Question about Indesit Washing Machines
Door locked red sign comes off
I have indesit wia121 but I donot know about exact programming of machine machine is locked red sign is coming on lock logo and I dont know how to open lock when I am switching this off the door open after two three minutes and when I am putting clothes inside and switch on again its starting but not moving spining or drying and lock sign is coming again on it could u pl tell me the exact programming where shoud be the other buttons and how to start this only two green lights are coming on spining and draining but the third light of washing up on timer is no coming on pl tell me the reason
    Genius:
  • 1,198 Answers
Has it ever run right? Are the water valves on? Is the selection by buttons or a touchpad? If buttons, make sure each is on a selection, not half way or in between. If touch pad, see if there is a reset.
Posted on Nov 29, 2013
  • 1462 Answers
SOURCE: Fixing broken door lock of Indesit W123X washing Machine
no easy way to open
disconnect from mains
take top off. feel down the front to where the door lock is and see if you can feel the door peg sticking thro the door interlock. force this with your fingers and with luck the door will open
if can't do this way, break handle off and lever peg with a small screwdriver
you can buy a handle kit complete. fitting this is not difficult - split the door and all will be revealed advise you make a carefull note of where springs go etc before you start stripping it down or take a few fotos if you have a digicam
Posted on Jul 10, 2008
SOURCE: The door lock flashes constantly - Indesit WIA101
Switch on machine and start its program. While it is running then turn program selector control to TOP position. After a few seconds ALL lights should flash and machine should stop. It ought now to have been reset to normal.
Posted on Aug 23, 2008
  • 1294 Answers
SOURCE: washing machine door locked indesit WD12X
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Posted on Apr 02, 2009
SOURCE: Indesit washing machine not spinning - fault code timer and dor lock light flashing
my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
Posted on Jan 18, 2010
SOURCE: all lights flash on indesit washing machine soon after switch on
Indesit washing machine lights come on briefly when awitched on at mains and then no power
Posted on Apr 19, 2010
I have a indesit iwb71250 that the red door lock light is on constantly but we can open the door and shut although the machine will run it wont fill with water... any ideas
May be the switch is loose try fixing it with ascrew driver or the rubber hose is not fixed properly and the machine pump is taking air or the pump failure
Oct 19, 2014 | Indesit IWB71250 White 60 cm Washer Front...
Indesit WIA121 Flashing Door Lock, Prewash and Spin Lights - Machine not draining
hi something similar has started happening to our washer, after the initial wash starts the machine doesn't do anything for a while then the red door light flashes on and off very quickly as does the 1st and 3rd green wash cycle light?
Jul 04, 2012 | Washing Machines
Indesit iwdc6125. All 5 top lights flashing and rinse and door lock lights are on. Does this mean the module needs programming?
The door lock is faulty. I removed the top cover and removed the red control box from its nylon casing on the lock. I then broke the locking mechanism. Leave the control box connected or it won't work. My machine works but no longer locks so could be a problem if you have small children.
Mar 29, 2012 | Indesit Washing Machines
Indesit WIL 153 Door Lock
Hi John, did you ever fix your washing machine door as I have exactly the same problemw ith mine
Feb 20, 2010 | Washing Machines
I have an indesit WIE 137S. When the door is closed, teh red door lock light does not come on and the wash can't proceed. Any hep greatly appreciated
Have you checked your plug and the connections, also your socket.
If no joy, then door lock probably faulty.
Nov 18, 2008 | Indesit Washing Machines
INDESIT 1000 DOES NOT START
Had a similar problem ,flashing red led means door not locked, I removed door from machine removed front from door and found hinge pin for lock had come adrift, religned pin and chapped back into position .THen replaced door and door to machine .dor shut and lock worked perfectly, hope this helps
If this doesn't work you may have to replace the EMW. Should cost you around 60$
May 23, 2008 | Indesit W 123 Front Load Washer
Indesit Standard WIL 123 (UK) Washing Machine
Jan 04, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
88 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
