Question about Hitachi L42S503 TV
HDMI 2, 3 and 4 don't work - Hitachi L42S503 TV
HDMI`S DON`T WORK ON VIZIO TV
The HDMI controller is bad. The easiest "work around" is to use the "Component" connectors instead. The only downside is you get no higher than 720P. However, most cable/satellite and _all_ antenna signals are only 720P anyway. Most people are only seeing 1080P when viewing Blu-Ray discs. Cheapest alternative is to buy an "HDMI to Component" converter, which will let you connect multiple HDMI connectors to one box, and then have one set of Component connectors coming out of the box. You select different "sources" on the box itself.
Mar 07, 2016 | Vizio Televison & Video
Help with sound problem
Try doing the following: go to audio output settings and set your audio output port to HDMI.
Jun 19, 2013 | Video Game Consoles & Games
No Signal when HDMI connected with TV and cable box
Replace HDMI cable first, then check whether your box works on HDMI out. Try connecting box using other out (USB, VGA, DVI, DP, cable)
Apr 25, 2017 | Sony BRAVIA Televison & Video
Can you add additional receivers to the Nyrius HDMI system? I don't see that addressed anywhere.
The NAVS500 appears to be a 1-1 solution. From looking at other product content from Nyrius, it looks like the NAVS501 and NPCS550 models can be used with multiple transmitters.
Oct 01, 2012 | Nyrius NAVS500 HD 1080p HDMI Digital...
Hdmi outlets on slyvania lc320slx don't work
you may need to upgrade the firmware....it seems the 1.5 version corrected for "no picture with certain devices connected with HDMI"
you can find it here
Here you can find the instructions for performing the Firmware upgrade.
Aug 31, 2012 | Sylvania LC320SLX 32 in. LCD TV
Yamaha rx-v1600 hdmi output not working
Have you inspected the HDMI socket? I had the same problem and the socket had been damaged by a tight fit cabinet with insuficcient space behind the amplifier. A sideways cable tug on the inserted HDMI cable had snapped a small piece of plastic seperating the two rows of HDMI connectors, and three were splayed out, so no connection when plugged in. Solution was to carefully re-align the connector fingers and glue a tiny piece of insulating material between the two rows. The output now works perfectly. A bit fiddley, but worth the trouble when you look at how much Yamaha would charge to fit a new socket, or even a new board!
Don.
Aug 11, 2012 | Yamaha RX-V1600 Receiver
Picture has red tint when macbook air is connected through HDMI
I have exactly the same problem with my mac mini when I connect it to my Sony Bravia with an HDMI cable which works fine with my Apple TV. Sorry I don't have an answer yet!
Nov 10, 2011 | Dell W3707C 37 in. LCD Television
Our HDMI 1, 2, & 3 jacks do not work any longer. It's not the HDMI cord (replaced already) it's not the dish network box (replaced it today) - it's the TV. Can we fix it ourselves? Sanyo...
There is no "fix" for defective jacks for the average consumer like that.
I suggest using the COMPONENT inputs instead. Sorry, that means another new set of wires.
Component input will still be HD, it's just a lot more wires than the simple "one wire" HDMI.
At least you don't have to trash (or get repairs) to your TV and it will hold you over until you do.
Take care!
Sep 11, 2011 | Sanyo DP50747 50 in. Plasma TV
How do I program hdmi imputs on a txsr 506
You don't program hdmi. The manual describes all that stuff and the unnamed product at the other end of the cable plays a part, too.
http://www.retrevo.com/support/Onkyo-TX-SR506-Receivers-manual/id/13748ci477/t/2/
Sep 06, 2011 | Onkyo Audio Players & Recorders
TV was not in use but storm came through this morning and we were without power for 2 hours. Now when I turn the TV on it is not receiving a signal through any of the 4 HDMI ports. Cables work ok,...
Processor could be locked up, unplug the set from the wall for 40 Min. and that reset it back to normal. If that don't work, than it will need repair.
Aug 23, 2011 | LG 42LH40 LCD TV
Open Questions:
Hitachi L42S503 TV Logo
24 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
