Question about West Bend 55108 Espresso/coffee Maker
Replacement parts I need to replace steam plug, filter basket and filter holder for above machine. Your web site does not offer these. Please advise. Thanks!
Cuisinart grind & brew - spring in the filter area popped out. not sure where it goes?
Yes, you place the spring into the tube at the back. When you replace the basket holder, make certain you reach in behind the holder and guide the spring into the proper place on the holder. (Otherwise the spring will be forced to a permanent bend and not work as well. Can't find replacements for this spring on Cuisinart's website).
As for why it pops out better now, when you removed the basket holder and cleaned it, you also cleaned the plastic guides on each side. In normal use, these guides acculuminate coffee and tend to get sticky or gummy. When the door pops open, the sticky rails grab the guides and slow the sliding action.
Cleaning them restores the clean guide rails to slide open on. (Next time you clean the basket holder, remember to reach in and wipe out all the inner parts, including the plastic rails that the basket holder slides out on. These get coated with coffee as well. And the place around where the grind basket fits over the ground basket. This area always gets sticky with old coffee. Just use a wet paper towel and clean everything. (But remember to be careful when you reinstall the basket holder so that the spring fits back properly.
Dec 04, 2017 | Cuisinart Grind and Brew 10 Cup Coffee...
Filter mesh holder is damaged, locking holes are broken will not lock in place - need new filter mesh
Hi Joe: The model has been discontinued and difficult to find replacement parts. I located a few online suppliers offering a HEPA Filter that fits the BUC11700UC. See here:
http://www.vacuumcleaners.net/bosch-buz200hcuc-hepa-filter-for-bagless-jet-upright.html or
http://www.allergybegone.com/boshepfilfor4.html or
http://www.wikio.com/product/vacuum-parts-accessories-compatible_with_bosch-reviews-12020-page3-sort0.html
Is this the part you are looking for? The third site above does offer other replacement parts if you are looking for a different filter piece.
Thank you for using Fixya!
Jan 14, 2012 | Bosch BUC11700UC Cyclone Jet Bagless...
I have a Baby Gaggia, several years old. I buy IZZO ESE pods, which I understand should fit the holder. They do not in that a pod sits loose in the holder, with a margin round the edge between it and the...
Please try the following:
  • Remove the portafilter and activate the brew switch. Water should stream out of the shower screen. If not you need to clean the group components, or the machine is broken.
    To clean the group components, remove the center screw. The screen should drop down, the dispersion disk may be stuck, you can pry it loose with a flat head screw driver. Soak both of these in a descaling solution.
  • With the group components removed (as above) try brewing, water should stream out of a single hole. If not, you may have a faulty pump, or seals.
  • If water streams out normally, be sure that you are using the single espresso basket. This is the smaller basket that snaps into the portafilter, and has sort of a tulip shape.
  • Your group head gasket may be worn, and will need to be replaced. These need replacement ever 6 months to 12 months, and need to replaced even if the machine is rarely used, because they are made from natural rubber that dries out.
    Replacements can be found at many retailers online, a few are:
    espressocare.com, espressoparts.com, and seattlecoffeegear.com
Mar 02, 2011 | Gaggia Baby Espresso Machine
My pasquini livia machine is leaking from the base of the steam wand. Perhaps it is a gasket how do you replace these?
You have to take apart the system for changing the gaskets.If you are not a technical savvy don't try for it.Here is the parts diagram for your machine.Many of my fixya customers took apart the system to change the valve and they suffered a lot to fix it again back.All the best.
1 Boiler end gasket 11 Expanse Valve 21 Group gasket 2 Heating element 12 Drain 22 Refill solenoid 3 Gasket for above 13 Pressurestat 23 Group touch pad 4 Steam + water valve 14 Main switch 24 Drip tray grill 5 Pop off valve 15 Group 25 Water flow meter 6 Bleed valve 16 Group solenoid 26 Drip tray 7 Water level Probe 17 Group handle 27 Basket 8 Auto refill relay effect 18 Filter basket single 28 Steam-water valve knob 9 Heater exchanger injector 19 Plastic gasket 29 Manual refill valve 10 Heat wand 20 Site glass 30 Shower screen
the gasket look like this.I will cost around 12$.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Dec 29, 2010 | Pasquini Livietta Espresso Machine
Need to replace filter basket drip spout rubber ring
After searching for the replacement basket on web took whole coffee maker back to jcp and they replaced the 12cup coffee maker with a new item.
Jul 28, 2009 | Coffee Makers & Espresso Machines
My Cuisanart Espresso Maker EM-100 is creating a vacuum, so no liquid comes out and then I have to wait an hour to be able to remove the part that holds the coffee. Apparently it creates a vaccuum, holding...
Very strange problem for that model. I would remove the portafilter holder, and then run 3 cups distilled white vinegar through the machine - let it run on the espresso setting first, then let it run on the steam/water setting, with the function knob turned to water, and not steam. Clean any espresso grinds off the metal element that the portafilter holder usually conceals. Then try making a batch using the double filter basket, but only use a tiny amount of espresso - don't tamp very hard. If all is well, proceed to use the espresso maker. If not, call Cuisinart - that model has a 3-year warranty.
-Tha Mp3 Doctor
Apr 06, 2009 | Cuisinart EM-200 Espresso Machine
Gaggia Deluxe - Excessive steam discharging into filter holder
your seal of non teturn valve of group, just above metal part where you put upper filter. open the valve and carefuly clean, check the seal and spring.
Mar 09, 2009 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Exploding........
Hi All. I too was having this so called exploding issue with my machine & couldn't get any coffee!! The culprit is a clogged filter!! As you might know, Breville uses a double wall construction for the filter which incorporates an inner cup with many fine holes and there is only ONE small hole on the bottom of the outer wall(bottom). I guess over time some fine fine grounds get thru the inner layer and accumulate between the two layers and eventually get compacted enough to completely clog the filter to a point that the pump cannot push the water through it!! Thus the pressure from the pump can't escape & is releasd when you try to remove the coffee basket!! You can try to use a small pin inserted in the bottom hole to see if it clears the obstruction. It didn't work for me! I even tried using high pressure air to clear it, again unsuccessful!
THE FIX: Buy a new filter!
P.S. I found my machine to have some build up behind the strainer where the water enters the coffee chamber. To clean and clear, follow these steps: Unplugg the power cord!! Remove the watertank. Remove the filter holder. Turn the machine upside-down, Remove ONE screw in the center of the coffee chamber(It looks like a strainer with several holes). Remove the strainer and wash & clean any build up behind it. Reinstall in reverse order.
Sep 20, 2008 | Breville ESP8XL Espresso Machine
This sux
Did you ever solve this problem? I have a manual that I could email to you.
Christine Bingham
Feb 23, 2008 | West Bend 55108 Espresso/coffee Maker
West Bend 55108 Espresso/coffee Maker Logo
91 people viewed this question
Top West Bend Coffee Makers & Espresso Machines Experts
Douglas Dinnebeil
Douglas Dinnebeil
Are you a West Bend Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
