Question about Acer Extensa Computers & Internet
Acer extensa 5230E laptop operating system not found
Turn on my laptop aer screen flashes on then off to another black screen wheremedia test failure, exiting broadcom pxe rom, and final operating system not found
    Habit-Forming:
    New Friend:
  • 110 Answers
You will have to go into you bios to see if you hard drive is detected. If you want to no more about how to get into your bios you can see me on face book as Nic fourie and drop me a mail
Posted on Nov 28, 2013
zohail
  • 1223 Answers
SOURCE: PXE-E61: Media test failure, check cable Pxe-M0f: Exiting Broadco
PXE-E61: Media test failure, check cable (of the HARD DISK pls)
pls first check the hard disk seated in the bottom left side of ur notebook u have to take out the 7 or 8 screws first and then take take it out by pulling the connector gently and try to re seat or re fit the hard disk so connector can seat firmly in hard disk and then power up ur notebook if Error persists
then sorry to tell u my friend that ur Hard disk has CRASHED and not giving up files for OS loading kindly replace ur HARD DRIVE and restore ur OS thru backup disk u got
Pls take care of ur notebook from bumps and falls and hard impacts during operation and carrying bcoz the disk inside the HDD is very sensitive and gets damaged easily by impacts
pls rate me FIXYA for my diagnosis
Posted on Mar 09, 2009
frankzjm
  • 191 Answers
SOURCE: My acer 5620Z laptop cannot find its operating system
you can do check HD follow me:
1) open the cover at back of laptop
dc0d736.jpg 2) take out HD body see picture
5d35e3d.jpg 3) put it back in same way, then power on if bios find HD, the error message should be gone.
4) if still show error, you need change other HD, till the bios find out HD drive.
here you can download the service manaul to reference.
hope you fix it well, any question ask me any time please
Posted on May 14, 2009
  • 5 Answers
SOURCE: Problems with my inspiron 1501 details below
The problem your having could be the operating system is damange or the hard drive failed. Try to boot from a Windows XP or Vista CD to see if the drive is recognized.
Regards,
Posted on Sep 01, 2009
  • 3940 Answers
SOURCE: media test failure check cable
system is trying to boot to a network, this is most likely due to the hard disk drive not being detected, or the windows operating system is missing.
First reset the BIOS defaults, see if the system detects the HDD in the bios and will now boot.
Run diagnostics on the hard disk drive, which I suspect it will fail.
If diags on the drive pass, they try reinstalling Windows. But I expect you'll be replacing the drive.
Posted on Nov 15, 2010
  • 34 Answers
SOURCE: went to shut down comp. and screen said, and still
A "media test failure, check cable" means your hard disk failed. The bios can not locate the boot sector of the hard disk to begin loading the operating system.
"Operating system not found" means windows can't load because the Bios can not find the operating system (because the hard disk failed).
This is pretty much an unrecoverable error in terms of fast fixes. You can take the hard disk to a data recovery service if you need to retrieve important data or files.
Posted on Dec 05, 2010
Check the hard drive might be defect or loose from the hard drive connector. If the hard drive is detected in BIOS probably the hard drive is out of order
Nov 28, 2013 | Acer Extensa Computers & Internet
New Battery
Return the battery. Some aftermarket batteries don't work well, and COULD be a fire hazard. Get a genuine Acer battery replacement, beware of inexpensive aftermarkets.
May 03, 2013 | Acer EXTENSA 5230E COMPATIBLE LAPTOP LCD...
Will acer extensa 5230E reinstallation cds contain windows
A driver restore disk works with a windows disk to return your Acer Extensa 5230E Windows 7 back to the original factory setup.
Once windows has installed you put this disk into the drive as soon as windows gives you a found new hardware dialog box. Once inserted the Acer Extensa 5230E Windows 7 will automatically find all the drivers and also install most of the original factory software. BEWARE OF GENERIC DISKS ! All Drivers and factory software are operating system specific so you must have the correct software and drivers for your Acer Extensa 5230EWindows 7. Some of the drivers you would find on this Acer Extensa 5230E Windows 7 Restore Disk are listed below. Not all will be applicable to your system as this list is for information only for Acer Extensa 5230E Windows 7 Restore Disk.
THIS DISK DOES NOT CONTAIN AN OPERATING SYSTEM!
YOU WILL NEED TO INSTAL Windows 7 FIRST OR USE AN EXISTING INSTALL.
Hope this helps
Dec 18, 2012 | Hitachi Travelstar 5K320 HTS543232L9A300...
My acer extensa 5620z got knocked off the chair and since then it wont come on properely. The screen says media test failure, check cable, then operating system not found.
The fall likely dislocated the hard drive. If you are comfortable working on your laptop yourself (you may void the warantee, if any), you will need to locate the panel on the bottom that covers the hard drive. It may be labelled HDD. Open it and 'reseat' the hard drive. Reseat means essentially to unplug and plug back in. Put the panel back on and give it a try. Touch something metal that is grounded before opening it up to discharge any static built up on you before digging in.
Mar 11, 2011 | Acer Extensa 5620 Notebook PC
Where can i get circuit diagram of Acer Extensa 5230E laptop's mother board..???????
Hi
Following is the link for the manual
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Thanks
Dec 09, 2010 | Acer Extensa 5230E2913 Notebook
I have a laptop acer extensa 5230E, and i want to reset default bios becose i forgot my password
What you could try is to carefully take off the keyboard and look for a little battery on the mainboard of the laptop. Carefully take it out and place it back in the right way.
Make sure that you don't leave stains or greasemarks on the battery.
With kind regards,
Jeffrey
Feb 16, 2010 | Acer Computers & Internet
Acer Aspire 5610. Media failure and operating
This can be fixed. Do you have the recovery disk for your Acer Aspire 5610?
If you do, just pop the disk into your cdrom and follow the on-screen directions
If not please click here and enter the infomation that it is asking for, This will allow you to purcahse another set of the cds
Jan 23, 2010 | Acer Aspire 5600 Series 5610-2013 Notebook
How to replace Acer Extensa 5230E hard drive?
unplug power cord, remove main battery, remove lower cover , the hard drive is crome in color 4in x 5in there will be one silver screw holding it on , be sure to touch the metal frame before removing the hdd , that way you,ll discharge your static electricy on not hurt the computer , also you may want to go tohttp://tim.id.au/laptops and download your service manual as a guide .
Jan 08, 2010 | Computers & Internet
Where can I download for free the acer extensa 5230E manual ? for my new computere
Here is the link for the user manual for your laptop:
http://support.acer.com/acerpanam/notebook/0000/Acer/Extensa5230/Extensa5230ul.shtml
Just copy and paste that link into your web browser.
Nov 26, 2009 | Acer Extensa 4620 Notebook
Computers & Internet Logo
161 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
