Question about Dell Dimension 3000 PC Desktop
Diagnostic lights With an IDE SATA conveter I am trying to upgrade my PATA hard drive to a Sata ON OLD MOTHERBOARD and on the diagnostic lights I have 3 solid green lights and last light is solid yellow Please Help Thank you
    Problem Solver:
  • 9 Answers
I know this is old, but I think maybe I can help someone who is having a similar issue. I assume they were using some kind of IDE to SATA convertor from the motherboard header (the place where it plugs in on the motherboard) or an SATA to IDE convertor on the drive itself. It is probably not working or the mainboard can't support it. Here is the answer from the manual referring to the diagnostic LEDs:
  1. Ensure that the cables are properly connected to the system board from the hard drive, CD drive, and DVD drive.
  2. If there is an error message on your screen identifying a problem with a device (such as the floppy drive or hard drive), check the device to make sure it is functioning properly.
  3. The operating system is attempting to boot from a device (such as the floppy drive or hard drive); check system setup to make sure that the boot sequence is correct for the devices installed on your computer.
  4. If the problem persists, see "Contacting Dell" in your Owner's Manual for instructions on obtaining technical assistance.
These convertors are pretty straight forward. It's probably better to get an internal PCI SATA card and hook to that. There are a couple of advantages to a SATA card--
  1. They can support the rated speed of the drive. If you have a SATA 3.0 drive (6Mb/sec) and you have a card that supports it, it should run nearly that fast.
  2. They usually support hardware RAID for more drives.
  3. They usually have eSATA ports and maybe USB as well.
As long you have the drivers to support it, it should be better.
Posted on Apr 27, 2014
  • 77 Answers
SOURCE: Can i Install PATA hdd on Dimension 4700
I'm sorry, but I couldn't wade through this bunch responses, so I'm going to give you my own.
You have 2 sata drives installed, already, so you cannot add an additional one w/o a bunch of wonky adapters, so use the IDE channel. You say you have an IDE rom drive. Well, there's a reason there are 3 connections on an IDE cable. One side goes into the motherboard, the other 2 into your drives. The motherboard side is the one furthest away from the center connector. I assume you have the primary connector connected to your rom drive. the 2ndary one would be on your hdd. Why people asked you why you're doing this is beyond me. It works, you'll have an extra drive, your preference. Whatever.
Let me know if you have any more inquiries.
To answer your questions from your original post directly, the other 'ide' channel is specifically for a floppy disk You CANNOT connect an IDE cable to it. And yes, you can connect an  hdd to the slave port on the ide cable.
Posted on May 01, 2008
MDoe
  • 156 Answers
SOURCE: Dell dimension 3000 hard dirve what type do i need to install a sata pata or ide
Hi
Dell Dimension 3000 accepts IDE hard drive. Any modern IDE drive should be fine
Check out Dell Dimension 3000 Service Manual for spec and how to remove and install parts.
Mike
Posted on Aug 21, 2008
  • 58 Answers
SOURCE: Dell Dimension 5510
Normally you would set it up to boot from:
1. CD/DVD drive
2. Hard Drives
There may also be a floppy drive to add in whereever you want it.
This problem sound like some kind of drive controller or the drives are not being recognized in BIOS...check and make sure you see the hard drives when setting the boot order.
Posted on Mar 15, 2009
  • 166 Answers
SOURCE: I am having trouble installing a second hard drive
Have you enabled the drive in the BIOS yet?
To do this hit F2 when it starts up and then go down to drives. Hit enter and then locate the SATA port that you have it in and turn the drive on.
Let me know if this works or not. If it doesn't, give me additional details and we will try to fix it.
Posted on Apr 30, 2009
  • 7 Answers
SOURCE: Dell DimE310 wont reeboot
try this unplug your machine,take off the side cover,there is a jumper near the battery for the cmos,it has three pins,remove from pin 1&2
and place on 2&3,remove an return to the original position.
plug in and restart,at startup press F2,scroll to boot sequence and press enter,change order to (1)CD,(2) IDE hard drive(3) SATA hard drive,save and exit.
Posted on Jul 01, 2009
Is a ide a hard drive
You should check what kind of hard drive is using your computer. If it has less then 5 years probably hard drives are sata.
watch this tutorial
Instructions on USB To SATA IDE Adapters Cables
How to connect SATA devices in PATA IDE only PC system
Modding Guide Inline SATA Connectors
How to connect an IDE drive to SATA motherboard
Jul 22, 2015 | Hard Computers & Internet
Tip
How to connect your hard drive to your motherboard The first thing you have to...
