Question about JVC TH-M303 System
I can't seem to be able to get sound through the speakers when i am on cable tv. does anyone know how to fix this problem?
I can't get sound through my jvc th-m303 home theater system when i am on tv (Toshiba 1999). how do fix this problem?
  • louiselavign Sep 28, 2009
    do anyone know how to get the sound out of tv ?
  • 151 Answers
Run a set of phono cables from the tv audio out put to the aux in put on your system and set to prologic.
Hope this helps
CABLE GUY.
Posted on May 09, 2009
My GPX tv/dvd combo is making an intermitent 'buzzing' sound,anyone know how to fix it?
Is the sound coming from the speakers? (do you hear it with the sound turned off)
Either an audio problem if heard only with sound up or if a buzz with sound off it is a coil or transformer on the circuit board vibrating hard enough to produce the noise.
Both are fixable but require different tactics to resolve.
Mar 14, 2012 | GPX Televison & Video
Sharp Aquos LC-26D4U sound problem
Yes this is a common problem. You have to have it refered to a TV SHOP. I can fix it for you but in CA. the wiring on the speakers needs to be upgraded to a thicker wire. The gauge is to small for the current needed to flow evenly.
$75.00 Fix
Feb 13, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
TV speakers have switched off (i dont know how) how do i switch them back on again have used remote control to access sound options and does not seem to be a feature for on of off sound adjustment
Go into ur tv menu again,go to sound option again check what on the writing highlight on the tv SOUND SETTING now is it said VARIABLE SETTING.Than it is the sound setting problems,go into that highlight word VARIABLE SETTING just press the enter button on the remote to change it back to FIX SETTING.This should and will solved ur tv sound setting problems.If the sound setting already highlight word is said FIX SETTING.Than the tv have bad incomming broadcasting input signal cable or ur tv have bad or dead speakers problems to the tv itself.Not Sound Setting problems.
Apr 13, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
INSIGNIA TV WITH ILIVE BAR. 1 SIDE WORKS
Try swapping your cables from the sound-bar to the TV. If the sound still only plays through one channel but the channel has changed from right to left or vice-versa, then you have a bad cable.
If the performance is the same, connect a different device using the same cables to see if it's the sound bar input or the TV output.
Once you know where the problem is (the sound bar, the TV, or the cables) you'll know what unit needs repair or replacement.
It is entirely possible that a solder joint for the sound-bar has come loose. A soldering pen would easilly fix this if it's a bad joint/connection.
Hope this helps!
Dec 25, 2009 | Insignia 200W Stereo Receiver
Connect Bose System to Panansonic TV
in the tv setup menu there should be an item that will allow you to change the volume from variable to fixed on the output of the tv
Dec 07, 2009 | Panasonic Audio Players & Recorders
No sound on TV
Don't know the exact model you have, but generally when the capacitors are replaced, many CABLES ARE UNPLUGGED and RE-PLUGGED in the process, including the speakers. Have someone check the speaker connections. Also be sure the tv is not in "mute" mode or the volume is not set to zero.
May 17, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Dell 32 inch LCD Tv volume and menue problems
We also have a 32" LCD Dell flat screen tv #W3201C that has no sound. It's about 2/12 yrs old. One speaker started having a problem and we disconnected it. That was a couple weeks ago, now there is no sound at all. Dell should not be let off the hook so easily. Obviously there is a problem with the tv and it should be Dell's responsibility to make it right. Does anyone know if a class action suit has been initiated?
Mar 08, 2008 | Dell W3201C 32 in. LCD Television
Aiwa HT-DV1
cuse u need to go back form the tvs out to the dvds input thers no way it knows cuse u have no signal form tv bakc to it or form cable bocx rca out puts to the awia ins rca on input 2 ok or aux in
Jan 10, 2008 | Aiwa HT-DV1 System
Audio output not working
I had what may have been a similar problem and even talked to Westinghouse to see what I was doing wrong. Woman suggested there was a problem with the audio output port and suggested I exchange tv for another one. When the new one had the same problem, I discovered that to get audio out requires the volume to be turned way up on the tv (set speaker preference to external only if you don't want sound from tv speakers as well). If you have a digital optical connection on both the tv and the home theater, the sound output is independent from the tv setting and is easier to work with.
Oct 04, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Picture intermittently drops out.. other problems
Tv pricing has come down quit a bit these days and like the typical computor printers the ink cost more. In your case the parts will cost you a lot. With all the problems discribed "buy New" and get yourself up to date with that of what you want a Tv to do for you.
Dec 13, 2006 | Sony KV-20S10 20" TV
JVC TH-M303 System Logo
449 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
