2008 Qlink Legacy 250 Logo
Doug Dickson Posted on Nov 28, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
QLink Frontrunner where do you change gear oil in rear end
Rob Stephenson
Level 2:
Sergeant:
  • Expert 284 Answers
  • Posted on Dec 02, 2013
Rob Stephenson
Expert
Level 2:
Sergeant:
Answers
284
Questions
0
Helped
82396
Points
501
Typically most gear drive motorcycles use the same type of system. There will be a small bolt either 8mm or 10mm or a Phillips head . That will be at the bottom of the gear case just below the rear axle. Remove the bolt and let it drain. There should be a smaller screw or bolt of some sort above the axle. That will be the " weep " hole. Once you finish emptying the gear box. You re install the drain plug and fill the gear box through the weep hole. You fill it til it starts to come out past the threads. That is the correct fluid amount. Re install the weep hole plug and you're good to go.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_5bac37c3cb991fdb
2 Related Answers
tombones
  • 3567 Answers
  • Posted on Apr 19, 2009
SOURCE: Type of gear oil
Use 10w40 motor oil. Stick with the major brands; Pennzoil, Quaker State, Mobil or Shell.
Please rate this answer. Thanks jaacosta!
Anonymous
  • 12 Answers
  • Posted on Oct 19, 2010
SOURCE: QLINK owners manual says to
http://www.qlinkmotorblog.com/qlink_motor_blog/2009/08/oil-changes-keep-your-vehicle-up-and-running.html
2010 qlink frontrunner 500 once warmed up wont stay running why?
I take help from online w ebsites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer... rest is up to u.. U can also get free manuals
Jun 17, 2018 • ATVs
Where do you put oil in rear end of QLink 500
aSK TH EDEALER OR SHOP THEY WILL TELL YOU FREE
I need to know what kind of real end oil should i use on my 2007 yamaha vstar classic 650
For the final drive oil you can use any 80/90 Hypoid gear oil. If you choose a synthetic Hypoid gear oil your rear end will run cooler. One quart of oil is enough for 4 or 5 rear end oil changes. Because the rear ends are so expensive (around $1000), I change my rear end oil every other engine oil change.
1helpful
What type oil do you use in the rear wheel?
If you are talking about the final drive oil you can use any 80/90 Hypoid gear oil. If you choose a synthetic Hypoid gear oil your rear end will run cooler. One quart of oil is enough for 4 or 5 rear end oil changes. Because the rear ends are so expensive ($1000), I change my rear end oil every other oil change.
What type oil does the rear end and driveshaft use.
For the final drive oil you can use any 80/90 Hypoid gear oil. If you choose a synthetic Hypoid gear oil your rear end will run cooler. One quart of oil is enough for 4 or 5 rear end oil changes. Because the rear ends are so expensive ($1000), I change my rear end oil every other oil change.
What grade transmision oil should i use in the rear wheel hub for the drive shaft on my xvs1100
Any quality 80/90 hypoid gear oil will work. If you use a synthetic hypoid gear oil the rear end will have less friction, generate less heat , and last longer. Final drives are expensive and do not use much oil , maybe 1/2 cup. I recommend changing the rear end oil every other oil change.
There is a clanging noise when i put it in gear and can hear it while driving is it the rear end or universal joint
Check rear-end fluid level and play in rear pinion gear.
Check universal joints for play. If play is in pinion gear change rear end fluid and add a full bottle of LUCAS oil stabilizer, will quiet rear end noise.
Top Qlink Experts
Arnie Burke
Arnie Burke
Steve Sweetleaf
Steve Sweetleaf
ADMIN Andrew
ADMIN Andrew
Are you a Qlink Expert? Answer questions, earn points and help others
