Question about Hoover HDC6 Electric Dryer
Hoover tumble dryer
Hi there
I've had my Hoover condenser tumble dryer for about 18 months and now when I try to press the start button the motor starts, but then stops as soon as I release the button.  The button pops out straight away but if you keep your finger on the button the motor continues to work.
Any ideas?
Many thanks
  • 5 more comments
  • jilly7 Oct 18, 2007
    It appears to be the switch behind the start button that is faulty.  My partner switched this one with another and it worked again.
    Thanks for your help.
  • biscuit1969 Dec 26, 2007
    Hi I,ve got the same problem are the switches easy to change?
  • Anonymous Mar 17, 2014
    Wont start when start button is pressed. Light is on
    The drum on my hoover condenser tumble dryer wont go round
  • 291 Answers
I think you may have a bad relay on the motor, where power is re-applied after the push start is released
Posted on Oct 14, 2007
Could you tell me where the thermal limiter is situated in a DYC8913B please
Ian, Did not find your particular model, links below may help in changing and testing your thermostat.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Condenser Dryer Model No DYC 8913B Product Code 31100391
Hoover DYC8913B 80 Thermal Limiter
Dryer Isnt Heating High Limit Thermostat Testing Dryer Troubleshooting...
How to replace thermostat on tumble dryer how to diagnose the fault
Apr 24, 2016 | Hoover Dryers
Hoover Tumble Dryer VHC 391t. Its starts and does a cycle stops to turn the other way and just stops. If you press the start button it just clicks.
The most common problem for this would be the motherboard of the system that's controlling the Hoover Tumble Dryer. You will have to either get it repaired by a professional or get a new dryer.
May 14, 2012 | Hoover VHC391 T-80 Dryer
I have a Hoover tumble drier model HDC6 type TCMo1 and it is NOT getting hot HELP
Try hitting the reset button on the back side of the dryer.
Yank out your condenser and give it a good clean.
A nice video:
Dec 02, 2010 | Hoover HDC6 Electric Dryer
Hi We have a Hoover Apollo Supreme D6794 tumble dryer approx 18 years old. Has stopped working suddenly. We can turn the motor manually to start it but it then stops. What could be the problem? Is it...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Sep 20, 2010 | Dryers
My hoover nextra8 condenser tumble dryer turns on but does not spin, checked belt and is ok.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Aug 16, 2010 | Hoover HDC6 Electric Dryer
Hoover Maxi 6 TC50 Tumble Dryer making squealing noise
Have you fixed this problem? I also have a Hoover condenser dryer, only a few months old, and has started to make a squeal/whistle. I'm thinking it might be the front fan needing some WD40, OR too much water vapour around the belt that moves the drum causing the sounds.
If it's the fan, lubricating the shaft and its components should fix the problem, if a wet fan then I'd think maybe fully cleaning the condenser filter, reservoir ect will fix the problem.
The problem seems to go away though "mostly" 15 or so minutes after you start the dryer, so that makes me think ones it gets warm something is expanding to allow more "give" so maybe the belt.
Aug 26, 2009 | Hoover Dryers
My Hoover TC650 condensor dryer has a fault. When turned on it makes a noise (buzz) but the drum does not revolve. If I turn it by hand and then quickly close the door and press the button it will...
i saw your question and never worked on a hoover dryer so i checked it out go here to see video
i have to tell you on all the dryers i've ever worked on they never had a cap in them,only washers,on a dryer that isn't a condenser dryer if you get the dreaded buzzing sound and start it like you did,open the door,hold in the door switch and spin the drum with your other hand while someone else pushes in the start button and it would start it would be the motor,i've seen a condenser dryer and the problem always was with the filter,people that had just bought one didn't know you had to clean out the filter box,never took one apart,i saw that nobody answered you so i hope this video helps you out and i learned that condenser dryers have a cap in them.
Dec 30, 2017 | Hoover Dryers
Tumble dryer
take the top off. there should be a small relay board to the right just behind the fascia. the fault probably lies in that board - relay not holding in
Mar 11, 2007 | Hoover HDC6 Electric Dryer
Hoover HDC6 Electric Dryer Logo
1,387 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
