Question about LG 42LC2D 42 in. LCD HDTV
I have a 47LE5400 that is not working. When powering the tv the screen shows the LG logo, the channel that is playing and after 3-5 seconds the display goes black. Could tell me how I can troublesho
    Top Expert:
  • LG Master
  • 34,763 Answers
Probable power supply trouble.
Posted on Nov 28, 2013
freetek
  • 5568 Answers
SOURCE: LG 47" LCD FLAT SCREEN
IF IT WASNT DIGITAL HD I WOULD HAVE SUSPECTED HIGH VOLTAGE POWER SUPPLY BUT THAT DOES NOT EXIST HERE.
Well, not completely true; the fluorescent backlight is still a high voltage device, even if only hundreds of volts instead of kilovolts, and either the lamp(s) or the power supply for it (them) is causing the dropout of your picture. When it does it next time, look at the screen from various angles, I think you will see that video content is still there.
Posted on Sep 14, 2008
welcomejee
  • 10594 Answers
SOURCE: 32LG3000 LCD TV shows no picture when resuming from standby
It seems just channel stored data issue.
Please perform Auto Preset / Auto Channel / Auto Tuning (mentioned menu items) and store all channels again.
Hope problem will resolve.
Posted on Dec 18, 2008
  • 21 Answers
SOURCE: lg lcd tv screen goes
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Posted on Sep 18, 2009
  • 458 Answers
SOURCE: 42" LG Plasma tv, no picture - black screen, but have sound.
Most a likely a problem with your Y-Sustain board which will then not drive the screen giving a black picture. The fuse on the board may be open circuit & need replaced but most likely you will need to have the sustain board replaced.
Posted on Oct 28, 2009
electronick
  • 505 Answers
SOURCE: LG 50PG25 Plasma TV, black screen sound still works.
this faint picture issue is usually caused by a bad z sustain board. it is the smaller scan board on the right side of the tv when viewed from the back. it has some large cables that energize the plasma panel, dont confuse with the y sustain which has the tiny ribbon cables that address each line of the picture.
there should be a # on the board indicating the part number, plug it into a search engine to find parts.
this could also be a low voltage or something else, check the Vs and Va voltages and confirm theyre correct with the ones listed on the sticker inside the tv. Be careful this is dangerous and you can get shocked if you not familliar. The heatsinks can be energized and shock you , exercise caution. if you order a z sus board, make sure you can return if it doesn't fix. I'd say 95% chance its a z sus
Posted on May 21, 2010
I have a 50inch LG TV that when switching between programmes the TV goes blank for a moment
Are you using cable and if so which company and box?
ELECTREPAIRUSA@ELECTREPAIRUSA.COM
Dec 07, 2016 | LG Televison & Video
My LG 47LE5400 LED powers on with a black screen and no volume!! What could this be?
How long have u had the TV?
Can u get any menus to open?
r there any controls on the back?
Have u contacted tech supp?
have u recently moved the unit?
May 11, 2014 | LG 47LE5400 47 in. TV
Hello, I have a lg lcd monitor. w1941s model. when I start my computer, it work for sometime. then it goes blank showing only the LG logo. then the power button doesnot work. it hang up glowing. again
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 06, 2014 | LG Computers & Internet
My LG LH40 47Inch screen shows logo then gos off
Main board fault. Contact any service technician, or the authorized service center for LG. The second said will be the best.
Gopakumar Gopalan Google
Apr 01, 2014 | LG 47LH40 47 in. LCD HDTV
Lg 47le5400 size picture to fit the screen
You can fit the picture to the tv screen by clicking the buttons on the receiver. Change the setting to 1080i from 720i. It is going to work like that.
Nov 11, 2010 | LG 47LE5400 47 in. TV
Tv and ps3 plugged in and on. av channel shows an empty screen
Follow these steps to resolve your problem:
1. Turn off the PS3 so it only shows a red light. You can hold the power button on the front until it goes into standby. To be sure, flick the power switch on the back of the Play Station 3 off and then back on.
2. Make sure your Play Station 3 is connected to your regular TV (not HDTV) with the standard video cables.
3. Press and hold the power button until the screen "flickers" and then immediately release. This should reset the video settings.
4. Wait a few seconds, and the Play Station 3 (PS3) logo should appear.
If this does not resolve the problem, follow these steps:
3. Press and hold the power button on the front until the Play Station 3 beeps and then turns off again. This should reset the video for you and you can turn it back on after this.
Jun 10, 2010 | Sony Playstation 3 (PS3) Console
LG 42LC2D 42 in. LCD HDTV Logo
161 people viewed this question
Computer Repairing
Computer Repairing
