Question about Nikon DSLR D90 Digital Camera
E33 error showing on my nikon d90
I've tried to put a different prime lens on today that i've used twice before but it keeps flashing e33-what does this mean?i normally have the kit lens on with it but didnt seem to have problems last time i used it.have i done something wrong?
    Top Expert:
  • Nikon Master
  • 6,702 Answers
I can't find E33 in the manual. The manual although says in a note on Electronically-Controlled cameras:
In extremely rare instances, unusual characters may appear in the control panel and the camera may stop functioning. In most cases, this phenomenon is caused by a strong external static charge. Turn the camera off, remove and replace the battery, taking care to avoid burns, and turn the camera on again, or, if you are using an AC adapter (available separately), disconnect and reconnect the adapter and turn the camera on again. In the event of continued malfunction, contact your retailer or Nikon-authorized service representative. Note that disconnecting the power source as described above may result in loss of any data not recorded to the memory card at the time the problem occurred. Data already recorded to the card will not be affected. On the other hand, when you use a different lens, Something could go wrong. If F-- blinks, the camera means, there is no lens attached or a non CPU lens is attached. When your lens does not have a CPU, you only can shoot in the M-mode. Why not try the command rail in the M-Mode? When FEE appears, the Lens aperture ring is not set toy the minimum aperture. You should use the highest number on the aperture ring. Only on rare occasions the sensor for the aperture is broken and will give an error. Try moving the ring in the camera and see if the error stays when you turned the ring to the maximum.
Posted on Nov 28, 2013
SOURCE: Nikon D90 rear curtain sync will shoot flash twice
I also thought that this was a problem, but it isn't. The first flash you see actually fires before the curtain opens. It is a pre-flash that helps measure the intensity of the flash needed. It does not show up in your photo. The second flash is the actual flash that takes your picture.
Posted on Jun 18, 2009
BubbaGuru
  • 70 Answers
SOURCE: F-- on Nikon D90's display
Lense and body connection problem...Try removing and replacing he lens. Also you can try to gentley turn the lens on the body to make the contacts touch better...
Posted on Jul 05, 2009
lydiap
  • 12 Answers
SOURCE: Error message F-- Nikon D90 w/kit lens 18-105mm
correct - i need to get a good grip on the lens and click it to connect to the body
Posted on Jul 19, 2009
Rammsteins
  • 300 Answers
SOURCE: my 9 month old camera (Nikon s210 coolpix 8.0mp) that I
Hi!
It sounds like the lens focus is stuck. If you don't have experience in camera repairs, you should give it for a repair to your local Nikon service center or other camera service center.
Tom
Posted on Jul 31, 2009
SOURCE: got my Nikon d90 for
This is a common problem with this camera/lens conbo. I "solved" it by removing the lens, then reinstalling it - but hold the lens release button down, and rotate the lens a nuber of times (in the camera body) before releasing the button. It appears that the issue is poor electrical contact between the lens and camera body. If there is a poor contact, the camera will not know if thereis a focus and will lock the shutter release. With this poos contact, the camera will only fucntion in manual mode
Hope that this helps
Posted on Sep 12, 2010
Why doesn't my neotv netgear remote no longer communicating with box?
What do the different Remote control front LED lights mean?
  • Blink blue color twice per second: Remote control has paired NeoTV PRIME and is trying to connect NeoTV PRIME.
  • Blink blue color once per second: Remote control is trying to pair the NeoTV PRIME.
  • Orange blinking: Remote control battery is low. Please replace a new set of AAA battery.
go to page 15 of the following document:
http://www.netgear.com/landing/stream/img/gtv-specs/GTV100_IG_25Oct2012.pdf
Sep 09, 2014 | Computers & Internet
Images are black
Did you set your aperture your ISO and speed
please put it in Automatic if you dont know how
Dec 01, 2013 | Nikon D3100 14.2MP Digital SLR Camera with...
"Loading" error. RCA DCR69702 DVD can't read discs anymore.
Replace unit - the laser assembly has lost the ability to focus on surface of disk.
May 04, 2017 | RCA Televison & Video
Focus out problem in canon 50d while using 24-70mm lens?
If by a "normal" lens, you mean a 35mm or 50mm fixed focal length - often called "prime" lens, that is to be expected. The additional and internal rotating optical elements all contribute to loss of clarity, color loss, and increased chromatic aberration that starts to become noticeable when compared to use of a prime lens. It's a trade off; less number of lenses to carry and lower cost when using wide angle zoom lenses as opposed to a prime lens for even just a few of the focal lengths offered by the wide angle zoom types.
You can minimize the unwanted effects by staying away from both the extreme wide angle and zoom focal lengths as well as the widest aperture settings. If you can stay 2 or 3 stops smaller from wide open, you can limit these destractions from your pictures. This is recommended advice for nearly every lens: Keep away from the extremes.
Jan 08, 2012 | Canon 24-70mm f/2.8 Lens
What is error 99
What wide angle lens is it need f number it may be to old to work on eos 400d
Dec 27, 2009 | Canon EOS 400D Digital Camera
Dic
To make it play, you normally just push the play button.
If that does not work, often that means you have a lens problem.
Use a dvd lens cleaner kit , like the ones that you see clicking here.
If that does not work, you will need to take apart the unit, access the lens pickup, and clean the lens directly, using isopropyl alcohol and a cotton sticks.
Oct 10, 2008 | NAD L40 CD Player
DROPPED NIKON d40, now my pictures are all dark
First u have to reset the camera,go through the menu and select reset and yes. the camera will take default settings.Try now.
Reset the camera opening the connector cover.
You try with a different compatible lens .If works we have to change the lens.
Remove the battery and get fully charged .Operate all switches for some clicks. then put the battery and try.
Then u have to consult a mechanic.
Apr 27, 2008 | Nikon D40x Digital Camera
Power on n off
I had the same problem, corrected it by cleaning the battery contacts inside the camera.
Dec 21, 2007 | Sony Cyber-Shot DSC-S500 Digital Camera
Sony Cybershot Camera DSC-S650 won't stay on.
that happen to my camera, exactly same thing. and i figured out when i dropped it the zoom out zoom in lens was bent and stuck part way in camera. My brother was playing around and moved lens and it started to work again. If lens looks a little crooked try moving it or putting it straight. Hope it helps
Nov 08, 2007 | Sony Cyber-shot DSC-S600 Digital Camera
Nikon DSLR D90   Digital Camera Logo
102 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
