Question about Toshiba Satellite C55-A5246 15.6" LED Notebook - Intel Core i3 i3-2348M 2.30 GHz - Satin Black Trax - PSCF6U-02D00C
Toshiba C55-A5300-15.6" does not charge
Brand new computer is plugged in and does not charge. meter says )0% available (plugged in), charging. yet it is not. it does charge for about 30 seconds after the screen turns back on, then it stops.
2 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: The toshiba laptop a505 S6980
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Posted on Apr 20, 2011
How disassemble a Toshiba laptop Satellite C55-A5302.
It can't be disassembled. It is a built as one unit.
Nov 06, 2016 | Toshiba Computers & Internet
Toshiba c55
Try just using the mains power. Remove battery an leave plugged in . If it works it's the battery/ power brick .
Dec 26, 2013 | Computers & Internet
It shuts off all the time. Battery meter says....0% available (plugged in, charging) all the time.
If your computer stays on with the charger you might need a new battery. I had a similar problem with my Acer PC, it turns out all i needed was a new battery. After i purchased the new battery and the new charger my laptop work perfectly. Hope this helps. Good luck
Sep 30, 2013 | Toshiba Satellite Computers & Internet
My Fujitsu AH512 A series laptop which is brand new, the battery will not charge, just shows 0% available(plugged in, not charging), can you help?
Is your power cord (power brick) outputting the necessary voltage and most importantly amperage? If not, your laptop should still be under warranty. Take it back for a replacement.
Aug 25, 2013 | Fujitsu LifeBook Computers & Internet
NEW Battery not properly charging
Batteries have electronics data that software has to get to properly charge it. Newer lithium batteries maybe different. But apparently, you have a work around for a lengthy use of the new battery.
Feb 16, 2012 | Gateway MD7818u Notebook
The toshiba laptop a505 S6980 will not charge the battery when the AC is plugged in and dies immediately if unplugged . Meters shows 0% available (plugged in), charging. But it is not really charging.
Apr 20, 2011 | Toshiba Satellite L500-ST2521 Laptop AC...
I also have a Toshiba Satellite A100( PSAA9A-00S00F). Same problem Purchased a battery. Charged it for 6 hours and laptop dies once I removed ac cord. Thought it was the battery so demanded a...
It is very rare that a new battery would no give proper backup. Ensure from your operating system (XP, Vista, Win7) etc that the battery is charging properly and it gets 100% charged.
If it is not chargerging, the issue could be with the charger
Let me know if any further clarification is required
Hope this helps
CreativeTECH
Nov 05, 2010 | Toshiba Satellite A100-S8111TD Notebook
Battery not charging. Computer is brand new. Works fine when plugged in, however icon below reads 0% charge available, plugged in, not charging''. I took the battery out and reinserted it, and still no...
If the Acer is brand new then it is under warranty. Take it back to where you bought the Acer and get it fixed under warranty. if you attempt to fix it yourself you will most likely void your warranty.
Dec 26, 2009 | Acer Aspire 5535-5050 Notebook
Charging issues with a toshiba A215
Check the power adapter with a multi-meter, the voltage of the power plug that plugs into the power socket on the laptop should be slight higher than the voltage that is printed on the label on the adapter.
If it is faulty, there are replacement power supplies available on the Internet or at your friendly computer shop.
If the adapter is OK then the power socket on the laptop is faulty or this socket has a dry solder joint connection on the motherboard.
You can test this by wriggling the power plug when it is connected to the laptop, if the charge LED flickers and if you hold this plug in a certain position the charge LED stays on without flickering, then the power socket is faulty.
This can be repaired, but requires the laptop to be completely
disassembled. I suggest you get a quote first.
Sep 11, 2009 | Toshiba Satellite A215-S7422 Notebook
Toshiba Satellite C55-A5246 15.6" LED Notebook - Intel Core i3 i3-2348M 2.30 GHz - Satin Black Trax - PSCF6U-02D00C Logo
183 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