The first thing you have to figure out is what type of hard drive you have, a PATA or a SATA drive.
PATA = Parallel ATA
This type of drive uses the older IDE connections. Most of your current motherboards still have aleast one IDE connection to support the ROM drives on the market that have not moved over to SATA connections but you can still connect a hard drive to this connection if needed. The thing to keep in mind is that you can only connect 2 IDE devices to one IDE connection on the motherboard.
Here is an example of an IDE cable. If you can see there are tabs on the cable to make sure you line up the pins properly.
SATA = Serial Advanced Technology Attachment
This type is now the standard that most hard drives are. Also note that alot of your ROM drives are switching over to this format as well.
Here is an example of a SATA cable.
In regards to power connectors If you are using a PATA drive then you will use the Molex power connector. Note some of the early SATA drives use this power connector as well.
For the SATA drives you would use the SATA power connector. Note if your power supply does not have this connection you can get an adapter that goes from a Molex connection to the SATA connector.
Next you will need to find the connectors for the hard drive on your motherboard. Below if pictures of the 2 connection types.
IDE/PATA motherboard connectors
SATA motherboard connectors
on Sep 01, 2010 | Computers & Internet
I have upgraded my hard drive from pata to sata using the ide to sata converter I don't no what went wrong but my diagnostic lights are reading A B C are solid green D is solid yellow and i am getting...
You may have to reboot a few times to update the bios with the new card. But there is probably an IRQ problem between the 2 cards. To fix this move the sata card over one slot and try booting again maybe 2 or three times.
Nov 28, 2013 | Dell Dimension 3000 PC Desktop
Sata pata ide hard
A sata drive doesn't need jumpers. The jumpers were only required when 2 drives used the same cable.
How do I choose a hard drive?
It depends upon where the hard disk is to be installed, ie. in a desktop computer, in a laptop or in an USB hard drive case.
A 3 1/2 inch hard drives can be a IDE/PATA or a SATA type. Older computers use IDE/PATA hard drives and the maximum size you can install in a desktop depends upon the computer's BIOS.
SATA hard drives are generally used in later model computers and the size of the hard drive is not limited by the BIOS.
A 2 1/2 inch hard drives are used in laptops and are available in IDE/PATA and SATA types. The size and limitations of IDE/PATA hard drives also apply to laptops. The same applies to SATA hard drives.
The choice and size of hard drive depends upon your requirements and how much you want pay.
Don't forget to check BIOS for the maximum IDE/PATA hard drive size you can install in your computer.
Aug 22, 2011 | HP Computers & Internet
How do i install a wdeads hard drive? where is the power supply (4pin Molex)?
I'LL TELL YOU UPFRONT i HAVE ONLY INSTALLED SATA ON A NEW SYSTEM SO MY ANSWER MAY NOT BE CORRECT IN ALL SITUATIONS
Question is vague. Are you replacing a drive or building a new system? SATA drives have a dedicated plug on the Mother Board. Of course you already know you can't replace an IDE with a SATA without an adapter (Ebay has them for about $8) or the Bios is incompatible. The power is on the Motherboard and does not have a connector from the power supply like an IDE has.
Feb 20, 2011 | Western Digital WD15EADS 1.5 TB SATA Hard...
Can i use PATA hdd for this motherboard?
You could connect a PATA HDD to this using the IDE connector, which then means that you would need to either slave your optical drive on the same channel, or obtain a sata optical drive.
The other ( not recommended) solution is to buy an IDE / SATA converter and run the hard drive from a SATA port. I've never had any sucess with these adaptors
Dec 25, 2010 | ASUS P5GC-MX/1333 Motherboard
ASUS M2N68-AM SE2 GeForce 7025 Socket AM2+ MB built system. Works great with Sata hard drive. Removed my older 500GB IDE hard drive and CDROM from old PC. When i try to put both, or either 1 into to IDE...
Try to go into the bios and set the first boot device as your sata hdd. There will be a option in boot section of the cmos setup where the hdd drive order will be mentioned. If PATA is shown first press enter in the option select SATA and press enter save and exit changes things should go on fine.
Also check your pata hdd and cdrom specific jumper setting. For more help post your HDD model and make and cdrom model and the bios type
Dec 01, 2009 | Computers & Internet
Dell Dimension 3000 PC Desktop Logo
mukhtar21 shaikh
mukhtar21 shaikh
