Question about Whirlpool Washing Machines
Washer stops at drain and spin. timer makes a buzzing noise.
    Genius:
  • 1,198 Answers
The lid switch is the usual suspect for this symptom.
Posted on May 09, 2009
Why is my Whirlpoo WFW9050X washer buzzing when it's turned on?
Biggest hassle with these machines is that the belt or drive stops working properly. Check for that first. If parts needed check here. Search Over 2 1 Million Appliance Parts
Sep 09, 2017 | Whirlpool WFW9050X Washer
Wont do anything
See if the buzzing is coming from the timer, it may be broken. Try to change the timer to spin and see if the motor works.
Dec 02, 2013 | Maytag MTW5700TQ Top Load Washer
My GE washer model WDSR2080D2WW, will fill and wash only. When it should drain and go into the spin cycle, all it does is makes a buzzing noise from the timer. This is no matter the cycle setting. What is...
Hi- Sounds like your drain pump is bad, or clogged. Not easy to get to. It could also be a timer issue or an issue with your pressure switch which tells the washer when the water is out and it can go into spin mode. Sounds like you need to have someone out to take a look.
Sep 23, 2010 | GE WDSR2080D Top Load Washer
My whirlpool washer makes a buzzing noise and does not spin or drain. I think it my be the timer, It arches when you turn it off and makes a rattaling noise when you shake it.
Is this a front loader there may be something stuck in the pump,and the washer may be out of balance is the door locked and won't open?
Aug 29, 2010 | Whirlpool Washing Machines
My GE spacemaker top loader will not drain, makes buzzing noise
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
May 29, 2010 | GE Spacemaker Washer and Dryer Electric...
Whirlpool washer will agitate only, no drain or spin
99% probability that your timer switch is done. The only remedy is replacement.
Aug 23, 2017 | Whirlpool Washing Machines
It fills and agitates. Fills up then stops, makes a buzzing noise and will not drain or spin. What could be wrong?
in order to accurately diagnose this i will need the model number, but it could be that your lid switch is faulty, therefore not allowing your washer to go into a spin cycle. for safety reasons. another cause of this could be from a bad timer, if your timer stops after the agitation cycle and does not continue to count down then you have a bad timer.
Oct 11, 2009 | Kenmore Washing Machines
Series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
Jun 16, 2009 | Kenmore Washing Machines
Waher will not go into spin cycle. It makes a buzzing noise and will not spin.
it's most likely your timer....u can get the machine to spin out your clothes by pushing the timer in and pulling it back out. this resets the motor and makes it turn backwards. it's a pain to do this because you have to keep an eye on the time. this will get you through until you change the timer.
May 28, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
67 people viewed this question
Dan Webster
Dan Webster
Sal De
