Question about Garden
Jonesred chainsaw has no compression. help.
No compression
    Sergeant:
  • 458 Answers
Pull ot the spark plug and look for any metal shavings on the plug. If you find some the saw in done. My first guess the saw was run with the wrong fuel mixture.
Posted on Dec 02, 2013
    Problem Solver:
  • 13 Answers
Remove the muffler check if the piston is scratched!! I am quite sure
This is the problem. If your are very lucky you might be able to fix the cylider by honing.In the worst case you have to get a new piston and cylinder kit.I reccomend a chineese aftermarket kit.or even better a used cylinder and piston from a friend in exange for a box of beer.
Posted on Dec 24, 2013
Need to know what the compression should be for a 2150 poulan chainsaw
the compression on a chainsaw can be checked by simply holding the crank rope by itself, it should chug down the rope very slowly.
Apr 03, 2013 | Poulan Oregon Chainsaw Chain For Chainsaw...
Compression ratio for husqvarna 455 rancher chainsaw
be careful check the compression on that engine it has a compression release valve on the side of the cylinder the release builds up with carbon and it sticks dropping the compression
Aug 27, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
Older (early80s) 80cc jonesred wont stay started, It runs for a few seconds after i pull the recoil and only with the choke open the it stalls out
Fuel starvation, replace the filter in the fuel tank, check the fuel hose up to the tank for signs of leaks or cracks, if no better it will need a carb service, and clean the internal carb filter, as it is an old saw new diaphrams will probably be required.
Oct 05, 2011 | Garden
How to control the amount of oil going to the bar and chain on a jonesred model 630 cghainsaw
The oil pump is adjustable, if you remove the cover/bar and chain, you will see the adjuster screw to the top left hand side of the oil pump,located just behind the sprocket, it is a black screw, it is marked around the outside from 1 to 4, 4 being the highest setting.
Sep 27, 2011 | Garden
I have a craftman chainsaw with a 42 cc engine has compression of 90 lbs does it need rebuilt it wont start
90lbs is not enough compression, so yes rebuild, or more fiscal idea is get a new one, unless you can do the labor yourself.
Sep 25, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
M842 chainsaw wont start when hot
I suspect your warm start procedure is the fault, the manual is not correct IMO. Any choke on a warm engine causes flooding, try this, if no better post back or return it for warranty replacement.
Start Procedure
Cold:
  1. Ignition on/off to on.
  2. Set compression release – optional step even if saw is equipped with a compression release.
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4).
  4. Set compression release – optional step even if saw is equipped with a compression release.
  5. Push (open) choke pull starter until it starts. (usually first pull).
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull).
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 13, 2010 | McCulloch Garden
Im having problems starting an MS250 Stihl chainsaw. Can you give
Chances are good that the compression is not to blame. I would look at:
1. Bad Fuel
2. Fuel Line/filter
3. Carb dirty/mis adjusted
3. Spark Plug
4. Ignition
Dec 01, 2009 | Standard Oregon Chainsaw Chain For Stihl...
Blowing out gas at the start. Drained and filled with fresh gas mixture. Cleaned spark plug and srayed carb cleaner in hole. Pull choke pull cord , blowing gas out of carb. Stuck float? Buy carb kit from...
No floats in chainsaw carbs. Severly flooded most common start problem with chainsaws. Read and follow the start procedure in your manual. Don't use choke on flooded engine (may set fast idle, set then turn off)!
Extreme Flooding by Dolfoff
Please follow this link, http://www.fixya.com/support/t3226410-no_spark_new_plug_but_continues_flood cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button
Start Procedure
Cold:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls)
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) - Don’t pull with choke closed.
Hope this helps
Lou
Oct 31, 2009 | McCulloch Garden
Huxqvarna chainsaw Model 41
this unit does not have a compression release.you must have another problem some where.let me know what you have either done or not done to the saw and i will be glad to help......
Mar 23, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Compression Poulan chainsaw
you can not set the compression on two cycle motors,the compression new is at about 90 to 95 pounds after six to nine pulls of the recoil
Jan 05, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Garden Logo
47 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
