I get a constant noise after I plug in the guitar
The reason for the few seconds delay is that this amp uses a vacuum tube preamp which has to heat up before it operates.
Now with most amps at high gain you will get some noise, but it should be well below the level when you are running program material through it. The statistical electronic noise will be more of a hiss. If it is hum you are getting, then the filter caps MAY have failed. Also if you have light dimmers can sometimes get into the equipment.
First step is describing the type of noise. Behringer is VERY stingy on supplying schematics. Essentially they WON'T unless you are one of theior certified techs.
Your amp SHOULD be simple enough to fix without schematics UNLESS it has one of the Behringer digital effects. That board has a chronic failure of the DC filter cap.
Jul 22, 2009 | Behringer EUROPOWER EP2500 Amplifier
Behringer EP2500 amplifier channel crackling noise
Got asilimar problemwit a behringer europower pmh 3000.
my
The Right channel began to crack up and drizzle now it seems completely dead.
Changed the cables both of input and seapkers , still the problem stays the same. Any suggestion before brigning for a month at the repair shop? And get out with a 200-400$ bill ?
Apr 28, 2009 | Behringer EUROPOWER EP2500 Amplifier
Mar 25, 2009 | Behringer EUROPOWER EP2500 Amplifier
250 people viewed this question
 Grubhead
Grubhead
