Question about Toshiba Satellite C55-A5246 15.6" LED Notebook - Intel Core i3 i3-2348M 2.30 GHz - Satin Black Trax - PSCF6U-02D00C
Toshiba Satellite C55-A plugged in, not charging
The computer is plugged in, the battery does not charge although the icon says it is. It begins charging when the screen is off then turned back on. it then will charge for 45 seconds then stop. the computer is also brand new
  • 3940 Answers
SOURCE: Toshiba Satellite A100 VA1 system unit model# PSAAKC - VA104C
Does the system power on using the AC adapter?
How old is the battery?
If the system powers on and runs normally on AC, and only the battery fails to charge, the 1st thing I would look at is the battery itself.
Batteries in portable systems have a lifespan of 300 to 500 recharge/discharge cycles before they normally fail. This is why portable batteries have a 1 year warranty regardless of the system warranty.
If replacing the battery does not resolve, then you most likely need a motherboard replacement.
Posted on May 17, 2008
  • 6 Answers
SOURCE: Toshiba Satellite A135 Battery Issues!!!
Here's what happened (The fix is at the end):
8 months after buying my Toshiba A135 the battery began charging only intermittently. It also would not run without the battery. I put up with it for a month then took it back to Best Buy to get it repaired under warranty. They kept it over 2 weeks then gave it back saying it was the battery, which they replaced. One week later I had the same problem again. Back to Best Buy. The guy at the counter said it was probably the battery, they had encountered a lot of that. I said no, explained it, and gave it over to be fixed. 2 weeks later I got it back. They had reset the BIOS, no hardware replacement. I got it home and it was not fixed. I took it back the next day. They kept it 2 more weeks. They replaced the motherboard. I took it home and...you guessed it the same problem on the day I got it home!!! I took it back with one week left on my warranty. I don't remember what they replaced the last time but I think it was the motherboard again. I got it home (2 weeks later) and THE SAME PROBLEM on the day I got it home. So, the lesson there is that Best Buy computer maintenance SUCKS!!
I called Toshiba to try to get them to fix it for free, and out of warranty. After several frustrating minutes of conversation with an accented person who just kept telling me that my warranty was up, I hung up and called back and got an English speaking person. SHE was very helpful, listened to my problem, agreed to give me a one-time fix ticket. They paid for the postage. When I got my computer back it was mostly fixed.
The problem was the module at the back of the computer where the power cord plugs in. It was defective. Some wire or solder had gotten loose. They replaced it and it worked fine after that, except that when it goes into sleep mode it will not wake up. I fixed that by turning off all the sleep mode options. BTW, a friend of mine with the same computer is now having the same problem.
Posted on Oct 22, 2008
Geekman
  • 32281 Answers
SOURCE: "Plugged in, not charging", Toshiba Satellite A135 S4527, under Windows Vista Home Premium
It sounds like the power socket on the laptop is faulty and needs replacing or resoldering. To check this, power up the latop with the power adapter, wriggle the plug in the power socket and check if the battery charge indicator flicks on and off indicating charging and not charging. If it indicator flicks on and off then you have a faulty power socket.
This can be repaired but required the laptop to be completely dismantled to access the power connector.
Posted on Feb 18, 2009
  • 253 Answers
SOURCE: Toshiba Satellite L25-S1216 - blank screen
Try to shutdown, remove battery, remove AC plug, Press and Hold Power button for 30 seconds, replace battery and AC adapter and test.
do you hear windows booting ( the startup sound) after a few minutes, if so there may be a monitor hardware problem
Posted on Mar 30, 2009
I started having the same problem and worse mine would shut off without warning either from the battery running down or even just plugged in without a battery.
I thought It might be overheating so I got a can of air and cleaned all of the vents...and downloaded core temp to monitor the cpu temp @ http://www.alcpu.com/CoreTemp/. Same problem shut down and no charging even though it was running cool.
Finally I started changing settings and it seems to be working and charging just fine.
Here's the answer:
1. Set your power scheme to balanced
2. Open Toshiba Assistant from start
3. In Toshiba Assistant open CPU tab and set to low power.
4. When asked "restart now?" say no and shut it down using the start menu.
When you start it back up you will see the change.
Changing either one of these settings brings the problems back. I can't explain it.
I HOPE IT WORKS FOR YOU!
I just can't afford another laptop right now.
P.S. even at low power my system works fine...It's a little slower @ start-up but otherwise good.
Posted on Jul 29, 2009
TOSHIBA SATELLITE C55D POWER LED ON WHEN CLICK POWER . ,BUTTON SCREEN LIGHTS UP AND SAYS BATTERY LOW AND CHARGING
Yep... classic signs of a bad/poor battery! About $13 including US shipping (US Seller too).
See eBay: 322759285844
If you REALLY want to do a good job buy a NEW POWER SUPPLY TOO! They do age ~ with time ~ like all of us.
$9.78 shipped.
Happy BATTERY with it's NEW Power Supply!
Anthony
Lot Battery for Toshiba Satellite C55 C55D C850 C855 C850D C855D PA5024U...
AC Adapter Power Supply Cord for Toshiba Satellite C55D A5120 L755D S5150...
Nov 21, 2017 | Toshiba Computers & Internet
How disassemble a Toshiba laptop Satellite C55-A5302.
It can't be disassembled. It is a built as one unit.
Nov 06, 2016 | Toshiba Computers & Internet
How to reset hdd/ ssd password of toshiba satellite c55-b5299
Contact Toshiba, prove ownership and they may be able to help.
Mar 01, 2015 | Toshiba Satellite C55-B Black Laptop...
Toshiba c55
Try just using the mains power. Remove battery an leave plugged in . If it works it's the battery/ power brick .
Dec 26, 2013 | Computers & Internet
I have a Toshiba satellite C55 laptop that will only show one light on the front when plugged into power source. I have bought, and put in, a new battery, and it would go to the advanced boot up screen,...
Try this:
Disconnect the battery from the laptop; Plug in the AC power cable, try turning on the laptop again.
It SHOULD power up and continue to boot into windows like normal.
If it does, now put the battery into the laptop while the laptop is on.
Make sure in windows you see that the battery is charging.
If it is, then the battery was to depleted on energy to start the laptop; Some laptop batterys have to have a minimum charge in order to start the laptops. Even if the power cable is plugged in.
Oct 04, 2013 | Toshiba Satellite Computers & Internet
Hello there, I own a toshiba c655-s5049 laptop about a year. When I connect a charger taskbar icon shows plugged-in, not charging and the front panel power/battery indicator lights green not orange. When...
Take some alcohol and a q tip and wipe the battery terminals and the terminals on the battery compartment. The laptop not getting a good connection with the battery
Aug 07, 2017 | Toshiba Satellite C655-S5049 Notebook
Battery not recharging
All batteries die sooner or later. I believe you have a dead cell.
1) Find another machine that uses the same battery and try it or
2) try another battery or
3) Give up and buy a new battery.
Good luck.
Apr 30, 2008 | Toshiba Satellite M35X-S111 Notebook
Toshiba Satellite C55-A5246 15.6" LED Notebook - Intel Core i3 i3-2348M 2.30 GHz - Satin Black Trax - PSCF6U-02D00C Logo
339 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
