Question about Samsung RFG293HA
How do you clear Error code 1E on Samsung RFG293HA Refrig? I believe it has something to do with the freezer?
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: I have a two month
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 31, 2010
Daewoo DWD-F1011 1E error code I have a daewoo washing machine model DWD-F1011 and it start working the wash before no working spin and gives error code 1E. Any idea what that might be?
I do not believe that is a 1E I think it's an IE error code which would be water inlet wiring or something like that. Here is the code list, scroll down until you find IE, Daewoo errors start at E2, hope this helps.
http://removeandreplace.com/2015/11/02/daewoo-washing-machine-error-fault-codes/
Aug 30, 2016 | Daewoo Washing Machines
I have a samsung Refigerator RF4287HABP that has an error code SE after a power failure. What should I do.
According to Samsung Customer Support SE stand for Sensor Error... after a power outage... so follow the same procedure as 1e (holding the save energy and lighting button for about 6 to 10 seconds.)
Jan 02, 2015 | Samsung RF4287HABP 28 cu. ft. 4-door...
Fix error 1e on Samsung wf875
That's a pressure sensor error. The pressure sensor detects your water level.
If you take the top off of your wash machine, you should see a clear, plastic air tube (like the type used for aquariums) going from your outer tub to a sensor mounted on the top right of the washer (well, I think that's where it is on yours. Your model number isn't anything I have in my records). Remove the air tube from the sensor and blow through the tube to clear any obstructions. Then, put the tube back on the sensor and try to run a wash cycle. If the error code pops up again, change the hose and the sensor. If you still get it, make sure you aren't using too much soap and your drain hose isn't siphoning water from the stand pipe. Because, the next thing you are looking at is a new control board.
Oct 20, 2014 | Samsung WF8704RSW
1E error code
The Flex zone Temp sensor is the most common issue. check your model number suffix to make sure the part is correct:
http://www.appliancepartspros.com/samsung-temperature-sensor-da47-00095e-ap4136048.html
Best,
Joe
Jan 31, 2014 | Samsung RS2534 Side by Side Refrigerator
Samsung Refrigerator Error Code 1E or IE
1E error is bad freezer sensor. You would need to either replace PART NUMBER: DA32-10104N behind the freezer evaporator cover or the main pcb PART NUMBER: DA41-00684A
Mar 15, 2013 | Samsung RF4287HARS French Door...
The tempature on my refrig. panel continues to blink on the frig.side. I have it at the lowest settinng which is 34F. The Freezer has not moved nor is it blinking. The freezer is still holding its temp. ...
The computer has detected an error in the system and needs to be addressed by a Samsung qualified technician. They have a list of error codes that they can figure out what's wrong with the unit.
Jul 18, 2011 | Samsung RS2630SH Side by Side Refrigerator
Code on door says er dH on Kenmore elite refrig
This error code has something to do with a defrost sensor and happened after an extended power outage. I unplugged the refrig and it reset itself!
Jul 17, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Samsung RFG293HA Logo
66 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
