Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Replacefual lines how to install new gas lines
    New Friend:
  • 15 Answers
Just take apart the air cleaner and any other covers around the gas tank and carb. you will see the lines, remove one and notice how attached, if you can re-use clamp good, if not count how many needed, take line to ACE, Auto Zone, Discount Auto you get the picture, ask for and give them gas line and also ask for clamps needed.
That's it.... any questions feel free to ask...
Posted on Nov 30, 2013
How to change my gas line on a 17 inch 25cc gas weedwacker trimmer/edger
basically this is a very simple thing to do as long as you have purchased the correct size of hose. Before removing the fuel line from the tank remove it from the carburetor. then you need a small bent wire or something like it to fish the filter out of the fuel tank. When you have that done you need to remove the filter and just pull the fuel line out. When you install the new line in the tank you need to snip the new fuel hose at an angle to help in the ease of re installing it. Once you get it started you can either reach into the tank with needle nose pliers and pinch it so you can pull it back into the tank. Or you can just twist it in a circular motion until it feeds itself into the tank. The rest is common sense. Install the fuel line filter and put it back into the tank then suck a little gas up the line so the carburetor don't have to do it. that'll prime the line and make it easier for the trimmer to start.
Jun 29, 2014 | Craftsman 25cc Gas Line Trimmer
How to install new pool heater
Shut the pump down. Open the lid on the pump to allow into the system. This will drain the plumbing lines at the equipment. Drain water from heater by removing drain plugs(usually 3) Shut the gas valve off to the heater and undo the union that is usually after the valve(recommend gas fitter doing this and he should reattach any piping or rethread new cut pipe. Cut or disconnect water lines from and to the heater. Remove old heater Install new heater in location and reconnect water lines to appropriate side of the headers(water inlet and outlets for heater). Gasline reconnect via gas fitter. Light pilotand restart pump after filling with water and repriming
May 07, 2013 | Pool & Spa
Brand new model rtg-64dvln smell gas when water is turned on..when water is off no gas smell getting code 11 gas valve not fully open but gas valve is fully open
1) if you smell gas, this is absolutely dangerous.
Call installer immediately.
If you installed yourself, get a professional technician immediately.
2) Copy following link for For error code 11: problem with gas.
Do not use flex line, bleed air from gas line, check gas pressure, incomplete combustion, etc.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Jan 29, 2013 | Water Heaters
Installed new fuel pump because car had old gas in tank. removed tank and completly drained it. replaced tank and installed new fuel pump and fuel filter. put about 6 gallons of gas in car. have tried to...
Okay, you need to make sure the fuel pump is getting power and that you have the lines hooked up correctly. Also, when you replace fuel pumps you need to remove the air cleaner and use starter fluid to get the engine started.
Jul 09, 2011 | Nissan Z Cars & Trucks
Just purchast and installed everything hooked up push the sparker looking through window I see nothing
You posted under Reliance gas water heater
You installed a new gas water heater and are trying to light water heater using the piezo igniter.
Not clear is what steps you have taken so far, and which gas control valve is on the new water heater, and what lighting instructions say on side of water heater.
Also unknown if you bled air out of gas line, or if gas shut-off handle is rotated so handle is parallel with gas line.
Read instructions written on side of tank, open link below to double-check installation, and then add a comment with steps you have taken so far, and describe the type of gas control valve on water heater.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Jul 03, 2011 | Reliance Natural Gas Water Heater Control
Installed new 250 unit today, getting error code IF, Gas is on, gas valve in front panel is open, unit grounded, gas feed line necked down to 3/4 npt at shut-off valve, tried to increase gas pressure 1...
Did you bleed the gas line of air? In a nw installation it is not uncommon to sit there 20-30 seconds with the gas line union open and the shutoff open to get all the air out and a good flow of gas present. If that doesn't work post a comment with what else happens.
John
May 29, 2011 | Hayward 250fdn Low Nox Nat Gas Swimming...
Disconnected intake hose from gas tank to primer bulb
is gas line broke or disconnected? Either way it has to be reinstalled.First, get new gas line, and be sure to get it longer then you need, because, you will need to cut a sharp angle on one end then install this end into gas tank, then reach thru gas cap opening with needle nose pliers, get ahold of fuel line and pull thru. if you do not cut angle on new fuel line, you will never get the line into gas tank.
Apr 29, 2010 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
How to get gas lines in tank
You can go to Home Depot and for about $7 U.S. dollars, they sell a replacement filter, primer bulb and install wire. It is really cool. You put the install wire thru the hole in the tank where the lines come out of the tank. There is a small hook on the end. This hook fits thru a small hole in the new fuel line end which is cut on an angle. Basically this allows you to fish the new line into the tank thru the gas fill port up thru the small holes in the tank. Then just plug the tubes on the carb. Easy Pizzi !!!
Feb 18, 2010 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Have installed new fuel pump and gas lines in 1995
pull line off of front of filter and cycle key 2 on position if there is no fuel present your feul pump may b the problem, before replacing old one make sure the fuse is good
Oct 06, 2009 | 1995 GMC Jimmy
I have an older Weed Eater gas powered trimmer(Model XT 85T) The fuel lines have aged, rotted and broke. I have new lines (big fuel line and small fuel line). How do I get these lines through the holes...
gas line is 1/8" ID. NAPA autoparts sells replacement gas line that works but has an OD that will not fit hole in plastic frame where the carb sits. Just drill the plastic to the OD of new gas line and use needlenose pliers to install the line. Same goes for the gas tank. Just make sure it is tight fit so it does not leak.
Mar 27, 2009 | Garden
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
