Question about Ovens
If you can help let me know
Food inside cook light come on error43 and locked can't open
MODEL FGF355CGBF Door lock activates when check food in oven not allowing to continue to cook. occasionally stays locked
Hello Richard;
My name is Peter. I am a retired field service appliance technician.
You have an old unit. Some parts such as the door switch are no longer available.
You door lock should only engage when you are in the self cleaning mode. So you have a communications problem between the door lock and you control panel.
25601831-imv3tze4snahc4os1l3biiwf-2-0.jpg Latch Motor Substitution: 5304449471 Cost $180.00
25601831-imv3tze4snahc4os1l3biiwf-2-5.jpg Substitution: 316131600R Cost: $130.00
You may to replace one or both of these components.
Based on the cost of the parts and my service call experience you are looking at a $500.00 -$600.00 service call.
It's time for a new unit. Go into the internet and search; :Sears Outlet Store". This is a scratch and dent store where you can save several hundred dollars on a new unit with a one year warrantee.
Mar 23, 2015 | Frigidaire Ovens
Had 3rd panel installed march 2014-jtp70 30 inches. now nothing is working-only the light and clock are functioning
I never really fixed the problem, but have avoided it most of the time. Tell me if I'm wrong, but when you open the door to pull out your food after cooking, the steam from the food comes up and fries the control panel, right? To temporarily fix (reset), we just flipped the circuit breaker on and off. To avoid it after that, we would hold a cookie sheet at the top of the oven door, blocking the control panel when we opened the door after the food had cooked. This keeps the steam from blasting the control panel and locking it. Instead, the steam goes into the room.
Pretty ridiculous to have to do that, isn't it? :-( I think we're reaping what we so when we outsource our manufacturing to China...
Jul 05, 2014 | GE JTP70 Electric Single Oven
Why has baumatic B501SS oven covered in light gray coating inside when heated, now not working
It sound like the heating element burned out. Check the element and see if there is a burned spot or blister somewhere along the element. If so the element will need replacing.
May 03, 2014 | Baumatic B180 Electric Single Oven
GE oven controls lock after opening door and steam from cooked food comes out
you may find there is some insulating material missing internally as I would imagine steam affecting the front of the control panel
Nov 14, 2013 | GE JTP70 Electric Single Oven
Why is mu beko cooker building up steam in the over and making food all soggy comet have told me not to cook food with any water in but thats impossible
You do not normally cook with water inside the oven, ovens are for dry cooking only, rings are for boiling water and used for cooking this style
Jul 12, 2011 | Ovens
How do I get the door open after self cleaning and what do I push to self cleaning
Hi, Some ovens are self cleaning During the cleaning process, the oven heats up to a temperature of 900 degrees Fahrenheit. The extreme heat cooks off food and spills inside the oven, leaving ash that can easily be wiped out. The oven door locks while it is cleaning to prevent the door from being opened. Self cleaning ovens are better insulated than regular ovens to keep the extreme heat inside.
Instructions
Read the owner's manual that came with your oven before you perform self cleaning. Although all self cleaning ovens work basically the same way, there may be slight variations for some manufacturers and models.
Take out the oven racks. You need to clean the oven racks by hand, and then put them back in when the oven is done cleaning.
Wipe up any spills and messes inside the oven first, using warm water and a mild soap. Ovens smoke more during cleaning when there is food inside. Wash the inside of the oven door as well. Do not scrub the door gaskets, just gently wipe them off. Damaging the gaskets prevents the oven from sealing.
Lock your oven door manually if your model does not lock it automatically when you clean.
Open a window near the oven for ventilation. There is a certain amount of smoke when you clean the oven. The dirtier the oven is, the more smoke is created.
Turn the control on your oven to "clean" and set the timer for 2 to 5 hours depending on how dirty your oven is, and what the manufacturer recommends.
Wait for the cleaning to finish and the oven to cool before opening door. When oven is fully cooled wipe up any ash inside. If your oven is not completely clean, next time set the timer for longer. If your oven is spotless you might want to see if you can get away with a shorter cleaning time.
Tips & Warnings
Because self cleaning ovens are better insulated, they are more energy efficient when used for cooking. However, if you run the self cleaning feature on your oven more than once a month, you offset the savings you realized. With light to moderate use your oven should be able to be cleaned every one to three months.
Save on the electricity used with a self cleaning oven by cleaning the oven right after use at a high temperature. For example, if you set your oven to clean after making French fries at 450 degrees, it takes less energy to get the oven up to the required 900 degrees.
If you have pet birds, take them out of the house before cleaning your oven. Over heated cooking surfaces, oils and fats, can create fumes that are harmful for a bird's delicate respiratory system.
Hope it helped.
May 28, 2011 | Ovens
We have recently purchased a Coopers halogen oven. I cooked a frozen fruit pie in it and the pastry looked beautiful, but when it was cut open the middle was cold and the pastry under the fruit not cooked....
Frozen food should be defrosted before cooking in halogen ovens.
Halogen ovens use only radiant heat and will not cook the centre of frozen food.
Jan 21, 2010 | Ovens
Accidently started clean, food inside,hit cancel,can't open
you would have to disassemble the cook top in order to get the the locking mechanism to manualy unlockit
May 01, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
How can i quit cleaning oven?
During the self clean cycle, oven temp will exceed 900 degrees F. At these temps, if you opened the door, the food inside would immediately catch on fire when the supply of oxygen hit it. When you turn your self clean cycle off, the oven door will remain locked until the internal temp drop below aprox. 550 degrees F for your safety. Once the oven cool below this temp, you will be able to start using the bake or broil again. This should be a Fix-Ya for your oven.
Dec 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
OTR Microwave Magnetron Fan and Interior Light Run with Door Open
Could be a defective door interlock or control board.
Mar 06, 2017 | Ovens
Ovens Logo
13 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
