Green lines from left to right lg tv
I have green lines from left to right on my lg tv
    Master:
  • 687 Answers
Most likely LCD Panel
Posted on Nov 30, 2013
5 Suggested Answers
AndroidLVR
  • 31 Answers
SOURCE: green lines down length of screen on my samsung 40 inch LE40F8
The reason for the green lines are the resolution. I'm assuming you're TV is set at 1080i, not 720p or 1080p correct? What happens is the "i" stands for interlaced, meaning, your TV displays your images with scan-lines. The "p" stands for progressive, meaning, TV displays picture as a whole. You can not visibly see the scan lines when seeing 1080i, but certain TV programs are not outputting their show to the resolution you're at, which will cause you to have the green line up at the top of your TV. SOME TVs might let you adjust the settings to rid yourself of the scanline, but most consumer TVs will not let you without the maintenance code to protect your unit from over calibrating and braking your television. Hope this helps.
Posted on Mar 20, 2010
SOURCE: Philips plasma tv. has green line on left side of screen.
Using your TV's remote control press the right cursor button three times and it will adjust the Screen to the right and the green line will disappear. Use the left button if your green line is on the left.
Thanks to:
http://www.tivocommunity.com/tivo-vb/showthread.php?t=319984
Posted on Nov 25, 2010
  • 324 Answers
SOURCE: Hi, I own a
Sorry to lay some bad news on you.........
It sounds like your set has had defective silk screening during the manufacturing process.
The lines in a plasma set are laid out using a silk screen process, the defects (if any) are burned out by laser, then the surface is sealed to protect the lines with a vacuum coating process. Your set sounds like it had a manufacturing defect that quality control somehow missed...it happens!
The good news is that since your set is brand new, you should be able to exchange it. Don't delay!
Posted on Feb 01, 2011
rohntech
  • 422 Answers
SOURCE: our 42" lg tv is
no. there's some problem on its display circuits that it need to be corrected, picture becoming dark has some problem with the inverter power supply circuits that responsible for lighting the small lcd flourescent light. maybe some loose connection in the components cause that to happen
Posted on Feb 06, 2011
LG 60UF7300 UHD TV has screen issues
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
May 19, 2017 | LG Televison & Video
Lg 60Pk750 plasma green lines
If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Sep 10, 2016 | LG 60PK750 60 in HDTVReady Plasma TV
LG vertical green line
LG plasma vertical line repair - YouTube
? 2:33
https://www.youtube.com/watch?v=24FkcQoeGPg
Feb 10, 2013 - Uploaded by Matt Mayer
I have an LG plasma, my vertical line is in the middle, as if one would have ... Panasonic Plasma TV TC-P50X5 Vertical GreenBar Line Fix ...
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ..
Jan 16, 2016 | LG Televison & Video
Vertical green line
? 4:45
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
I Have An Lg Plasma It Has A Green Line Down The Center What ...
www.diyforums.net/i-have-an-lg-plasma-it-has-a-green-line-down-the-ce...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
LG 50PK550 Plasma Single Thin Green Vertical Line - Fixya
www.fixya.com/.../t12061168-lg_50pk550_plasma_single_thin_green
Mar 10, 2008 - Posted on Mar 17, 2012.
Lg 55lv6300 has red and green vertical lines help
On other panel TV's this is known as a convergence problem. You have to get experienced help costing about $150 or do it yourself. TV's that age have this issue, and you have to open the Tv and find the voltage/convergence box with three screws on it. It usually has blue, green and red adjustment screws, with red on the right. So go for the green and red and adjust until the issue goes away.
Jan 25, 2015 | LG Televison & Video
What is the problem with a lg plasma tv green stripes 50% of the screen for 10 minutes
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes are given with illustrations. You can get an idea about the fault to an extent.
Aug 22, 2014 | LG MZ42PZ10 42 in Plasma TV
Our 42" lg tv is
Feb 06, 2011 | LG 42LC2D 42 in. LCD HDTV
Hi, I own a 50 inches plasma LG tv (the model is 50pj550) for only 2 weeks and it has started giving me 5 green dotted lines 9consisting of green pixels), from top right corner to bottown left corner....
Feb 01, 2011 | LG Televison & Video
Green vertical line on videocon 42inch plasma tv
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
Jul 27, 2009 | LG 60PS60 60 in. Plasma HDTV
Thanks to:
Oct 16, 2008 | Philips 50PF7320A 50 in. Plasma HDTV
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Electro Med Services...
